johnelling
Posted: Fri Aug 02, 2013 8:00 am Post subject: Trouble starting a 912 ULS |
Folks,
I've gradually had trouble starting a ULS with the 912 Rotax high torque
starter. First it did not like starting when it was cold. Then the
sprag seemed to come disengaged without turning the engine over enough
to start. Finally I started getting a gear-grinding noise. Then
eventually the gears never engaged; just a grinding noise.
I checked the starter alignment between the two ears for the bolts.
Perhaps a 0.010" difference between the gaps of the two ears and no way
to adjust that I could see since the ears of the starter flange are
threaded as are the bolt holes on the engine.
I removed the Rotax starter and found the gear surface was a little
rough as was the mating gear teeth inside the engine. Probably from the
grinding... I replaced the starter with a Skytec, aligned as best I
could to exactly the same position as the Rotax starter (off about
0.010" between the top and bottom ears of the starter flange and the
engine surface). The Skytec starter does exactly the same thing -
grinds the gears without really engaging.
Anyone have any ideas? Anything I should check before I start taking
apart the engine to get to the starter gears and clutch?
John
| - The Matronics RotaxEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
johnelling
Posted: Fri Aug 02, 2013 9:08 am Post subject: Trouble starting a 912 ULS |
Folks,
One more data point on the trouble starting: It is not the battery
current. I've connected a truck battery in parallel with the plane's
battery (so the ignition is switching more amps) and not solved the problem.
John
Posted: Fri Aug 02, 2013 1:43 pm Post subject: Trouble starting a 912 ULS |
Hi! John,
Where is your battery situated ? How far from the starter ? I had untold
problems with the Jabiru 3300 six cylinder until I put two Odessey 13Ah
batteries in parallel within 18" of the starter and used welding cables for
the leads.
Bingo not so much as a problem since.
Bob Harrison G-PTAG Europa now with 914 Rotax.
BARRY CHECK 6
Posted: Sat Aug 03, 2013 2:30 am Post subject: Trouble starting a 912 ULS |
John:
1 - What does the gear engagement points look like? If the gears are too new to show ware take some blue Dykem and coat the ring gear teeth and the starter gear teeth. Then try starting. You will have wear marks showing the gear contact - If they are not straight and even from face to face you have an alignment issue.
2 - If the gears are not engaging - Could the mounting system be totally incorrect? Am I to assume at one point and for a long time there were NO starting issues? If so... What changed?
3 - Any hard landings?
Barry
On Fri, Aug 2, 2013 at 12:00 PM, John Elling <jelling(at)newmexico.com (jelling(at)newmexico.com)> wrote:
[quote]--> RotaxEngines-List message posted by: John Elling <jelling(at)newmexico.com (jelling(at)newmexico.com)>
Folks,
I've gradually had trouble starting a ULS with the 912 Rotax high torque starter. First it did not like starting when it was cold. Then the sprag seemed to come disengaged without turning the engine over enough to start. Finally I started getting a gear-grinding noise. Then eventually the gears never engaged; just a grinding noise.
I checked the starter alignment between the two ears for the bolts. Perhaps a 0.010" difference between the gaps of the two ears and no way to adjust that I could see since the ears of the starter flange are threaded as are the bolt holes on the engine.
I removed the Rotax starter and found the gear surface was a little rough as was the mating gear teeth inside the engine. Probably from the grinding... I replaced the starter with a Skytec, aligned as best I could to exactly the same position as the Rotax starter (off about 0.010" between the top and bottom ears of the starter flange and the engine surface). The Skytec starter does exactly the same thing - grinds the gears without really engaging.
Anyone have any ideas? Anything I should check before I start taking apart the engine to get to the starter gears and clutch?
John
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
http://forums.matronics.com
le, List Admin.
Roger Lee
Posted: Sat Aug 03, 2013 3:27 pm Post subject: Re: Trouble starting a 912 ULS |
It sounds like you may have lost your sprag clutch that engages the engine with the starter then releases as soon as the engine speeds past the starter rpm.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
