Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Tue Aug 13, 2013 10:14 am Post subject: Jabiru 3300 CHT Disparity |
Also posted in Zenith 601 section
I attended a forum at Oshkosh where a fellow discussed his research on cooling a Jabiru 3300. He had compared the spark plug washer type CHT sensors to ones directly in the head and showed that they pretty consistently indicated CHT's about 70° cooler than actual temperatures! If this is the case, Jab operators could be cooking their engines while thinking that their CHT's were within safe limits. He ended up designing a cooling baffling system that is nothing like what comes from the factory and claimed that was the only way he was able to get the CHT's under control.
I wonder what the rest of you Jabiru 3300 operators have to say about this? I'm not flying mine yet but will be getting ready to hang it soon.
For a summary on the fellow who made the presentation check out http://www.eaaapps.org/presenterinfo.aspx?id=1973
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
jabfox(at)hotmail.com Guest
Posted: Tue Aug 13, 2013 10:36 am Post subject: Jabiru 3300 CHT Disparity |
I was there also, that guy was trying to reinvent the wheel
> Subject: Jabiru 3300 CHT Disparity
| Quote: | From: timjuhl(at)frontier.com
Date: Tue, 13 Aug 2013 11:14:04 -0700
To: jabiruengine-list(at)matronics.com
--> JabiruEngine-List message posted by: "Tim Juhl" <timjuhl(at)frontier.com>
______________
CFII
Champ L16A flying
Wing modifications done - back working on the fuselage
http://forums.matronics.com/viewtopic.php?p=406639#406639
nick(at)flylightning.net Guest
Posted: Tue Aug 13, 2013 10:45 am Post subject: Jabiru 3300 CHT Disparity |
| Quote: | From what I understand jabirus CHT limits are based on the CHT probe being
under the spark plug. Regardless of what is going on else where in the head,
this is where their testing comes from.
I would put the CHT probe under the exhaust spark plug as noted in the
installation manual, and use the limits set by jabiru.
We have been flying the 3300 in the Lightning design now since early 2006
and never have "cooked" and engine while operating inside the limitation set
forth by jabiru. We have over 130 aircraft flying with this engine and the
stock jabiru provided baffle system all over the world with no issues.
Nick Otterback
Arion Aircraft LLC
R&D Technical Support
931-680-1781
JohnDRead(at)aol.com Guest
Posted: Tue Aug 13, 2013 11:20 am Post subject: Jabiru 3300 CHT Disparity |
I was there also. I was very skeptical too about his opinions. I too would use the baffling as provided from Jabiru USA and work from there.
Regards, John
CH701 - Colorado - Jabiru 3300
Cell: 719-494-4567
Home: 303-648-3261
In a message dated 8/13/2013 12:36:20 P.M. Mountain Daylight Time, jabfox(at)hotmail.com writes:
| Quote: | I was there also, that guy was trying to reinvent the wheel
______________
CFII
Champ L16A flying
pete(at)usjabiru.com Guest
Posted: Tue Aug 13, 2013 12:28 pm Post subject: Jabiru 3300 CHT Disparity |
I did attend that forum. This man spent a great deal of time creating a
solution that is looking for a problem to solve. He had a Jabiru J series
aircraft which are not hard to cool. Very early cowls on that aircraft did
not cool the best but there was an easily fix that Jabiru put out in a
service bulletin. My company has built about 125 of these aircraft and I
can say without hesitation that cooling is not much of an issue.
As far as putting the sensor some other place that indicated by Jabiru -
we've tested a few. Under a head bolt on the exhaust side of the head
produces a reading that is about 20 degrees cooler than under the plug. If
you create a new scale with lower maximum limits and operate your engine to
those cooler indications I don't see much of a problem.
The gentleman at the forum however was promoting a probe location in the 3mm
hole that is drilled into the head between the spark plugs. I have found
this location to be unpredictable and unreliable. We had some bayonet
probes made that matched the hole diameter and flew for more than 50 hours
with a probe under the plug and another down the hole on the same head. We
did not find that temps were consistently higher indications down the hole.
Sometimes they were lower and sometimes higher. We could easily make the
temps "down the hole" rise quickly to very high levels while the indications
under the plug began to cool. Other times indications under the plug were
hotter than "down the hole". We decided that there was not enough
consistency to recommend operators employ that method.
We then tried a small ring terminal probe fastened to the hole with w small
self tapping screw. We got basically the same result with the being
variation from under the plug being less. Still not predictable to use.
The Jabiru fleet now numbers some 2500 planes. Fleet hours must be
somewhere between 1/2 to 1 million flight hours. Enough that is had been
proven that the under the plug probe location and the limits published by
Jabiru will predictably keep the heads from suffering heat damage. We can't
say that for the "down the hole" location.
Pete
Tim Juhl
Posted: Tue Aug 13, 2013 2:47 pm Post subject: Re: Jabiru 3300 CHT Disparity |
Wow, what great information! I'm glad I made this post. Thanks to all for responding.
CFII
Champ L16A flying
BARRY CHECK 6
Posted: Tue Aug 13, 2013 4:56 pm Post subject: Jabiru 3300 CHT Disparity |
Guys:
Am I reading this correctly - The Ring / under the sparkplug read LOWER in CHT than the probes that are screwed into the cylinder??? If so, that does NOT sound correctly at all.
Two examples:
1 - On Lycoming or Continental engines the Ring/under the plug thermocouple always reads HIGHER than screwed in or bayonet probes.
2 - The heat range of a plug affects the reading of the Ring/under the plug thermocouple... YES, it will also affect the standard reading CHT but the Ring type raises the CHT greatly - As ANY changes to the seating of the plug to the head will.
I can't comment on the baffling, so I won't.
Barry
PS
Once again GOOGLE changed things without my permission.
Barry
“Chop’d Liver”
"The reason Benjamin Franklin was such a great inventor was everything lay before him. The reason why we don't have great inventors today is, everyone is trying to reinvent the wheel"
On Tue, Aug 13, 2013 at 2:35 PM, David McCormick <jabfox(at)hotmail.com (jabfox(at)hotmail.com)> wrote:
[quote] I was there also, that guy was trying to reinvent the wheel
| Quote: | I attended a forum at Oshkosh where a fellow discussed his research on cooling a Jabiru 3300. He had compared the spark plug washer type CHT sensors to ones directly in the head and showed that they pretty consistently indicated CHT's about 70° cooler than actual temperatures! If this is the case, Jab operators could be cooking their engines while thinking that their CHT's were within safe limits. He ended up designing a cooling baffling system that is nothing like what comes from the factory and claimed that was the only way he was able to get the CHT's under control.
| Quote: | Tim
______________
CFII
Champ L16A flying
ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List
BobP
Posted: Sat Aug 17, 2013 1:27 pm Post subject: Re: Jabiru 3300 CHT Disparity |
I don't see how a CHT thermostat properly mounted in a small hole between the plugs can do anything but record the true CHT temperature.
I can see how a thermostat crimped into an aluminium tag that is waving in the breeze might not accurately display the temperature at the other end of the tag (ie at the plug/head interface).
If the air blasting over this tab were to be increased (eg by fitting a baffle that deflects and concentrates air onto the sensor tag) I would expect the thermocouple temperature would reduce - even if the baffle restricted the total airflow over the head so far that true head temperature increased.
If the above is true it would explain why the readings of sensors in the two different positions give differing readings.
BobP
PS is there a text summary of the presentation that started this thread?
_________________ BobP |
BARRY CHECK 6
Posted: Sat Aug 17, 2013 6:16 pm Post subject: Jabiru 3300 CHT Disparity |
Bob:
Anything that changes the conductivity of heat between the spark plug and the engine/cylinder will effect the CHT.
A spark plug is designated as a 'cold' or 'hot' plug because of the amount of heat it holds. The LESS heat that is conducted off the plug makes the plug a hotter plug. A hotter plug will cause the CHT's to increase. Putting s Ring thermocouple under the spark plug cause LESS heat to be conducted away from the plug which raises the heat range of the plug and therefore the CHT's.
Also - Ring thermocouples read HIGHER because the heat range of the plug is now increased.
I am not sure of what you are saying about a crimped aluminum tag? Would you have a part number that can be researched online with a picture?
Barry
On Sat, Aug 17, 2013 at 5:27 PM, BobP <matronics(at)panth.co.uk (matronics(at)panth.co.uk)> wrote:
[quote]--> JabiruEngine-List message posted by: "BobP" <matronics(at)panth.co.uk (matronics(at)panth.co.uk)>
BobP
BobP
http://forums.matronics.com/viewtopic.php?p=406929#406929
-List" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List
le, List Admin.
BobP
Posted: Sun Aug 18, 2013 4:01 am Post subject: Re: Jabiru 3300 CHT Disparity |
Hi Barry,
I can't see that a plug temperature range will affect the (true) cylinder head temperature. My understanding is that the terms hotter and colder plugs refer to the thermal coupling between a plug's centre electrode/ceramic nose, and the main plug body. The plug temperature range needs to be selected so the plug nose gets hot enough to burn off oil and carbon that might otherwise kill the spark, and cool enough not to act as a glow plug resulting in pre-ignition.
All the plug type thermocouples I have seen consist of an aluminium washer that is squashed between head and cylinder, the washer has a tag extending from it that "waves in the breeze". The thermocouple junction is crimped into that tag and so reads the tag temperature rather than the cylinder head temperature, or even the temperature at the plug/head interface.
guccidude
Posted: Sun Aug 18, 2013 12:52 pm Post subject: Re: Jabiru 3300 CHT Disparity |
I agree with BobP on the first paragraph. The second paragraph may need a little explanation. The ring does all that he mentioned but I think it does not read the "temperature"directly. The ring is the ground. The head temp changes the resistance value in the ring(ground) and that is what the temp indicator is displaying. The temp you read off the gauge is a resistance value displayed as a temp. That is my understanding of temp probes(rings). Dan
BobHaas
Posted: Sun Aug 18, 2013 1:39 pm Post subject: Jabiru 3300 CHT Disparity |
I concur, But I don't think the heat range is overly affected by the
thermocouple. Bob Haas N380BH N3300BH.
BARRY CHECK 6
Posted: Sun Aug 18, 2013 3:27 pm Post subject: Jabiru 3300 CHT Disparity |
Dan & Robert H.:
To answer the question correctly you have to tell us what is the Make and Model of Temperature Gauge. Most gauges use a Thermocouple. It is more accurate and can handle all sorts of harsh environments. The other option is a Thermal Resistor not as accurate and environmentally challenged.
In either case GROUND is not used as part of the temperature acquiring circuit, it is used for noise isolation and and RF isolation. Different companies have different ideas on how to handle these issues. The three types of thermocouples are: Open element, Sealed Un-Grounded and Sealed Grounded. They each have their own advantages and disadvantages.
As for the Ring type thermocouple it is a THERMOCOUPLE not a Thermal Resistor. The thermal resistor would be destroyed by torquing down the spark plug. And your idea, you could not count on the contact resistance being uniform from spark plug to spark plug or from day to day.
Robert - Opinions do not count here, only the facts count. The ring type thermocouple most definitely does affect the heat range of the spark plug. It can take the heat range UP two or more range levels. Here is a simple check you can perform from the comfort of your computer chair:
Ask around of owners of the SAME engine and SAME installation - What their CHT's are. Also ask which thermocouple they are using... Ring type or Screwed in type. There is also a bayonet type but not to many owners use it. You will find Ring thermocouples will always be a Higher Temp.
Hope this information enlightens those gray areas.
Barry
Test Engineer for the past 20 years, developing and doing exactly this type of testing.
On Sun, Aug 18, 2013 at 4:52 PM, guccidude <dcr(at)fdltownhomes.com (dcr(at)fdltownhomes.com)> wrote:
[quote]--> JabiruEngine-List message posted by: "guccidude" <dcr(at)fdltownhomes.com (dcr(at)fdltownhomes.com)>
http://forums.matronics.com/viewtopic.php?p=406988#406988
le, List Admin.
matronics(at)rtist.nl Guest
Posted: Sun Aug 18, 2013 11:17 pm Post subject: Jabiru 3300 CHT Disparity |
Barry,
Just to be pedantic, the ring is not part of the thermocouple. The ring is no more than a convenient mechanical shape that conducts heat to the tiny thermocouple that is soldered/welded into the crimp end of the ring.
The entire concept of CHT is funny. The cylinder head is a big lump of metal. One end is the hottest (the inside of the combustion chamber), the other end the coolest (the fins that we try to blast with cold air). The metal of the cylinder head conducts heat from the hot side to the colder side, and anywhere in the head you will find different temperatures. Therefor there's no such thing as 'the right CHT'. You will find temperature gradients throughout the head.
This said, there is a predictable relationship between all temperatures. When you know the highest temperature at the hottest spot that the material will withstand, thermo analysis allows you to calculate what temperature each other location in the head will be. There will be variations such as airflow, cooling from fuel mixture, ambient temperature etc.
The manufacturer picks a convenient location where they attach a thermocouple, then tell you what temperature that particular spot can be without the hottest spots in the head getting damaged. That's the goal, prevent damage.
Now, the issue with Jabiru is not that it allows for such low CHT. The problem is that they picked a spot (the crimp of that CHT ring sensor) that gets a *lot* of influence from the outside. Both ambient temperature and the airflow we use to cool the engine also influence the actual thermocouple temperature. This makes it much harder to be certain that if the thermocouple indicates 350F, the hottest spot in the head is not going to be damaged. Why does an air dam inside the airduct appear to be so effective? Because it directs the airflow down, placing that thermocouple directly into the cold airstream. Now wrap that thermocouple with a few layers of HT rubber and your readings go up. Not because the head get hotter, but because the thermocouple no longer gets direct cool air.
So, long story short, the max CHT is whatever reading ensures no damage to the head. Unfortunately, Jabiru's design choices have made it really hard to predict what that reading is.
Rob
On 8/19/2013 1:26 AM, FLYaDIVE wrote:
[quote] Dan & Robert H.:
Barry
BARRY CHECK 6
Posted: Mon Aug 19, 2013 1:22 am Post subject: Jabiru 3300 CHT Disparity |
Bob P:
There is more to it than just "burn off oil and carbon". The spark plug heat range also affects the internal gas burning temperatures within the cylinder. If you don't believe me get a set of plugs that are one or two heat ranges higher and watch your CHT - EGT and even your oil temps. They WILL get higher. Another way to think about it is: Why have different heat range spark plugs if heat range was such a constant?
NO TWO SAME ENGINES WILL READ THE SAME TEMPS! This has been discussed and notes over many, many years and millions of hours flown. The idea of the thermocouple dangling in the breeze makes as much a difference as spitting in the ocean does to the water level. Forget About IT!
What does make a difference - AND - As I said, do the test, ask those on the group, ask other groups - - - Is Ring Thermocouple Temps Vs Threaded Thermocouple Temps. You will see the Ring temps are Higher. The REAL question you should be asking is: ARE the CHT's REALLY HIGHER? NO! They are NOT!
The next question you should be asking yourself is: WHY are they NOT higher?
Well, let me explain it this way:-
If you take 10 people in good health...
Take the Same - Standard (not medical) Thermometer ...
And take their body temperature at the following locations: Mouth, Armpit, Forehead, Rectal and bottom of the Foot... Would you expect to see the same temperatures?
NO! Of course not!
YET! All 10 of these people are in good health!!!
So what is the difference?
The difference is Location, Location, Location. We all know Standard 'internal' body temperature is 98.6F. It is just where and how and with what, you take the reading.
AND! Each person in good health has their own range of 'good health'.
The bottom line is: No matter how much you try to reinvent the wheel a wheel is still going to be round. Ring thermocouples will read higher, they will raise the heat range of the spark plug and ALL thermocouples and temperature readings are a reference point.
FLYING is NOT an EXACT SCIENCE! Only because Pilots are involved. There are way too many variables.
Oh, the Rings are NOT made of aluminum... If they are they should NOT be. Aluminum is a POOR conductor of heat. Yes, a poor conductor. I know I have you scratching your head with that statement. They should be made from copper or brass. Other than heat reasons, malleability. Thermodynamics 101.
Barry
PS:
Capitals do not mean I'm yelling. That is a dumb Internet definition of capitals, I am just bring attention to particular words. I do this since you can not hear the inflection in my voice.
On Sun, Aug 18, 2013 at 8:01 AM, BobP <matronics(at)panth.co.uk (matronics(at)panth.co.uk)> wrote:
Hi Barry,
BobP
http://forums.matronics.com/viewtopic.php?p=406955#406955
le, List Admin.
Posted: Mon Aug 19, 2013 2:11 am Post subject: Jabiru 3300 CHT Disparity |
Barry,
BobP is right, spark plug heat ranges have very little to do with CHT. The different ranges are there to ensure the spark plug continues to operate well within a particular engine. It has zero effect on the actual operation of the engine. A hot plug produces exactly the same sparks as a cold plug for the same amount of electrical energy.
A picture tells more than 1000 words. Here's a video that explains very well what spark plug heat ranges mean: http://www.youtube.com/watch?v=LbR75wq9nmM
Rob
P.S. Capitals *do* mean yelling on the Internet. Just like EULA's and insurance policies they cause people to ignore the entire text. There are better ways to emphasize.
On 8/19/2013 11:21 AM, FLYaDIVE wrote:
[quote] Bob P:
NO! Of course not!
Barry
PS:
| Quote: | --> JabiruEngine-List message posted by: "BobP" <matronics(at)panth.co.uk (matronics(at)panth.co.uk)>
Hi Barry,
BobP
le, List Admin.
| [b]
BobP
Posted: Mon Aug 19, 2013 2:00 pm Post subject: Re: Jabiru 3300 CHT Disparity |
Hi Barry
I'm replying to your email in serious mode just in case you were being serious and not "pulling my leg"
Plug manufacturer NGK make no reference to combustion temperatures being affected by heat range - except in the abnormal condition of incorrect plug selection causing (dangerous) pre-ignition (see link below)
http://www.ngksparkplugs.com/tech_support/spark_plugs/p2.asp
I thought my comments relating to a "spark plug ring and tag" CHT sensor giving misleading CHT readings as compared to a sensor buried in the head self-evident. This assertion has been confirmed independently by the observations of a number of Jabiru pilots who have (before fully switching to "buried" sensors) run their engines with a plug ring and a buried CHT sensor AT THE SAME TIME and on the same cylinder and noted the temperature difference. They invariably report that the buried sensor reads hotter – typically by 20 degrees centigrade (not cooler as you suggest).
The reason for my original posting in this thread was because it had been suggested (by others) that "in head" sensors gave inconsistent CHT measurements. The point I was making was that perhaps (I believe) the “reference” plug ring and tag CHT sensor is giving inconsistent measurements (because of heat loss from the tag) and the buried sensor is giving accurate (or at least more accurate) measurements.
You made the assertion “The idea of the thermocouple dangling in the breeze makes as much a difference as spitting in the ocean does to the water level. Forget About IT!”
Barry, the only thing that stops the cylinder heads going into melt down is that same cooling breeze!!!! Clearly the airflow has much more effect than you suggested (and the baffle location maximizes that airflow exactly over the sensor tag!).
If you still think I'm wrong could you please back up any further advice by conducting the following tests on your aircraft and reporting back:
1) Totally block off your CHT cooling air ducts (shouldn’t be a problem if the "cooling air makes as much a difference as spitting in the ocean does to the water level").
2) If you think 1) might lead to some overheating fit some super cool spark plugs (you claim CHT, EGT and even oil temperature move in sympathy with the plug temperature range).
3) Do a WOT power check and advise how many seconds before the engine seizes up (don't even think about taking off).
With regard your observation that "aluminium is a bad conductor of heat" you might wish to note that aluminium(pure) conducts heat twice as well as brass (admiralty) - a material you claim to be a good conductor of heat!
I do agree that copper would be a better material for ring tabs - subject to age/work hardening not being an issue.
jetboy
Posted: Thu Aug 29, 2013 3:44 pm Post subject: Re: Jabiru 3300 CHT Disparity |
Jabiru now have an alternate CHT thermocouple location
http://www.jabiru.net.au/images/AVDALSR085-1_CHT_sensor_mod.pdf
I dont use either method because they only read the temperature of the lug, in free air, or the sparkplug body temp..
putting the thermocouple junction -with or without the existing crimped area of the lug - into the hole and sealing over with RTV is a more accurate way.
just make allowance for the higher readings obtained, when referring to CHT operating limits specified by Jabiru.
_________________ Ralph - CH701 / 2200a |
