hotwheels
Posted: Wed Jul 17, 2013 1:00 am Post subject: proper way to splice RG400 pigtails? |
Is there a proper way to splice RG400 coax? This may have been discussed in the Aeroelectric docs, but I don't recall seeing it.
RG400 pigtails were connected to the back of my radio stack and made it easy to work with coax runs under the panel. At the time BNC crimped connectors were used for splicing and they seem to work fine for the moment. However, I'm concerned that BNC may not offer the most reliable choice for the long term, especially when connecting coax runs that keep one flying in the right direction...
I ran across an application that used SMA connectors... Better choice? If so, where can those be sourced for a reasonable price?
Jay
RV-10 Phase 1
billp(at)wwpc.com Guest
Posted: Wed Jul 17, 2013 6:31 am Post subject: proper way to splice RG400 pigtails? |
BNC connectors are a very nice constant impedance connector. The good
ones are silver plated and I have seen ones that are still serviceable
after half a century of aviation use. TNC is another choice and those
connectors are available for RG400 as crimped connectors too. SMA
connectors were developed specifically for higher frequencies with lower
power handling capability in tighter spaces. If you have a connection
for a receive-only (like a VOR antenna, GPS antenna, XM antenna) then
SMA would work for that. I don't think SMA is mechanically superior to
the BNC/TNC connectors. I wouldn't use an SMA connector on a transmit
antenna (comm, xponder, etc).
SMA connectors are probably going to be more expensive because they
aren't as much of a commodity item as the BNC is. Pasternack is who I
get connectors from. They probably are not the cheapest but they only
carry good quality connectors and they have everything and I don't have
to spend hours searching. http://www.pasternack.com/
You can expect to pay about $10 a piece for RG400 SMA Male connectors.
Bill
Jay
RV-10 Phase 1
http://forums.matronics.com/viewtopic.php?p=404822#404822
Posted: Wed Jul 17, 2013 7:07 am Post subject: proper way to splice RG400 pigtails? |
Either one is just fine. I use SMA under heat shrink
to splice salvaged cut-pieces for longer finished
lengths.
I can sell you a pair of BNC or SMA cable male
and female connectors. The BNC are easier to
install tho. Unless you have some practice with
the SMA I'll suggest that BNC is your highest
order probability for success.
Posted: Wed Jul 17, 2013 10:10 am Post subject: proper way to splice RG400 pigtails? |
Quote: | >I ran across an application that used SMA connectors... Better
lengths.
When extending an existing coax, consider the
value of trimming the original cable back some
distance to move the splice to a more convenient
location.
Things can be pretty busy behind the panel and
adding another mated pair of connectors only
6" away from one of your radios may not be the
most attractive location.
Cutting some of the original cable back before
splicing on the extension offers an opportunity
to put the spice in a less obtrusive location.
