		n100rh(at)sbcglobal.net Guest
				 Posted: Sun Jul 21, 2013 12:03 pm    Post subject: RotaxEngines-List Digest: 8 Msgs - 07/10/13 |
				A quick question for you all. I have a 912S in a Rans S7. Out of the
 blue the oil pressure gauge is rapidly swinging from high to low
 followed by a pause at the correct oil pressure. Then more of the same.
 This only happens after flying for 20 min or so in 70F weather. I
 figured it must be the sender unit which is attached to the block near
 the oil pump. I got the same readings on the next flight. Reducing the
 engine to idle causes the gauge to settle down.
 However, here's where it gets interesting, I noticed that all the
 gauges, tach, oil temp, oil pressure and voltage are stable at the
 beginning of the flight but when the oil pressure starts to swing wildly
 the other gauges too have started to vibrate, not to the extent of the
 oil pressure.
 I'm starting to become suspicious that the voltage regulator is getting
 ready to crap out. Thoughts?
 Ralph
 Reno, NV
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		rickofudall
				 Posted: Sun Jul 21, 2013 7:00 pm    Post subject: RotaxEngines-List Digest: 8 Msgs - 07/10/13 |
				Check engine to airframe grounds and instrument grounds first.
 Rick Girard
 On Sun, Jul 21, 2013 at 3:02 PM, Ralph K. Hallett III <n100rh(at)sbcglobal.net (n100rh(at)sbcglobal.net)> wrote:
   	  | Quote: | 	 		  --> RotaxEngines-List message posted by: "Ralph K. Hallett III" <n100rh(at)sbcglobal.net (n100rh(at)sbcglobal.net)>
  A quick question for you all. I have a 912S in a Rans S7. Out of the blue the oil pressure gauge is rapidly swinging from high to low followed by a pause at the correct oil pressure. Then more of the same. This only happens after flying for 20 min or so in 70F weather. I figured it must be the sender unit which is attached to the block near the oil pump. I got the same readings on the next flight. Reducing the engine to idle causes the gauge to settle down.
   However, here's where it gets interesting, I noticed that all the gauges, tach, oil temp, oil pressure and voltage are stable at the beginning of the flight but when the oil pressure starts to swing wildly the other gauges too have started to vibrate, not to the extent of the oil pressure.
   I'm starting to become suspicious that the voltage regulator is getting ready to crap out. Thoughts?
  Ralph
  Reno, NV
  -List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
  http://forums.matronics.com
  le, List Admin.
 Zulu Delta
 Mk IIIC
 Thanks, Homer GBYM
    - Groucho Marx
		Roger Lee
				 Posted: Mon Jul 22, 2013 5:25 am    Post subject: Re: RotaxEngines-List Digest: 8 Msgs - 07/10/13 |
				Hi Ralph,
 I'm with Rick. Sounds like a poor ground. It could be a loose ground or a corroded one.
  _________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Home 520-574-1080  TRY HOME FIRST
Cell 520-349-7056 |
