Over Voltage on Start Up
dbarnes
PostPosted: Sun Sep 01, 2013 11:17 am    Post subject: Over Voltage on Start Up Reply with quote
I have 40 hours on my lancair es and have been trying to solve a charging problem since the first startup in july. I have a vertical power electrical system (vp-200), a b&c voltage regulator (lr3c) and an io-550n with a stock 60 amp alternator. Five seconds after engine start vertical power switches power on to the voltage regulator. The alternator comes on and vertical power senses an overvoltage and disconnects the power to the regulator. After resetting the vertical power sometimes two or three times over a 30 second time period the system holds and remains fine for the balance of the flight.
I replaced the voltage regulator with an identical replacement with no change. Another clue is that when the system first starts holding in the voltage is on the high side close to 31 volts. Over time maybe ten minutes it settles down to 28.6 for the remaining flight. I also hear a faint alternator squeal in my headset. I am using two odyssey pc535 12 volt batteries in series and they are at the rear of the plane connected with #2 welding cable
The odyssey batteries are four years old but have been kept charged with a smart charger. I wondered whether a bad diode in the alternator could cause this?
Anyone have any ideas?
Dan Barnes
PostPosted: Sun Sep 01, 2013 12:59 pm    Post subject: Over Voltage on Start Up Reply with quote
There's something fundamentally wrong here. The voltage
should NEVER be higher than the regulator's set-point.
Readings of 31 volts suggests that the regulator is not
getting 'real' bus voltage sample which is critical to
proper operation.
Attach a (+) lead of a voltmeter to the regulator's bus
voltage sense terminal (#3) and the (-) lead to regulator
ground terminal (#7). Tell us what you read when the
VP screen is reporting 31 volts. It sounds like the
regulator 'believes' it's doing a good thing while in
fact, the data it's operating on is bogus.
How is the regulator grounded?
Where does terminal (#3) get it's power?
This has the 'smell' of a grounding issue where battery
recharge currents are polluting the regulator's ground
reference causing it to operate at something other than the
set-point.
Try dismounting the regulator, disconnect existing wire
from terminal #7 and run a test wire from #7 to the
crankcase. I'm thinking that you may see the ov
condition disappear. Can you describe your ground system
for us?
dbarnes
PostPosted: Mon Sep 02, 2013 8:14 am    Post subject: Re: Over Voltage on Start Up Reply with quote
Starting at the battery a #2 cable goes to the inside of the fire wall to a plate with a field of spade connectors then through a 5/16 inch brass bolt to the engine side of the firewall to another field of spade connectors and also to one of the starter mounting bolts through a large braided cable. The regulator is on the engine side of the firewall and gets its ground from one of the spade connectors. Originally I had the sense line of the regulator hooked to a dedicated output from vertical power. In trying to solve this problem I moved it to the battery positive bolt on the firewall (through a small fuse). At first it seemed to solve the problem but the charging voltage was too low. When I adjusted higher I was back to the same problem.
I am going to the hanger this pm and will try an alternate ground to the engine block and extend wires into the plane to measure the sense voltage and compare it to the vp displayed voltage.
Dan Barnes
PostPosted: Tue Sep 03, 2013 7:26 am    Post subject: Over Voltage on Start Up Reply with quote
Very good. Your ground system appears righteous. But
there's something going on that confuses or fools
the regulator's otherwise clear view of the universe.
dbarnes
PostPosted: Tue Sep 03, 2013 9:11 am    Post subject: Re: Over Voltage on Start Up Reply with quote
Bob,
I tested the voltage on the sense terminal to the ground terminal on the regulator. It seemed to match the display on the vertical power. They both measured over 30 volts. The io-550 uses a direct drive alternator. I didn't have an additional ground wire on it so I added that. I took a #8 wire from the case ground to the engine block. Another plane I looked at had that so I added it. No change. Any chance the regulator is seeing too much ac from the alternator and it is confusing it? I have read in the car world that leaky, open, shorted diodes sometimes cause strange problems.
Dan Barnes
PostPosted: Fri Sep 13, 2013 11:10 am    Post subject: Over Voltage on Start Up Reply with quote
proper operation.
set-point.
for us?
