tonyrenshaw268(at)gmail.c Guest
Posted: Mon Sep 23, 2013 10:20 am Post subject: Rotax 914 CHT probes |
Can someone please remind me of the CHT sensing options for the Rotax 914? I know under spark plug sensors can be used, but that it can effect spark plug torque, so I am interested in whether there is a port on a cylinder etc that can be used accurately, or whether water temperature is the better method of monitoring engine temperature health. Thanks in anticipation. Regards
Tony Renshaw
gilles.thesee(at)free.fr Guest
Posted: Mon Sep 23, 2013 10:49 am Post subject: Rotax 914 CHT probes |
Tony Renshaw a écrit :
| Quote: | >
> Gidday,
G'day Tony,
The 914 comes with two CHT sensors, one on the front left head, the
other on the rear right head.
You just connect one of those to your gage. Everything is the
installation manual.
Naturally, since all the temps limits in the manual are CHT temps, those
are the temps you need to monitor.
FWIW,
Best regards,
Gilles
http://contrails.free.fr
ptag.dev(at)talktalk.net Guest
Posted: Mon Sep 23, 2013 12:06 pm Post subject: Rotax 914 CHT probes |
Hi! Tony . There is a position to the side of the rocker box which is dry ( no coolant and no oil to receive the sensor which is not unlike a little cylindrical sensor definitely NOT an under plug sensor .) On the 914 it is also vital to have a water flow temperature sensor in the coolant “manifold” pipe passing down the rear of the engine bay to the radiator.. It is no good sensing the coolant temperature anywhere else it won’t be reliable.
Bob Harrison G-PTAG
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Tony Renshaw
Sent: 23 September 2013 19:20
Subject: Rotax 914 CHT probes
Tony Renshaw
01234567890123
