Inline connections needed? (with little space)
PostPosted: Wed Sep 18, 2013 3:24 am    Post subject: Inline connections needed? (with little space) Reply with quote
At 06:21 PM 9/17/2013, you wrote:
rickofudall wrote:
> Or you could use the machined pins for the DB 25 and mate them
directly with some shrink tubing over them and go without using the
body of the connector.
> Rick Girard
I have room for a DB-25 behind the switches.
What is controlled by these switches? Are the
'mags' legacy magnetos or p-mags? What is the
largest anticipated current to be controlled
by any one switch?
donjohnston
PostPosted: Wed Sep 18, 2013 5:06 pm    Post subject: Re: Inline connections needed? (with little space) Reply with quote
by any one switch?
Master switch, mags, starter contactor, boost pump, alternator...
Stock magnetos on a Continental IO-550.
Highest current device is the boost pump drawing 4a (at) 28v.
