stopping engine in flight
davidjoyce(at)doctors.org
PostPosted: Mon Aug 12, 2013 1:05 am    Post subject: stopping engine in flight Reply with quote
Some time ago there was some discussion about stopping &
restarting the engine in flight. Yesterday I was
experimenting with this in order to research glide angles
with engine idling and actually stopped. I was frustrated
in this because with the ignition off my prop continued to
windmill with the speed pulled right back to 50kts. This
is with a Rotax 914 and a Woodcomp SR3000W, and I guess it
is because this prop offers appreciably more blade area
than say Warp drive blades. For what it is worth the
engine fired up again immediately on switching the
ignition back on without needing the starter.
Regards, David Joyce, G-XSDJ
rparigoris
PostPosted: Mon Aug 12, 2013 2:36 am    Post subject: Re: stopping engine in flight Reply with quote
Hi David
"I was frustrated in this because with the ignition off my prop continued to windmill with the speed pulled right back to 50kts."
I owned a 1948 Cessna 170 rag-wing for 19 years. I would regularity stop the prop and go gliding.
Some of the time when the sea breeze was working well on Long Island you could maintain with the prop windmilling, but if you managed to stop the prop you could climb. I used a strap on your wrist Ball variometer.
Once you managed to get things stopped, L/D went up and sink rate went down.
Anyway to stop the fixed pitch prop on my Continental C-145 (very close to O-300) 6 cylinder, I would need to use full flaps and do a semi aggressive stall. Not a whip stall, but not a slowly pull stick in your lap either. This was especially necessary if not solo with light fuel.
Remember the ragwing 170 had hinged flaps the same size as the 120, and they didn't work very well on the 120.
Anyway, did you try full flap stall solo with light fuel to get things stopped?
Ron Parigoris
Roland
PostPosted: Mon Aug 12, 2013 5:12 am    Post subject: Re: stopping engine in flight Reply with quote
Sorry David, if this might be an "odd" question, but did you also try to feather the Prop? I don't know if this is possible with the Woodcomp.
Roland
XS Trigear 914 (Airmaster Prop)
nigel_graham(at)m-tecque.
PostPosted: Mon Aug 12, 2013 5:37 am    Post subject: stopping engine in flight Reply with quote
David,
Don't forget that at 9.0:1, the 914 has a lot less compression than the
912s (10.5:1). Combine that with your large blade area and it's not
surprising that it windmills easily.
Nigel
On 12/08/2013 10:04, David Joyce wrote:
<davidjoyce(at)doctors.org.uk>
Some time ago there was some discussion about stopping & restarting
the engine in flight. Yesterday I was experimenting with this in order
to research glide angles with engine idling and actually stopped. I
to windmill with the speed pulled right back to 50kts. This is with a
Rotax 914 and a Woodcomp SR3000W, and I guess it is because this prop
offers appreciably more blade area than say Warp drive blades. For
what it is worth the engine fired up again immediately on switching
the ignition back on without needing the starter.
PostPosted: Mon Aug 12, 2013 6:15 am    Post subject: stopping engine in flight Reply with quote
Roland, I do not have a feathering prop so no. And as I
was researching how to cope with an EFTO, doing a flaps
down stall didn't really fit either.
Regards, David
On Mon, 12 Aug 2013 06:12:38 -0700
Roland
http://forums.matronics.com/viewtopic.php?p=406499#406499
Un/Subscription,
Forums!
Admin.
Fred Klein
PostPosted: Mon Aug 12, 2013 6:54 am    Post subject: stopping engine in flight Reply with quote
On Aug 12, 2013, at 2:04 AM, David Joyce wrote:
Yesterday I was experimenting with this in order to research glide angles with engine idling and actually stopped. I was frustrated in this because with the ignition off my prop continued to windmill with the speed pulled right back to 50kts. This is with a Rotax 914 and a Woodcomp SR3000W
David...can we presume that the SR3000W controller does NOT have a full-feathering position?
F.
Alan Carter
PostPosted: Mon Aug 12, 2013 6:56 am    Post subject: Re: stopping engine in flight Reply with quote
Ow Boy , shouldn't say this. Use to stop the prop on the old Grumman AA,s
Restart engine in dive, and do 1/2 hours free flying, with the taco stopped, it was many years ago.
C150 loops well with the pro stopped, Confessions of a QFI
PostPosted: Mon Aug 12, 2013 7:00 am    Post subject: stopping engine in flight Reply with quote
Fred, You can buy them with full feathering or indeed with
reverse thrust, but I have just the standard one. Regards,
David
On Mon, 12 Aug 2013 07:54:02 -0700
>a Woodcomp SR3000W
F.
peterz(at)zutrasoft.com
PostPosted: Mon Aug 12, 2013 7:12 am    Post subject: stopping engine in flight Reply with quote
wow...you could get a draggy 150 to climb over the top without any thrust?   Must have been quite a dive ....... & sight!
On Mon, Aug 12, 2013 at 10:56 AM, Alan Carter <alancarteresq(at)onetel.net (alancarteresq(at)onetel.net)> wrote:
[quote]--> Europa-List message posted by: "Alan Carter" <alancarteresq(at)onetel.net (alancarteresq(at)onetel.net)>
http://forums.matronics.com/viewtopic.php?p=406516#406516
target="_blank">http://www.matronics.com/Navigator?Europa-List
le, List Admin.
Fred Klein
PostPosted: Mon Aug 12, 2013 7:23 am    Post subject: stopping engine in flight Reply with quote
Aha...so, if I'm understanding your concerns correctly, the sticky dilemma is the realization that in the event of an engine shutdown, your range to an emergency landing will be sharply limited w/ a forward speed of only 50 kts....?... What was your sink rate and estimated L/D in this configuration?
F.
On Aug 12, 2013, at 7:59 AM, David Joyce wrote:
Fred, You can buy them with full feathering or indeed with reverse thrust, but I have just the standard one. Regards, David
F.
Alan Carter
PostPosted: Mon Aug 12, 2013 7:57 am    Post subject: Re: stopping engine in flight Reply with quote
No Standard entry speed difficult to keep the the prop from windmilling at high speed , prop stopped ,during pull up prop windmills drag goes up ,the speed decay,s away prop stops, Plane judders and shakes as it goes over the top, then the prop goes into windmill on the pull out,
A real work horse is the Cessna 150, draggy slow, but a strong old bird.
Alan
pete(at)lawless.info
PostPosted: Mon Aug 12, 2013 9:15 am    Post subject: stopping engine in flight Reply with quote
Hi David
Was the prop full fine? I had understood that the constant speed units
would run the prop full fine in the event of engine stoppage. If it was be
worth trying manually setting full course and see if it makes a difference.
Pete G-RMAC
PostPosted: Mon Aug 12, 2013 10:48 am    Post subject: stopping engine in flight Reply with quote
Fred, All will be revealed in due course in the Europa
Flyer, but I was slowing in the hope of stopping the
engine rotating. It will glide nicely at 1:12 with the
engine idling, at 70kts, but I suspect it would go
slightly better with the prop stopped
Regards, David
On Mon, 12 Aug 2013 08:23:09 -0700
F.
>Regards, David
>>>a Woodcomp SR3000W
>> F.
Gary.Leinberger(at)miller
PostPosted: Fri Aug 16, 2013 10:47 am    Post subject: stopping engine in flight Reply with quote
I have a Tri-Gear 912S Europa. As part of the requirement for my Motor Glider endorsement (US) I had to feather the prop, stop the engine and do some gliding. I have a three bladed Airmaster Prop with the feather option. With the short wings and the engine off, prop feathered, I show about 600 fpm down with no thermal activity. (I was at about 6000 feet, above the tops of the cumulus clouds in the area so I haven’t tried this in a thermal yet.) Plane is a bit heavy (full IFR) and I am a proper sized American – 265 lbs. And I had an instructor on board. So a lighter plane (and pilot) may do better. Should have the long wings done soon (I have given up on estimating completion dates) and will provide some better info on soaring then.
The 912S is a high compression engine, unlike the 912 and 914. So the prop will stop when the ignition is off even if not feathered. It is also hard to start by diving alone although I have heard that a serious dive will finally get the prop wind-milling high enough for a start – I think you need at least 300 + rpm to get a charge out of the ignition system. For mine a slight dive (100 knots) will start to move the blades a bit, and a mere touch of the starter lights it off.
The feathering and un-feathering takes a bit of time – which I imagine will seem even longer if you wait too long when running out of lift.
Gary Leinberger
Lancaster, Pa.
N388SG
PostPosted: Fri Aug 16, 2013 11:11 am    Post subject: stopping engine in flight Reply with quote
Gary, Do you have a prop windmilling figure to compare it
with? Regards, David Joyce, G- XSDJ
On Fri, 16 Aug 2013 14:47:07 -0400
Gary Leinberger <Gary.Leinberger(at)millersville.edu>
the cumulus clouds in the area so I haven't tried this in
a proper sized American - 265 lbs. And I had an
- I think you need at least 300 + rpm to get a charge
The feathering and un-feathering takes a bit of time -
Gary Leinberger
Lancaster, Pa.
N388SG
terrys(at)cisco.com
PostPosted: Fri Aug 16, 2013 12:19 pm    Post subject: stopping engine in flight Reply with quote
Hi Gary,
We have a Europa XS with a 912S and Airmaster prop and long wings. We were interested in two important questions; when will it stop wind milling, and when will it do an air restart (in case we run the battery dead flying around with the alternator not charging). We found the stop wind milling speed to be around 50 kts, and the air restart at around 110 kts. These seemed near perfect speeds, by our reckoning.
BTW, we got a glide ratio of about 23:1 initially, but got up to almost 26:1 by;
1) adding a cowl flap to the bottom of the cowl (behind the radiators).
2) adding fairings to the non-retractable outrigger legs.
regards,
Terry
________________________________________
From: owner-europa-list-server(at)matronics.com [owner-europa-list-server(at)matronics.com] on behalf of Gary Leinberger [Gary.Leinberger(at)millersville.edu]
Sent: Friday, August 16, 2013 11:47 AM
To: 'europa-list(at)matronics.com'
Subject: Re: stopping engine in flight
Gary Leinberger
Lancaster, Pa.
N388SG
iancook_1(at)btinternet.c
PostPosted: Fri Aug 16, 2013 12:40 pm    Post subject: stopping engine in flight Reply with quote
Terry,
We have just finished the spinning trials in my mono motor glider
after two years of trying to satisfy the LAA (UK) requirements to get a
Permit to Fly, so was very interested in your comments, especially about
blocking of the cooling ducts to improve the LD ratio, do you have any
further details that you can make available? I had the company (Europa) fit
small wing tip wheels to my wings so I can take the outriggers off
completely if I want to go wave flying. Is your machine a mono or Tri-gear?
Best Regards
Ian Cook
G-CBHI
terrys(at)cisco.com
PostPosted: Fri Aug 16, 2013 4:17 pm    Post subject: stopping engine in flight Reply with quote
We have a mono-wheel. I will see if I have some pics of the cowl flap later on. We used narrow roller blade wheels on the outriggers and fitted aerodynamic fairings to the outrigger legs, using hot wire cut blue foam and shrink sleeve to hold it in place.
regards,
Terry
From: owner-europa-list-server(at)matronics.com [owner-europa-list-server(at)matronics.com] on behalf of Ian Cook [iancook_1(at)btinternet.com]
Sent: Friday, August 16, 2013 1:40 PM
Subject: RE: Re: stopping engine in flight
Terry,
Best Regards
Ian Cook
G-CBHI
Fred Klein
PostPosted: Fri Aug 16, 2013 4:59 pm    Post subject: stopping engine in flight Reply with quote
Very clever Terry...Fred
