Alternator Putting out Max Current
ChangDriver
PostPosted: Fri Aug 30, 2013 5:01 pm    Post subject: Alternator Putting out Max Current Reply with quote
I have a 35 Amp B&C alternator on an experimental aircraft. Also installed is the B&C regulator. I went thru the troubleshooting guide and all voltages are in spec. But, when running the engine at takeoff power, the alternator is putting out 35 amps. Bus voltage is regulated at 28.8 but the current is maxed out. This has never happened before. Any insight into where to look for the problem,
Thanks!!
PostPosted: Fri Aug 30, 2013 6:17 pm    Post subject: Alternator Putting out Max Current Reply with quote
If the voltage is normal (I presume this is a 28v airplane)
and the alternator is maxed out after starting the engine
then your battery is probably dead and the alternator is
running full bore to get it recharged.
ChangDriver
PostPosted: Sat Aug 31, 2013 2:11 am    Post subject: Re: Alternator Putting out Max Current Reply with quote
Bob:
Thanks. Actually the battery is new. 28 v system. The alternator (SK 35) is putting out no current at idle. As RPM increases, the current increases. At approx. 1200 rpm 10 amps, 1500 rpm 15 amps, 2000 rpm 22 amps, etc up to maxing out at t/o rpm or 2500 rpm (radial engine).
Craig
PostPosted: Sat Aug 31, 2013 6:24 am    Post subject: Alternator Putting out Max Current Reply with quote
At 05:12 AM 8/31/2013, you wrote:
Bob:
(radial engine).
Craig
Okay. If your reading the proper bus voltage under
load, then the regulator is working. The alternator's
output is RPM limited so as you increase rpm, the
AVAILABLE output current will rise to a maximum of
the alternator's nameplate rating. If the bus voltage
is correct and alternator is delivering a lot of current,
then something is LOADING the alternator . . . either
a discharged battery, operating accessories or a
combination of both.
Do you have a battery charger/maintainer that you
can put on the battery overnight so that we can
start with a KNOWN topped-off battery to do some
tests?
Is this a 'new' condition . . . in other words,
has this airplane flown with a normally operating
system?
ChangDriver
PostPosted: Sun Sep 01, 2013 5:11 am    Post subject: Re: Alternator Putting out Max Current Reply with quote
Bob:
Well I went thru the B&C troubleshooting guide and the entire system checked out. I then thought thru how a charging system works and that since the bus voltage was being held at 28.8 volts (the B&C setpoint) that it had to be something else. While the batteries were new, that does not mean fully charged.
So, I ran the engine at 1200 rpm which was 12 amps of output. Ran it for 15 minutes and watched the output drop to 9 amps. This confirmed it had to be the batteries (all radios, etc off). I then ran the engine to max RPM and 24 amps was max seen. So I went and flew it for an hour and it now indicates 8 amps with radios on, etc.
SO, the moral of the story was that new batteries did not imply fully charged batteries (I have 2 12V SLA batteries in series to make a 24 VDC system).
Thanks for the advice!!
Craig
PostPosted: Sun Sep 01, 2013 7:22 am    Post subject: Alternator Putting out Max Current Reply with quote
At 08:11 AM 9/1/2013, you wrote:
Bob:
VDC system).
What you have observed is a demonstration of the idea
that the regulator's primary function is to take care
of the battery . . . and the battery is a bucket for
the storage of watt-seconds of energy. A NEW battery
can be in a discharged state and present a significant
opportunity for the regulator/alternator team to square
off and break a sweat while topping off the bucket.
Had a roofer in my driveway in Wichita a few weeks ago
cursing his battery after his pickup wouldn't start.
The battery's installation date WAS several years back
so there was no reason to discount the possibility that
the battery was bad.
I put a charger on it and put 20+ amps in to the battery
. . . the terminal voltage didn't even get to 14.0
volts at 20A charge rate . . . a very good sign. A soggy
battery's terminal voltage will pop right up and acceptance
current will rapidly decline.
After 15 minutes, I load tested the battery and it
readily delivered 300+ amps for 10 seconds while
loaded down to 9v. I.e. the battery was healthy,
just depleted. We started the truck and the battery's
terminal voltage stayed down around 12.2 volts . . .
i.e. the alternator was not coming on line. If the
alternator HAD come on line, the terminal voltage
would have almost immediately risen to 14+ volts.
Had the alternator been fitted with an ammeter,
it might have 'pegged' at the name-plate rating
for the alternator until the battery had accepted
a substantial replenishment whereupon the current
would begin to taper off.
What you witnessed was the good and proper operation
of your ship's electrical system.
