Posted: Sat Jul 27, 2013 4:47 am Post subject: Fuel system revisited |
Fellow RV-10 builders and aviators
Following some recent considerations about the fuel system to adopt in the -10 I am building, I am now thinking in putting the “Red cube” flow meter in the engine compartment, near the mechanical pump, and the filters in the wings roots, leaving only the fuel pump “buried” in the tunnel.
What do you think about the “red cube” near the mechanical pump?
And what about putting the filters (2) in both wing roots? Do you recommend putting filters or gascolators here?
Best regards
Carlos
partner14
Posted: Sat Jul 27, 2013 5:37 am Post subject: Fuel system revisited |
Filters in wings, yes....cube by mechanical, not so good....install it between the servo and spider.Don McDonald
To: <rv10-list(at)matronics.com>;
Subject: Fuel system revisited
Sent: Sat, Jul 27, 2013 12:46:54 PM
Best regards
Carlos
40636 |
Posted: Sat Jul 27, 2013 5:47 am Post subject: Fuel system revisited |
There are a lot of options. I have the filter, fuel pump and flow sender in the tunnel per plans and have no issues. The fuel totalizer is always within half a gallon when I fill up. That said, the most accurate place to put the red cube is between the throttle body and the spider (I did that on my 8A). So if you go away from plans you may as well put it in the best spot. Do not however hard mount it to the engine. For the 8A I enclosed the flow sender in a large fire sleeve. I figured this to be my back up plan for the 10 if the red cube did not work in the tunnel.
I do not find it difficult to service the filter with it mounted in the stock position in the tunnel. On annual you are taking the seats out and tunnel cover off anyway - that's 90% of the effort to get to the fuel filter.
Filers only - there is no value of installing a gascolator in a low wing airplane other than the inherent filter element in the gascolator. Water collects in a gascolator when it is mounted in the lowest spot of the fuel system. With the aircraft parked water slowly gravity drains to that low point. The gascolator provides no mechanical water separation function with flowing fuel. For a low wing airplane you cannot mount the gascolator such that the inlet is below the bottom of the fuel tank. The fuel tank sump is the means to detect and remove water from the tank.
Carl
120 hours
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo
Sent: Saturday, July 27, 2013 8:47 AM
Best regards
Carlos
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
tfarrell839
Joined: 10 Nov 2012 Posts: 27 Location: Watsonville, CA
Posted: Sat Jul 27, 2013 6:26 am Post subject: Fuel system revisited |
I give a 3rd vote for the cube just before spider. Keep it away from pumps when possible. They, sometimes, seem to be affected by the pulsations of the pumps.
On Jul 27, 2013, at 9:46 AM, "Carl Froehlich" <carl.froehlich(at)verizon.net (carl.froehlich(at)verizon.net)> wrote:
[quote] <![endif]--> <![endif]-->
Carl
120 hours
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Carlos Trigo
Subject: RV10-List: Fuel system revisited
Following some recent considerations about the fuel system to adopt in the -10 I am building, I am now thinking in putting the “Red cube� flow meter in the engine compartment, near the mechanical pump, and the filters in the wings roots, leaving only the fuel pump “buried� in the tunnel.
What do you think about the “red cube� near the mechanical pump?
Best regards
Carlos
0123456789
_________________ Tim Farrell
Aircrafters
831-722-9141 |
robin(at)PaintTheWeb.com Guest
Posted: Sat Jul 27, 2013 12:13 pm Post subject: Fuel system revisited |
Check the Archives for photos of Sean’s Red Cube placement between the Servo & Spider.
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Farrell
Sent: Saturday, July 27, 2013 7:26 AM
Subject: Re: RV10-List: Fuel system revisited
Carl
120 hours
Best regards
Carlos
0 1 2 3 4 5
| 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9
Checked by AVG - www.avg.com
Version: 2013.0.3349 / Virus Database: 3204/6516 - Release Date: 07/24/13
