aaaron(at)tvp.com.au Guest
Posted: Wed Jul 31, 2013 5:43 am Post subject: B-lead protection |
I'm finishing the wiring in my safari helicopter and need some advice re B-lead ANL or fuse. I'm using the skytec starter with built in solenoid with about 3 feet of number 2 wire going from the starter to the master contactor. I'm using a tractor style push-button starter switch and an externally regulated 40a alternator. Since I have no external starter contactor, do I need to run the B-lead from the alternator via a fuse to the master contactor or can I run it the much shorter length between the alternator and starter? If the former, I could mount the ANL holder on the firewall but I would have three fat wires (starter, B-lead and main bus) bolted to the master contactor. If I can just connect the alternator to the starter lead I can use an inline fuse holder. My questions are:
1. Where do I put the B-lead and fuse/ANL?
2. What size wire for the B-lead?
3. What size fuse/ANL?
4. Do I need to put a diode across the starter button and if so, which one and in what direction?
Thanks!
Allan
Posted: Wed Jul 31, 2013 6:49 am Post subject: B-lead protection |
At 08:42 AM 7/31/2013, you wrote:
#2 is possibly overkill, #4 would certainly suffice
for your battery/starter wiring.
| Quote: | Since I have no external starter contactor, do I need to run the B-lead
Take it to the starter.
| Quote: | 1. Where do I put the B-lead and fuse/ANL?
As close as practical to the starter but if
the fuse ends up in the middle of the wire run,
it's no big deal.
| Quote: | 2. What size wire for the B-lead?
8AWG is fine for 40A alternator.
| Quote: | 3. What size fuse/ANL?
I see Walmart is offering this fuse
in a 30A, which is plenty robust for
your alternator.
http://tinyurl.com/l6qbxsc
This is a miniature fuse for which you
can fabricate your own holder from a piece
of phenolic and some screws, nuts and washers
from the hardware store.
| Quote: | 4. Do I need to put a diode across the starter button
Not ACROSS the button but from contactor side
of button to ground. Cathode connected to pushbutton,
anode to ground. Any of the 1N5400 series diodes
from Radio Shack are find. See:
http://tinyurl.com/l65nqnw
There was an AD issued against the ACS key-switch
some years back that put a diode across the switch . . .
completely ineffective.
Diode needs to wire across
the solenoid coil either at the switch as described
or on the contactor (probably not as convenient but
if you can put it there, that's good too.)
Posted: Wed Jul 31, 2013 12:11 pm Post subject: B-lead protection |
3. What size fuse/ANL? |
Here's a 40A MIDI style stocked by Digikey
http://tinyurl.com/mpudgxu
and a holder like this
[img]cid:7.1.0.9.0.20130731150249.020c51e0(at)aeroelectric.com.0[/img]
To mount it can be found here . . .
http://tinyurl.com/kcbyc79
47.84 KB |
6386 Time(s) |
donjohnston
