High voltage AC and faston
jan(at)CLAVER.DEMON.CO.UK
PostPosted: Mon Aug 19, 2013 1:05 pm    Post subject: High voltage AC and faston Reply with quote
Hi Bob,
We have a discussion at work regarding the suitability of Faston connectors used for high voltage AC systems in mobile applications.?
All the best
Jan
jluckey(at)pacbell.net
PostPosted: Mon Aug 19, 2013 4:49 pm    Post subject: High voltage AC and faston Reply with quote
Yes - they are acceptable for 120/240 volt applications. I think they have a voltage rating of at least 300 volts.
What is your high AC voltage mobile application?
Jeff Luckey
Sent: Monday, August 19, 2013 2:13 PM
Subject: High voltage AC and faston
Hi Bob ,
All the best
Jan
PostPosted: Mon Aug 19, 2013 9:45 pm    Post subject: High voltage AC and faston Reply with quote
Mobile power generators – I was told that using Faston for AC application was not a good thing due to the line frequency .. i.e. alternating current causing “vibration” in the connector .. I can not see the issue with using a faston connector in this application, providing a quality faston is used – Not a poor quality Chinese copy.
I was wondering if aircraft used them in high voltage AC applications …
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jeff Luckey
Sent: 20 August 2013 01:47
Subject: Re: AeroElectric-List: High voltage AC and faston
Jeff Luckey
Hi Bob ,
All the best
Jan
<="" font="">
PostPosted: Tue Aug 20, 2013 8:36 am    Post subject: High voltage AC and faston Reply with quote
"..I was told that using Faston for AC application was not a good thing due to the line frequency .. i.e. alternating current causing “vibration” in the connector .."
I don't know about that one...
I've never heard of that and it sounds
like an "old wives tale".
The Fast-on connectors are used
ubiquitously in all kinds of things
like appliances. Look inside a
refrigerator, washing machine, dryer,
furnace, air conditioner, etc. All AC
machines that have a fair amount
of mechanical vibration. You will
see lots of Fast-ons.
As you said, stay with high-quality
connectors from T&B or Amp
and crimp properly.
I've never worked on 400hz aircraft
systems so I have no direct knowledge
of whether Fast-ons are used for
that application - but I don't think
frequency is a factor.
Sent: Monday, August 19, 2013 10:54 PM
Subject: RE: AeroElectric-List: High voltage AC and faston
Jeff Luckey
Hi Bob ,
All the best
Jan
<="" font="">
PostPosted: Tue Aug 20, 2013 1:06 pm    Post subject: High voltage AC and faston Reply with quote
Thanks Jeff
I totally agree with you .
Sent: 20 August 2013 17:35
"..I was told that using Faston for AC application was not a good thing due to the line frequency .. i.e. alternating current causing “vibration” in the connector ."
and crimp properly.
Mobile power generators – I was told that using Faston for AC application was not a good thing due to the line frequency .. i.e. alternating current causing “vibration” in the connector . I can not see the issue with using a faston connector in this application, providing a quality faston is used – Not a poor quality Chinese copy.
Jeff Luckey
Hi Bob ,
All the best
Jan
<="" font="">
http://www.matronics.com/Navigator?AeroElectric-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution --> http://www.matronics.com/con================
[/url][url=http://forums.matronhref=][/url][url=http://forums.matronhref=][/url][url=http://forums.matronhref=] --> http://www.matronics.com/con================
5
6
7
8
9
