jskiba(at)icosa.net Guest
Posted: Fri Sep 13, 2013 3:28 pm Post subject: Looking for a circuit that when you press a button powers th |
Looking for a circuit that when you press a button powers the device but ....if the button is held on it is only powered for a max setting (say 3 seconds) but this same circuit should stop if the button is released before the 3 seconds.
Hope that makes sense, I bet it exists already and I just am searching under the wrong name.
Thanks in advance for the help
Jeff.
henador_titzoff(at)yahoo. Guest
Posted: Fri Sep 13, 2013 4:46 pm Post subject: Looking for a circuit that when you press a button powers th |
Jeff,
I believe you need a better spec. For example, you say that when the button is pressed, the device is powered on. Then you say if the button is released before the 3 second interval, it should stop powering the device. Or at least that's what I think you said.
I think you need to divide it into the following functions:
- If the button is pressed for less than N seconds, function 1 happens
- If the button is pressed for more than N seconds, function 2 happens
- If the button is held for exactly N seconds, well never mind, there is no such thing unless you have an accuracy spec. If you do, then function 3 happens. These three functions need not be mutually exclusive.
Whatever functionality you want, I believe a microcontroller or CPLD will do the job. If you describe your functionality more accurately, including output voltage, current, etc., then this group can recommend specific products, including boards.
Henador Titzoff
To: "aeroelectric-list(at)matronics.com" <aeroelectric-list(at)matronics.com>
Sent: Friday, September 13, 2013 7:27 PM
Subject: Looking for a circuit that when you press a button powers the device but ....
--> AeroElectric-List message posted by: Jeffrey Skiba <jskiba(at)icosa.net (jskiba(at)icosa.net)>
Je= --> http://www.matronics.com/Navigator?AeroElectric-Lista href="http://forums.matronics.com/" target="_blank">http://forums.mat &nbs//www.matronics.com/contribution" target="_blank">http://www.matronics.co==================
nuckollsr
Joined: 24 Mar 2009 Posts: 95 Location: Medicine Lodge, KS
Posted: Fri Sep 13, 2013 6:06 pm Post subject: Re: Looking for a circuit that when you press a button power |
Henador's suggestion is doable. There's probably a half dozen approaches to this task. Questions:
How much current do you need to switch?
Can the switch be in the ground side of the load?
Do you mind if a relay is used . . . or is it a design goal
to be all solid state?
You may be able to do this for a few$ of discrete
components . . .
Eric M. Jones
Posted: Sat Sep 14, 2013 6:10 am Post subject: Re: Looking for a circuit that when you press a button power |
Quote: | Looking for a circuit that when you press a button powers the device but ....if the button is held on it is only powered for a max setting (say 3 seconds) but this same circuit should stop if the button is released before the 3 seconds.
Jeff. |
The circuit you want is a momentary push button with a resettable fuse. Preferably solid state.
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
