Cutting Slots
pdelano(at)telus.net
PostPosted: Fri Aug 30, 2013 5:43 pm    Post subject: Cutting Slots Reply with quote
Hi all,
Most have probably figured out how to make nice slots without drilling
countless holes in nearly a straight line. I used an Olfa Knife with a
straight edge and a little help from my friends needle nose vice grips and
snips. see attached photos.
Now for my question: If one adds auxillary fuel tanks are they identical to
the ones that come in the 701 wing kit or are they a different size.
Perry
 Filesize:  43.78 KB
 Viewed:  3373 Time(s)
 Filesize:  49.92 KB
 Filesize:  45.28 KB
 Filesize:  43.54 KB
 Filesize:  44.52 KB
 Filesize:  38.54 KB
 Filesize:  42.34 KB
 Filesize:  47.81 KB
 Filesize:  45.33 KB
carlossa52(at)gmail.com
PostPosted: Sat Aug 31, 2013 5:49 am    Post subject: Cutting Slots Reply with quote
Nicely done, Perry
I too use this technique on aluminum, but when I read "slots" on the heading of your note, I thought about the slots on the firewall, for the steering rods.
(I have been working on that area, so it's natural.)
To make those slots, I used this tool, available from the usual sources:
http://www.adelnibbler.com/
It's fairly cheap at around $30, and works nicely - of course, it also works on aluminum.
Cheers
Carlos
On 30 August 2013 21:42, Perry Delano <pdelano(at)telus.net (pdelano(at)telus.net)> wrote:
[quote] Hi all,
Perry
