bgreen(at)bimi.org Guest
Posted: Wed Aug 07, 2013 10:42 am Post subject: Kolb-List Digest: 4 Msgs - 08/06/13 |
Rick:
Where do you order these press fit bushings?
Thanks.
Bob
George
The press fit bushings are ultralight/light plane standard fuel fittings
They are inserted into a hole in plastic fuel tanks. They are a fuel proof
rubber like material. After they are inserted a metal fuel fitting is
pressed into the bushing which locks the bushing in place and makes the
assembly highly leak resistant. They do require that the proper sized hole
is drilled, that is the hole is carefully debured, and the fuel fitting is
lightly lubricated when it is installed.
Rick Neilsen
Redrive VW Powered MKIIIC
zeprep251(at)aol.com Guest
Posted: Wed Aug 07, 2013 4:13 pm Post subject: Kolb-List Digest: 4 Msgs - 08/06/13 |
Bob
JBM has them.Buy them on line,get them in 2-3 days
neilsenrm(at)gmail.com Guest
Posted: Thu Aug 08, 2013 5:09 am Post subject: Kolb-List Digest: 4 Msgs - 08/06/13 |
Bob
Also Kolb, Aircraft Spruce, or any of the ultralight parts venders.
Rick Neilsen
On Wed, Aug 7, 2013 at 8:13 PM, Gary Aman <zeprep251(at)aol.com (zeprep251(at)aol.com)> wrote:
[quote]Bob
