JOHN TIPTON
Joined: 17 Sep 2006 Posts: 239 Location: Torquay - England
Posted: Thu Jul 25, 2013 11:11 pm Post subject: two com radios |
Hi Guys (Bob)
I'd like to fit 2 x radio coms, I don't want or need a full 'audio panel'
what are my options, I guess I really need is some kind of sophisticated
change-over switch
John
bob.verwey(at)gmail.com Guest
Posted: Thu Jul 25, 2013 11:18 pm Post subject: two com radios |
Intercom?
On 26 July 2013 09:07, JOHN TIPTON <jmtipton(at)btopenworld.com (jmtipton(at)btopenworld.com)> wrote:
[quote]--> AeroElectric-List message posted by: "JOHN TIPTON" <jmtipton(at)btopenworld.com (jmtipton(at)btopenworld.com)>
Hi Guys (Bob)
I'd like to fit 2 x radio coms, I don't want or need a full 'audio panel' what are my options, I guess I really need is some kind of sophisticated change-over switch
John
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
le, List Admin.
nuckollsr
Joined: 24 Mar 2009 Posts: 95 Location: Medicine Lodge, KS
Posted: Fri Jul 26, 2013 7:00 am Post subject: Re: two com radios |
There are a number of options. Suggest you review the chapter on audio systems and then come back for necessary clarification on selection of a solution.
toddheffley
Joined: 24 Mar 2010 Posts: 8 Location: Fort Worth Texas
Posted: Sat Jul 27, 2013 10:15 am Post subject: Re: two com radios |
John
I wonder if you have considered an alternative solution to a installed second com?
My experience with hand crafted audio control systems has been 100% negative,,,, meaning poorly thought out, no documentation, making repair a puzzling endeavor.
My favorite set up for a VFR/CrossCountry/LightIFR aircraft is:
ONE com. The best quality you can afford. CI122 antenna on the belly, Meaning a REAL antenna, not just a cheapy 1/4 wave stick, not a internal antenna. Best practices on coax termination and so forth. Carefully think through Bob's well documented Zdiagrams to give the unit the bast chance of rock solid power + some type of Plan B power.
A intercom correctly installed with the direct Mic/Phone jacks wired, as well as the Pilot/Copilot/Pax mic/phone jacks. NAT is my favorite, but that is because I am a snob.
My point is, put most of you eggs in that basket and make that basket FIRST RATE.
Secondly, a backup com system that is a REAL backup.
Meaning, a handheld radio, SOLIDLY afix the panel or side wall. Separate mic and phone jacks wired ONLY to the handheld. A DEDICATED 2nd com antenna hooked directly to the handheld.
FRESH batteries, and/or Fresh spare batteries in the flight bag.
This approach gets rid of the audio panel, a single point of failure, and divides the cost of the second com in half.
I recommend this after YEARS of working on light aircraft with poorly maintained, 2nd rate avionics.
Best wishes for you and your project.
Todd
_________________ WWW.toddheffley.com
www.theinterconnectco.com for lighting products
AV-TS.com for Jet Aircraft Test Equipment |
Posted: Sat Jul 27, 2013 7:36 pm Post subject: two com radios |
At 02:07 AM 7/26/2013, you wrote:
<jmtipton(at)btopenworld.com>
Hi Guys (Bob)
John
Have you considered 1 comm radio and a hand-held?
My flight bag always carried this constellation of
back-ups . . . even when I was flying an A36 with
all the goodies.
http://tinyurl.com/d5mrjgh
The nice thing about this line-up is that it's
totally independent of the airplane's electrical
system no matter which airplane you're flying.
uuccio(at)gmail.com Guest
Posted: Sat Jul 27, 2013 9:46 pm Post subject: two com radios |
On Jul 28, 2013, at 5:35, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> wrote:
all the goodies.
Bob,
With this setup (in your own airplane) would you recommend:
A) connecting the handheld antenna to the aircraft com antenna (if so, how? Dave mentioned in a previous post a that you had a setup specifically designed for that with what sounded like an antenna splitter, but I could not find details on your website)
B) wiring the PTT and Rx/Txs of the handheld through the audio panel as com2 (if there is a simple way to do this, not sure... But the idea would be that the handheld functions exactly like a normal com2).
Sacha
Posted: Sat Jul 27, 2013 9:48 pm Post subject: two com radios |
Sorry I just realized that John does not need/want an audio panel, I didn't mean to high jack the thread...
Posted: Mon Jul 29, 2013 6:10 am Post subject: two com radios |
Todd, thanks for the heads up on an issue I would never have considered from that point of view!
Just wrestling with the whole 2 comms/intercom problem at the moment. You just made it easier!
Bob Verwey
A35 Bonanza ZU-DLW
Safari ZU- AJF
On 27 July 2013 20:15, toddheffley <public(at)toddheffley.com (public(at)toddheffley.com)> wrote:
[quote]--> AeroElectric-List message posted by: "toddheffley" <public(at)toddheffley.com (public(at)toddheffley.com)>
John
Todd
WWW.toddheffley.com
http://forums.matronics.com/viewtopic.php?p=405436#405436
le, List Admin.
