		randy(at)shadycreekoutlaw Guest
				 Posted: Mon Jun 12, 2006 6:11 am    Post subject: Bolt Torque Specs |
				I am finishing up the center spar for my 601  XL.  There are 6, AN4-15A bolts that go through the center  spar.  Are there torque specifications on these bolts that I need  to follow?
  Thanks in advance,
  Randy
  XL Wings - Plans Only
  http://www.n344rb.com
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Mon Jun 12, 2006 7:05 am    Post subject: Bolt Torque Specs |
				Randy,
 Most bolts in structural applications will have a torque value for the
 place they are used.
 The AN4-15A bolt is a high strength fine thread bolt with 50-70 inch
 pounds standard type nuts.
 You need the Standard Aircraft Handbook 6th ed or later.  Most of this
 kind of information is
 in this handbook.  Your plans have the final word on fasteners,
 dimensions etc.
 Larry McFarland - 601HDS at www.macsmachine.com
 Randy Bryant wrote:
  	  | Quote: | 	 		   I am finishing up the center spar for my 601 XL.  There are 6, AN4-15A
  Thanks in advance,
  Randy
				 Posted: Mon Jun 12, 2006 11:59 am    Post subject: Bolt Torque Specs |
				Thanks Larry,
 My plans don't say what to torque these bolts to...  Since most are kit
 builders and don't have to actually build this part, since it comes from the
 factory already assembled, I guess that the torque value for these 6 center
 spar bolts is not 'common knowledge'...  I guess my best bet is to call ZAC
 and see what they can tell me...
 Thanks much,
 Randy
		normskiroo@ukonl
				 Posted: Tue Jun 13, 2006 6:56 am    Post subject: Bolt Torque Specs |
				Hello Randy,
  According to CZAW the recommended torque for the  AN4 bolts are 50 to 70 in. lb. (5.6 to 7.9  Nm) the limit being 11.3 Nm.
  Hope this helps.
  Norman
  601 XL G-DONT 40 hrs  U.K.
		frank.hinde(at)hp.com Guest
				 Posted: Tue Jun 13, 2006 7:25 am    Post subject: Bolt Torque Specs |
				Actually the real limit is when you strip the threads! You  cannot cause a bolt to fail in service due to over torquing. They will break (if  subjected to vibrational tension changes that cuse fatigue) if you UNDER torque  them.
  Bottom line (and I can't wait to get flamed on  this... ...) the listed torques specs really are on the very bottom limit for  comfort and I assume are primarilly for fasteners in shear rather than tensile  applications.
  You would never find a cylinder head or tensile faster with  so little torque, but they have been shown to work in practice . Mine are all a  little tighter than this though.
  Frank
    From: owner-zenith-list-server(at)matronics.com  [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of  norman
 Sent: Tuesday, June 13, 2006 7:54 AM
 To:  zenith-list(at)matronics.com
 Subject: Re: Bolt Torque  Specs
  Hello Randy,
  Hope this helps.
  Norman
				 Posted: Tue Jun 13, 2006 8:10 am    Post subject: Bolt Torque Specs |
				I thought that the reason for torquing bolts was to  achieve the proper 'stretch' in the bolt...  I know in an engine, you  torque rod bolts, they stretch and apply tension to the rod caps and this helps  hold the cap on...  If you over torque, you 'stretch' the bolt past its  elasticity and loose this extra holding capacity...
  Maybe I'm wrong...??  I just hate having to  tighten something as far as it will go then 1/4 turn more as the torque  specs...
  Thanks!
  Randy
  [quote]   ---
				 Posted: Tue Jun 13, 2006 8:48 am    Post subject: Bolt Torque Specs |
				Thanks Frank,
  It looks like I'm gonna agree with you after  all...  I just got a response back from ZAC about the torque of these bolts  and here's what they said:
  "For proper bolt selection and installation,  please refer to the FAA
 publication, Acceptable Methods Techniques, and  Practices: AIRCRAFT
 INSPECTION AND REPAIR AC 43.13-1B"
  We all know what that says, 50-70 inch  pounds...  Its a crying shame that a go-kart manufacturer can tell you  specifically to torque certain bolts, used in certain applications, to an exact  spec, and aircraft manufacturers can't... (I guess they're too busy  keeping their rivets exactly 8mm from the edge)  Even the auto makers  do this...  They'll tell you specifically how many foot/pounds or  inch/pounds to tighten certain bolts, not some broad range of 50-70 inch  pounds...
  I guess I'll just tighten em' as tight as they'll  go, then go about 1/4 turn more... that should do it..
  Randy
  [quote]   ---
		Carlos Sa
				 Posted: Tue Jun 13, 2006 10:00 am    Post subject: Bolt Torque Specs |
				Randy, I think you are quite right.
 The more torque you apply, the closer the material gets to "plastic" (as opposed to "elastic").
 There is a lot of good reading material out there. I found this one to be interesting:
 http://www.auf.asn.au/scratchbuilder/hardware.html
 Cheers
 Carlos
 CH601-HD, plans
 Building aeroplanes (one) since 1999. A tradition in the making.
  _________________ CH601-HD, plans
Montreal, Canada |
				 Posted: Tue Jun 13, 2006 10:02 am    Post subject: Bolt Torque Specs |
				There is no way on Earth you will stretch AN bolts with  the miniscule listed torque specs. The AN4 is listed at about 6 ft  lbs...On a cylinder head this would be  more like 15lbs and it still won't stretch.
  Frank
    From: owner-zenith-list-server(at)matronics.com  [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Randy  Bryant
 Sent: Tuesday, June 13, 2006 9:08 AM
  Thanks!
  Randy
  [quote]   ---
		moorecomp(at)yahoo.com Guest
				 Posted: Tue Jun 13, 2006 10:15 am    Post subject: Bolt Torque Specs |
				Randy,
 Remember that the torque is to be added to the running
 torque of the nut. If you are using self locking nuts,
 then you need to measure the amount of torque required
 to turn the nut and add it to the 50 - 70 in. lbs.  If
 you really want to get educated on threaded fastener
 torque, go here and look at MIL-HDBK-60.
 http://www.combatindex.com/mil_docs/mil_hdbk_index_01.html
 This is a great link and all should bookmark it. Lots
 of info here.
 BTW - At the end of the handbook, it shows a chart
 that looks like the AN4 bolt, which is a 125ksi
 tensile material, would require approx. 100 in. lbs.
 of torque, the max value given in the 43.13.
 Small flame for Frank,
 Excessive torque can be a bad thing too, especially if
 you exceed the elastic limit of the bolt. Over time,
 with cyclic loading and vibration, the preload on the
 fastener will be gone, resulting in a situation you
 described - undertorque. As another lister noted, bolt
 stretch is commonly used as a method of checking for
 proper preload. But, the value is within the elastic
 limits. All of this is the reason that we go back and
 retorque fasteners after a certain time. Also, in the
 type of joint we are talking about, the use of many
 bolts is because the majority of the shear loads are
 transferred through friction of the joint components,
 and the load is spread over a large area and not just
 taken up by the bolt shanks. Lose the preload, and you
 cause stresses to be concentrated at the bolts, thats
 were elongated holes come from.
 Ducking,
 Craig Moore A&P
 701 builder wannabe
 --- Randy Bryant <randy(at)shadycreekoutlaws.com> wrote:
 [quote] Thanks Frank,
  refer to the FAA
  Practices: AIRCRAFT
  inch pounds...
  it..
  Randy
				 Posted: Tue Jun 13, 2006 10:59 am    Post subject: Bolt Torque Specs |
				Thanks Craig,
 This is good info... This really helps...  My fear was I wouldn't tighten
 them enough and have to worry about that from now on after my plane is
 flying, or be in fear that they are too tight and loose the preload...yet
 another thing to worry about...
 One more quick question for you:
 Would a certain bolt such as an AN4 require the same torque regardless of
 it's application (where it's being used on the plane) ?
 Thanks much,
 Randy
				 Posted: Tue Jun 13, 2006 12:13 pm    Post subject: Bolt Torque Specs |
				Randy,
 I assume you looked at the MIL-HDBK-60. Paragraph 4.2
 gives the two type of shear loaded joints. One is like
 your wing attach bolts. No sliding, with shear loads
 transmitted by friction. Think of the other as like a
 rod end or fork fitting. This type obviously does not
 use friction to transmitt the load from one fitting to
 the other, it goes through the bolt. In this case, the
 torque is only to hold the joint together so that
 bending loads do not occur on the bolt. A castle nut,
 finger tight, then tight to line up the cotter pin
 hole would suffice. On a high tensile load like an
 engine mount to firewall, then the clamping force of
 the rated torque would be used to keep the joint
 together and prevent bending. Good luck building. I'll
 be there one day.
 Best regards,
 Craig Moore A&P
 701 builder wannabe
  Thanks Craig,
  after my plane is
  plane) ?
  Thanks much,
  Randy
 snip
		noelloveys(at)yahoo.ca Guest
				 Posted: Tue Jun 13, 2006 2:01 pm    Post subject: Bolt Torque Specs |
  I usually go with the lower end  of the range...50 - 70 In.Lb.  Use 50 In. Lb. on the first use... if the  nut is removed and used again then I'll use 60"Lb. The second time it's removed  may as well replace it if it is in an area of any stress.
  One other thing I always  turn/torque the nut....  never the bolt.
 Noel [quote]
		zodierocket(at)hsfx.ca Guest
				 Posted: Tue Jun 13, 2006 2:33 pm    Post subject: Bolt Torque Specs |
				Randy not to dampen your expectations but “you are” the manufacturer, not the kit provider. It is your responsibility to ensure compliance to FAA regulations.  Zenith sells and supports kits that will someday fly. If you want an exact torque you could try AMD which manufacturers Zodiacs for the LSA market, but I doubt they will respond. ZAC’s response was correct and expected. It is up to you as to what torque you are comfortable with.
 cdngoose
 www.ch601.org / www.ch701.com/ www.Osprey2.com
 -----Original Message-----
 Thanks Frank,
 [i]"For proper bolt selection and installation, please refer to the FAA[/i]
  [i][i]publication, Acceptable Methods Techniques, and Practices: AIRCRAFT[/i]
  [i]INSPECTION AND REPAIR AC 43.13-1B"[/i][/i]
 We all know what that says, 50-70 inch pounds...  Its a crying shame that a go-kart manufacturer can tell you specifically to torque certain bolts, used in certain applications, to an exact spec, and aircraft manufacturers can't... [i](I guess they're too busy keeping their rivets exactly 8mm from the edge)[/i]  Even the auto makers do this...  They'll tell you specifically how many foot/pounds or inch/pounds to tighten certain bolts, not some broad range of 50-70 inch pounds...
 Randy
		daberti(at)sbcglobal.net Guest
				 Posted: Tue Jun 13, 2006 3:29 pm    Post subject: Bolt Torque Specs |
				50 to  70 is NOT "some broad range"  in fact + or - 10 inch lbs Is a rather  standard torque tolerance.  Certificated (calibrated) torque wrenches are  only good to 2 percent of the total range of the wrench so if you have a 0  to 150 in lbs wrench it's accurate to  3 inch lbs from what you set it  to.  Sounds like a pretty tight specification to me, and I shoot for the  mean plus the drag of the nylon stop nut.
 Dave 601-HD 912ULS
   	  | Quote: | 	 		     [i]"For proper bolt    selection and installation, please refer to the    FAA[/i]
				 Posted: Tue Jun 13, 2006 9:15 pm    Post subject: Bolt Torque Specs |
				I only use the drag of the  fibre lock nut (AKA friction torque) when it is specified.  Wearing of the  fibres in the locknuts is the main reason I dump them after they have been  tightened three times.  In the overall scheme of things they are cheap  enough to use relatively new.
  As for the torque wrench I tend  to check mine out with a known weight every couple of months.  Right now  for 200"Lb. I set for 187"LB.  checking it is easy as suspending a known  weight on the handle at a specific distance from the centre of the stud and then  adjusting the wrench to just click at that torque.
  e.g. 16.6Lb. suspended at 12"  from the centre of the stud = 200"Lb.  When calibrated this way the torque  wrench should be less than 1% out.  you can also put the same weight at 6"  top check the calibration of 100"Lb.
  In Canada torque wrenches used  on certified A/C have to have a certificate of calibration in effect before the  wrench is used.
 Noel [quote]
		normskiroo@ukonl
				 Posted: Tue Jun 13, 2006 10:38 pm    Post subject: Re: Bolt Torque Specs |
				Randy,
 A word of caution here, I have this morning checked my CZAW drawings and they specify the bolts that attach the wings on my XL are AN5 15A not AN4 15A.
 The torque for these bolts according to the data CZAW gave me is -
 100 to 140 in. lb. recommended 11.3 to 15.8 Nm with a limit of 25.4 Nm.
 I shall, next time a am down at the aircraft use a vernier gauge to confirm the size.
 During a wings off/back on operation some time ago I managed to strip the threads of one of the bolts /nuts by over tightening and I was only using a ratchet socket handle six inches long!
 Needless to say the drilling of the bolt head took a while to get the whole thing out!
 Norman 601 XL G-DONT 40 hours, UK
				 Posted: Wed Jun 14, 2006 3:28 am    Post subject: Bolt Torque Specs |
				 	  | Quote: | 	 		  16.6Lb. suspended at 12" from the centre of the stud = 200"Lb.  When
 This estimate assumes the measurement of 12 inches and 16.6 pounds
 have a combined error of less than 1%.  I find this conclusion very
 unlikely.  Still, the procedure will assure a reasonably accurate
 torque from the wrench.
 Paul
 XL wings
				 Posted: Wed Jun 14, 2006 3:31 am    Post subject: Bolt Torque Specs |
				 	  | Quote: | 	 		  CZAW drawings and they specify the bolts that attach the wings on my
 ZAC drawings for the XL also call for AN5 -15A attach bolts on the
 wings.  I decided to change to AN5-14A since the originals seemed a
 little too long to me.
 Paul
 XL wings
