paul.r.kuntz(at)gmail.com Guest
Posted: Thu Aug 08, 2013 8:48 pm Post subject: Rotax 912 UL alternator drop-out |
I have a homebuilt Pipistrel Sinus with a Rotax 912 UL that I flew to Oshkosh and back last week. The panel has a dual Dynon Skyview display with two-axis autopilot, plus radio and transponder. The total electrical load with everything running is 7 to 8 amps. Occasionally it can go to 9 or 10 amps if I'm charging cell phone and iPad en route. I'm pretty confident that I have the electrical system wired so that the ammeter is measuring the total electrical load.
The alternator dropped out once on the outbound trip, but came back after removing the iPad charging load. The symptom was a voltage drop from 13.8 volts to 12.5 volts, which seemed strange. On preflight the voltage may read that high for a minute or so on a freshly-charged battery, but it quickly drops to 12.2 or 12.1 volts. In flight, the voltage would drop to 12.5 volts and stay there for several minutes. I would think that if the alternator had failed, I'd see the voltage drop to the same 12.1 volts that I see on preflight, and keep dropping slowly. I can't see why it would drop to 12.5 volts and stay there, unless the voltage regulator is failing in a way that I'm not familiar with.
The alternator dropped out (same symptoms) a few times on the trip back, but by reducing the load to 3 amps (one Skyview display, radio and transponder), it stayed on line except for awhile when it seemed that the mid-day sun shining on the dashboard was adding extra heat behind the panel. That time we brought it back by directing cool air from a fresh air vent forward toward the spot where the voltage regulator is mounted inside the cabin on the back side of the firewall.
So the problem seems to be heat-related. Does this make sense? The Rotax alternator is supposed to be rated for 18 amps, and able to handle a steady load of 14 amps easily. Does the Ducati regulator have a thermal self-protect cutout? Do I perhaps have a regulator that is ready to fail completely, or should I just put an avionics cooling fan behind the panel to get the air moving?Any other ideas?
Paul Kuntz
Joined: 28 Mar 2008 Posts: 1938 Location: Riley TWP Michigan
Posted: Fri Aug 09, 2013 4:10 am Post subject: Re: Rotax 912 UL alternator drop-out |
I have a RV-12 with Rotax 912 engine. The voltage regulator can be damaged by excessive heat. A fan that circulates warm air might not be enough.
Van's Aircraft sells an aluminum shroud that is pop riveted to the fins of the voltage regulator.
Cooling Shroud part number F-00002 $10.
Blast Tube "DUCT CBT-5/8" connects to the Cooling Shroud. $3.95 per foot.
http://www.vansaircraft.com/cgi-bin/store.cgi
See page 40-14 of this document for installation instructions:
http://www.vansaircraft.com/pdf/revisions/RV-12/Section_40.pdf
Joe
_________________ Joe Gores |
Posted: Fri Aug 09, 2013 9:56 am Post subject: Rotax 912 UL alternator drop-out |
Thanks for the tip. I'll check this cooling shroud idea. I'm also wondering if my regulator has already been compromised. Any opinions on what my repeated fail/recover situation indicates? I would guess that it cycled between failed and recovered 8 or 10 times before we established a state where it stayed on line, limited to a total current draw of 3 amps.
Paul
On Friday, August 9, 2013, user9253 wrote:
[quote]--> AeroElectric-List message posted by: "user9253" <[url=javascript:;]fransew(at)gmail.com[/url]>
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=406294#406294
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
le, List Admin.
klehman(at)albedo.net Guest
Posted: Fri Aug 09, 2013 1:05 pm Post subject: Rotax 912 UL alternator drop-out |
Paul
I would consider 12.5 volts to be a no charging situation but like you
I'd also expect it to slowly drop further.
Your 13.8 volts is also pretty low to reasonably recharge a battery
unless perhaps you are frequently flying long trips in hot temperatures.
If you believe your voltmeter to be accurate, I'd indeed suggest a new
regulator however the intermittent nature of the fluctuations could also
indicate a poor connection.
The John Deere PM regulator is rated at 20 amps and has served me well
(with a 20 amp alternator) on the cabin side of the firewall although
mine is mounted on a bracket about a half inch from the firewall to let
air circulate under it. I am not familiar with the rotax regulator but I
would consider a unit that needs air blast on it in the cabin to be way
too marginal for reliable service.
Ken
On 09/08/2013 12:46 AM, Paul Kuntz wrote:
Quote: | I have a homebuilt Pipistrel Sinus with a Rotax 912 UL that I flew to
Paul Kuntz
pestar
Joined: 11 Apr 2007 Posts: 61 Location: Auckland, New Zealand
Posted: Fri Aug 09, 2013 3:12 pm Post subject: Rotax 912 UL alternator drop-out |
electrical load.
Batteries charge at 13.8 and above, they deliver energy
at 12.5 and below. Regulators are set to charge batteries
so a functioning alternator produces a bus voltage generally
above 14.0 volts.
How long has this regulator been in service? 10A is
a pretty light load for a 912 regulator. I suspect
something has become intermittent.
Posted: Fri Aug 09, 2013 4:26 pm Post subject: Rotax 912 UL alternator drop-out |
At 05:38 PM 8/9/2013, you wrote:
Quote: |
I own a French DynAero MCR-4S Rotax 914 which I part built in France
prior to shipping back to New Zealand. During this time I learnt
that the standard Ducatti regulator was unreliable and so I never
fitted it. I replaced it with a GR6 Schicke electrical regulator
which is an approved LAA mode in the UK for Rotax engines..
This regulator is a lot more robust and eliminates the flakey
issues you may be experiencing. Mine is mounted under the co-pilots
seat uncooled.
Thanks for the heads-up Peter. I've heard a lot
of complaints about the Ducatti regulators.
There are certainly many examples of the technology
with opportunity to out-perform the Ducatti product,
Schicke and John Deere being amongst those that
should be considered.
Posted: Fri Aug 09, 2013 4:29 pm Post subject: Rotax 912 UL alternator drop-out |
At 12:55 PM 8/9/2013, you wrote:
Quote: | Thanks for the tip. I'll check this cooling shroud idea. I'm also
If your regulator can't carry 10A without cooling, it's
probably broke. A functional part should be capable of
rated output for the alternator which is on the order
of 18A. I've not heard of any mass-movements to forced
air cool these regulators.
Posted: Sat Aug 10, 2013 9:22 pm Post subject: Rotax 912 UL alternator drop-out |
Thanks for the tips, everyone. I concur with Bob that my Ducati regulator is done for and should be replaced. I will take a look at the Schicke unit that Peter mentioned.
Paul Kuntz
On Friday, August 9, 2013, Robert L. Nuckolls, III wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
Quote: | Thanks for the tip. I'll check this cooling shroud idea. I'm also wondering if my regulator has already been compromised. Any opinions on what my repeated fail/recover situation indicates? I would guess that it cycled between failed and recovered 8 or 10 times before we established a state where it stayed on line, limited to a total current draw of 3 amps.
le, List Admin.
Posted: Sat Aug 10, 2013 10:53 pm Post subject: Rotax 912 UL alternator drop-out |
The plane has a total of 75 hrs; ditto the engine and electrical system, so it's all basically brand new. The system voltage has always read 13.8 or 13.9 volts when the engine is running at normal flight RPMs, except for the drop-out periods I've described. It may drop below 13 volts at low RPM on the ground, but I believe that's normal.
I've never seen the load go above 12 amps. 9 or 10 amps seems like the normal load with everything running. It's perhaps 2 amps less with the autopilot disengaged.
The voltage regulator is on the cabin side of the firewall, mounted on a fairly large metal plate that stands off from the firewall about three-fourths of an inch. The firewall is composite with an insulating asbestos (or similar) fire-resistant blanket on the engine side. The cabin side never gets more than warm to the touch. I agree with the replies that say the Ducati regulator should handle both the load and the environment fine with no additional forced air flow. After reviewing all the replies, I'm inclined to just install a new one and see how it goes before I try to make changes to the system design, such as switching to a different regulator. Seems like there should be plenty of head room in the existing system.
Paul Kuntz
above 14.0 volts.
le, List Admin.
Posted: Sun Aug 11, 2013 4:06 am Post subject: Re: Rotax 912 UL alternator drop-out |
Since the problem is intermittent, it is more likely caused by a loose connection rather than bad electronics. Prime suspect is the circuit going to voltage regulator pin "C", especially the controlling switch (Master ?) and wire terminals.
It would be a worthwhile test to monitor the voltage on pin "C" during alternator failure.
Joe
Posted: Sun Aug 11, 2013 6:35 am Post subject: Rotax 912 UL alternator drop-out |
Joe brings up a good point. Intermittent failures
are more likely to be a loose connection as opposed
to a misbehaving piece of electronics. The Ducatti
regulators are potted, mechanically robust.
Doing a study of ship's wiring integrity might save
you from an unnecessary regulator change out.
Bob McC
Posted: Sun Aug 11, 2013 7:17 am Post subject: Rotax 912 UL alternator drop-out |
This is especially true since your observed "full charging voltage" seems to
have always been a tad low. (max 13.9 volts when it would normally be
expected to be 14 or greater)
This may also be indicative of a loose connection creating high resistance
and "fooling" the regulator right from the start. It may have never been
working optimally.
Bob McC.
_________________ Bob McC
Falco #908
(just starting) |
Posted: Sun Aug 11, 2013 8:53 am Post subject: Rotax 912 UL alternator drop-out |
At 10:16 AM 8/11/2013, you wrote:
Quote: |
<robert.mccallum2(at)sympatico.ca>
My recollection is that this series of regulators
tend to run low in the spectrum of battery recharge
protocols. My hypothesis is that the regulator is
intended for use on consumer tools like garden tractors,
machines that get used frequently in-season if not all
year long. Consumers are not looking for optimum
performance of a battery as an energy source, only
long service life for engine cranking. So the low-end
design point would tend toward that goal.
Adding a voltage adjust pot would be pretty cool,
but fraught with risk in the hands of the weekend,
shade tree mechanic . . . so I think the Ducatti
regulators are what they are for well considered
reasons.
Selection of this regulator by Rotax for use on an
aircraft may be not so well reasoned.
( -Thomas Paine 1776- )
Posted: Sun Aug 11, 2013 8:58 am Post subject: Re: Rotax 912 UL alternator drop-out |
My Rotax voltage regulator also puts out 13.8 volts. And so do others according to RV-12 owners that I have talked with. The Rotax engine starts so quickly, usually within a couple of seconds, that the battery is never discharged. Most of the time the regulator only needs to maintain the battery, not recharge it.
Joe
rickofudall
Posted: Sun Aug 11, 2013 3:31 pm Post subject: Rotax 912 UL alternator drop-out |
Bob, Or it may be that Ducati has a little of the Lucas bloodline.Let me tell you about my experience with another Ducati product used by Rotax. The ignition module used from approx 2005 until 2011, Rotax p/n 966726. It has a known failure in which it just stops firing at engine cranking speeds, but will fire at some elevated rpm. Once it is made to fire the module often resumes working properly for the rest of that day but when it is allowed to rest for a few days it resumes the high rpm firing. Case in point, a customers engine of that vintage that refused to start. We had already corrected a series of carburetor and fuel system issues and the engine still refused to start. I eliminated every possibility of ignition modules being grounded out, then removed them and contacted Lockwood Aviation. The customer sent the modules in and sure enough, on Lockwoods test stand they would not fire below 2000 rpm. Once that was reached the modules worked correctly then failed again in later tests.
Rotax is offering owners of these modules a reduced price on the latest version, p/n 966727. This new module also offers a 'soft start' capability with a timed ignition retard to help the higher compression 912 ULS and S models start easier.
Rick Girard
On Sun, Aug 11, 2013 at 11:52 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Quote: | --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Quote: | --> AeroElectric-List message posted by: Bob McCallum <robert.mccallum2(at)sympatico.ca (robert.mccallum2(at)sympatico.ca)>
reasons.
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Posted: Sun Aug 11, 2013 6:59 pm Post subject: Rotax 912 UL alternator drop-out |
At 06:29 PM 8/11/2013, you wrote:
Quote: | Bob, Or it may be that Ducati has a little of the Lucas bloodline.
Rick Girard
Interesting. I'm a little mystified by such stories.
Seems to me robust electronics really isn't a difficult
thing to do once you've set up design goals, written
a test plan for performance issues critical to
intended operation and then test and deliver to
those issues.
It's a cut-n-dried process; second nature for
me and most of the electron-herders I've
worked with. The fact that Rotax continues to ship
a marginally adequate rectifier/regulator is also
a puzzlement. I had a conversation with a system
integrator a few weeks ago wherein he was wrestling
with a constellation of noise generating components
supplied with a new, fuel injected Rotax. The engine's
fundamentals seem sound and of good value, yet the
company persists in artificially crippling a good
product with flaky accessories.
It would be interesting to be a fly on the wall in
some of their customer relations meetings that deal
with reported field problems. I guess that presupposes
that such meetings are even held.
It would be VERY interesting to see a schematic
and bill of materials for the problematic ignition
module . . . and know how the design was changed
to correct the problem! But it sounds like the
recommended replacement wasn't a corrected design
but a product with new features . . . while being
free of the low rpm problems of the previous
design. We'll never know . . .
rickofudall
Posted: Sun Aug 18, 2013 5:56 pm Post subject: Rotax 912 UL alternator drop-out |
Paul, As an aside, if your Pipistrel is certificated as an SLSA you must get a Letter of Authorization from the factory to make any changes to the aircraft. If you don't, your airplane airplane's certificate of compliance becomes void. If the factory won't give you a letter, your only option is to remove the change or take the aircraft ELSA.
Rick Girard
On Sun, Aug 18, 2013 at 10:57 AM, Paul Kuntz <paul.r.kuntz(at)gmail.com (paul.r.kuntz(at)gmail.com)> wrote:
Quote: | Several inputs suggested checking the connections on the leads coming from the alternator, and checking the system ground connections. I checked the faston-type alternator lead connections, which were clean and tight. I checked all of the ground connections, which were also tight. Yesterday I went up for a test flight and confirmed the symptoms under varying system loads. The normal system voltage with alternator on line is 13.8 volts, which is consistent with what others are reporting for the Rotax Ducati regulator. I see a max load of 10 amps with everything running, so I am satisfied that the total load is well within the standard Rotax system capacity. I also observed that the system voltage drops to 13.5 volts at the 10 amp max load, which seems abnormal. Under this max load, the alternator dropped out after a few minutes, indicated by system voltage dropping to around 12.5 volts -- consistent with fully charged lead-acid battery.
When I reduced the load to 3 amps, which is my practical minimum (one Dynon display, radio and transponder), the alternator came back and stayed there, with system voltage at the normal regulator set point of 13.8 volts.
I repeated this experiment a few times for various loads, finding that a total load above 5 or 6 amps will cause the alternator to drop out after a few minutes, and that it will come back when the load is reduced to 3 amps.
I am pretty well convinced that my voltage regulator is bad. I did learn from comments on this issue that Van's includes a voltage regulator cooling kit with its lighting kit for the RV-12, consisting of a length of plastic tubing that connects from the air intake duct to a shroud over the regulator, providing a direct blast of cooling air to counteract the increased electrical load of the lighting. So there is certainly indication that the Ducati regulator is susceptible to overheating under load. The RV-12 regulator is on the engine side of the firewall, however, and mine is on the cabin side. At 10 amps with the regulator mounted in the cockpit environment, I'm thinking the regulator should be able to handle the load without supplemental cooling. Others have noted the not-so-good reputation of the Ducati regulator, but there are thousands of them in service on Rotax engines worldwide, so rather than tackle a reconfiguration of my regulator and wiring installation at this point , I ordered a replacement Ducati from Lockwood Aviation and will see how it goes. I also ordered a overvoltage protection module from B&C, since the Pipistrel electrical system does not include one. I'll install it with the new voltage regulator.
I'll report my findings after installing the new regulator.
Paul Kuntz
On Sat, Aug 10, 2013 at 10:21 PM, Paul Kuntz <paul.r.kuntz(at)gmail.com (paul.r.kuntz(at)gmail.com)> wrote:
Quote: | Thanks for the tips, everyone. I concur with Bob that my Ducati regulator is done for and should be replaced. I will take a look at the Schicke unit that Peter mentioned.
Paul Kuntz
Quote: | --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Posted: Sun Aug 18, 2013 8:03 pm Post subject: Rotax 912 UL alternator drop-out |
Correct, Rick, but mine is built from a kit and licensed as Experimental Amateur-Built, so I am not bound by the SLSA restrictions. That's one of the main reasons I wanted to go the EAB route.
Paul
On Sun, Aug 18, 2013 at 6:54 PM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
[quote]Paul, As an aside, if your Pipistrel is certificated as an SLSA you must get a Letter of Authorization from the factory to make any changes to the aircraft. If you don't, your airplane airplane's certificate of compliance becomes void. If the factory won't give you a letter, your only option is to remove the change or take the aircraft ELSA.
Rick Girard
Paul Kuntz
Paul Kuntz
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
| [b]
Posted: Mon Aug 19, 2013 6:52 pm Post subject: Rotax 912 UL alternator drop-out |
Quote: | I see a max load of 10 amps with everything running, so I am
The symptoms you observed suggest a temperature sensitive
failure mode within the regulator . . . like a connection
that opens when the regulator warms up. While a cooling
system MIGHT mask this failure, it wouldn't necessarily
be a case of overheating beyond rated operating temperatures
rather a case of an intermittent connection that is
temperature sensitive.
