		craigb(at)onthenet.com.au Guest
				 Posted: Fri Jul 26, 2013 3:00 pm    Post subject: G Load testing |
				I have seen a few photos on the group over the years with
 a/c inverted and bags of sand, concrete, gold coins etc stacked
 evenly on the wings to simulate the G loading, question is how are
 people supporting the weight for this test through the fuselage itself
 obviously the top of the cockpit would be insufficient to take such a load
 of what 8000+ pounds, assuming 6g x 1370lb, or do I have the math wrong on
 this
 my thoughts were it may be easier to keep the A/C upright and load the
 weight
 into the cockpit with the whole lot supported by cradle and a few extra
 supports under each wing
				 Posted: Sat Jul 27, 2013 12:46 am    Post subject: G Load testing |
				wrong thought Craig. It has to be done the standard way. Design load is 4.5 G (from dilute memory)
 Don't try it without a qualified Inspector, easy to break something.
 Graham
  Sent: Saturday, 27 July 2013, 0:00
  Subject: Europa-List: G Load testing
 -->  Europa-List message posted by: "craig" <craigb(at)onthenet.com.au (craigb(at)onthenet.com.au)>
 this
 weight
 into the cockpit with the whole lot supported by cradle and-> http://forums.matronics.comhttp://www.======================
				 Posted: Sat Jul 27, 2013 2:52 am    Post subject: G Load testing |
				Yes but doesn’t there have to be a 50% safety margin on g load
 After all you could pull nearly 6 g in a turn (80 degrees bank) taking
 Evasive action for example.
 But back to the original question how does one support the a/c adequately for the testing in the inverted
 position
 From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of GRAHAM SINGLETON
  Sent: Saturday, July 27, 2013 6:44 PM
  Subject: Re: G Load testing
  Graham
  Subject: G Load testing
  this
  weight
    	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?Europa-List  | 	  0123456789
  Checked by AVG - www.avg.com
  07/26/13
				 Posted: Sat Jul 27, 2013 4:06 am    Post subject: G Load testing |
				craig a écrit :
 Graig and all,
 The 50 % margin is for calculation only, especially in a homebuilt.
 Contrary to popular belief, the 4.5 g load for instance, is a
 once-in-a-lifetime limit not to be inflicted on the airframe repeatedly.
 Safe load is considered to be approximately 80% of certified load.
  	  | Quote: | 	 		   After all you could pull nearly 6 g in a turn (80 degrees bank) taking
 Any airplane can break in flight if mishandled.
 It would take a really ham fisted pilot to reach as high as 6g.
 Additionally in peacetime I would advise to only perform avoiding
 actions
 Best regards,
 Gilles
 http://contrails.free.fr
