1rv4
Posted: Wed Jul 24, 2013 6:52 am Post subject: Zodiac 601 with Jabiru engine radio noise revisited. |
Hi Bob and All
I had a chance to do some work on the Zodiac 601 with a jabiru engine again. The problem is the Microair radio has a very loud hum when transmitting. The voice is clear but along with the voice is a very loud hum (whine). This happens with either the radio, or intercom being used, makes no difference. So far I’ve installed a forest of tabs on the firewall, and rewired all grounds to it, Jabiru recommended twisting the alternator(PM) leads full length, this was done, phone jack isolation washers where installed and checked for no errant grounds, regulator/rectifier hot lead was moved to the battery, ground was moved to forest of tabs big bolt. Mic audio and mic ground wires where separated as best as I could for most of their length(short run anyway). Capacitor was installed across the bus to ground.
The noise starts to appear at 1600 rpm and increases in volume up to max engine rpm. The alternator cuts in at 1600 rpm. Disconnected the alternator and ran it, no hum, everything is fine. If it is the alternator being the culprit, is there anyway to deal with it?
Thanks for everyone's suggestions so far but I’m running out of ideas.
Chris F
nuckollsr
Joined: 24 Mar 2009 Posts: 95 Location: Medicine Lodge, KS
Posted: Fri Jul 26, 2013 7:16 am Post subject: Re: Zodiac 601 with Jabiru engine radio noise revisited. |
This suggests that the noise is being injected into the microphone wiring such it is heard on the intercom and carried through to the radio.
ALL grounds? Avionics grounds should be treated as shown in installation diagrams. For example, microphone and headset grounds are generally routed with their signal wires and grounded to the device that get the signals . . . intercom or radio. This is illustrated and discussed in the chapter on audio systems.
Pointless
Phone jack isolation washers where installed and checked for no errant grounds,
Good
Okay
OOPS! See above.
Okay but pointless. Bus filters never help.
The alternator is the greatest generator of noise in the airplane. It cannot be filtered by any practical means . . . only careful crafting of system architectures will isolated the victim radios from the potential antagonism of the alternator.
Run all three microphone wires in twisted trio (shielded too if handy but not a driving requirement) from mic jack to the intercom. Do you have a stick mounted push to talk? Make sure it doesn't get to ground anywhere at connects only to the COMMON and PTT terminals on the mic jack.
