flysrv10(at)gmail.com Guest
Posted: Sun Sep 15, 2013 2:03 am Post subject: B and C pad mounted alternateor |
Anyone using B&C's pad mounted 20 amp alternator as a primary?
I checked my consumption and with everything on (exception fuel pump) it is 22 amps.
I have 500 hrs on Van's alternator and dread having to pull a prop out on a trip to replace a belt or the alternator.
Thanks.
flying-nut(at)cfl.rr.com Guest
Posted: Sun Sep 15, 2013 5:57 am Post subject: B and C pad mounted alternateor |
On 9/15/2013 6:02 AM, Rob Kermanj wrote:
I'm not using mine yet.
| Quote: | I checked my consumption and with everything on (exception fuel pump) it is 22 amps.
A properly tensioned and aligned belt will last a long time.
I had 2200+ hours on one belt (my AA-1B) before I changed it. It was
showing signs of cracking so it was a preventative move. You should
have a lot of warning before a belt failure. It should be on your
checklist at annual and damage is easy to see.
Now for your 'dread'. Next annual put a 'backup' belt on the nose of
the engine and ty-wrap it to the forward lift ring to keep it out of the
way. I have seen the 'replacement' belt be unuseable because the
primary lasted so long and it was just dried out. I don't have any data
but you should get at least 1000 hours out of a belt so change it during
an annual or when you pull the prop for some reason. Belts are cheap.
Linn
Thanks.
Checked by AVG - www.avg.com
Posted: Sun Sep 15, 2013 6:07 am Post subject: B and C pad mounted alternateor |
Good advice Linn. I will seriously consider it.
How about the alt? Anyone has failure hours in service data? My first one lasted 200 hrs. This one has 500 hrs and I have a long trip to take next month. I see black powder on the alt and I am worried.
Do not archive.
Rob Kermanj
Sent from my iPad
On Sep 15, 2013, at 9:57 AM, Linn Walters <flying-nut(at)cfl.rr.com> wrote:
I had 2200+ hours on one belt (my AA-1B) before I changed it. It was showing signs of cracking so it was a preventative move. You should have a lot of warning before a belt failure. It should be on your checklist at annual and damage is easy to see.
Now for your 'dread'. Next annual put a 'backup' belt on the nose of the engine and ty-wrap it to the forward lift ring to keep it out of the way. I have seen the 'replacement' belt be unuseable because the primary lasted so long and it was just dried out. I don't have any data but you should get at least 1000 hours out of a belt so change it during an annual or when you pull the prop for some reason. Belts are cheap.
Linn
> Thanks.
> Do not archive
> No virus found in this message.
Posted: Sun Sep 15, 2013 6:12 am Post subject: B and C pad mounted alternateor |
That should be 'conditional inspection' not 'annual' .... old habits are
hard to break.
Linn
On 9/15/2013 9:57 AM, Linn Walters wrote:
> it is 22 amps.
cheap.
Linn
> Thanks.
> Do not archive
Posted: Sun Sep 15, 2013 6:25 am Post subject: B and C pad mounted alternateor |
On 9/15/2013 10:17 AM, Rob Kermanj wrote:
You need to find out where the black powder is coming from. I suspect
the belt. Look at the baffling around the belt for signs that the
clearance wasn't enough. I've read (here I think) about some original
installations not having the flywheel and alternator pulleys aligned and
needing modifications on the alternator mounting to make it fit
properly. That may have been a Plane Power problem though. Have a safe
trip.
Linn
Do not archive.
Rob Kermanj
Sent from my iPad
> Linn
>> Thanks.
>> Do not archive
