Ray Allen position sensors
Tundra10
PostPosted: Mon Oct 07, 2013 7:12 pm    Post subject: Ray Allen position sensors Reply with quote
I would like the Dynon Skyview to record the position of my ailerons
and elevators.
Has anyone used the Ray Allen position sensors for this ?
Are they suitable for the continuous movement, or will they wear out ?
Do they provide mechanical resistance that would be felt as drag on
the control stick ?
How much off axis motion will the plunger accept before binding ?
Alternatively, are there any automotive products that might be
suitable, such as throttle position sensors ? The one used on my
vehicle would be impractical to mount.
Jeff Page
Dream Aircraft Tundra #10
PostPosted: Tue Oct 08, 2013 5:56 am    Post subject: position sensors Reply with quote
http://sensing.honeywell.com/index.php?ci_id=50310
http://www.mouser.com/ProductDetail/Honeywell/SS49E-L/?qs=%2fha2pyFadujjBQFozaeJvxILyylNJHM2nSeWyreXIzB4Z925QiG%2fMw%3d%3d
If you want to make your own sensor, a hall effect sensor is very simple to make electrically speaking. The hard part will be the mechanical installation. A magnet attached to the control surface will cause a varying output voltage across a load resistor as the magnet moves.
Joe
Joe Gores
jluckey(at)pacbell.net
PostPosted: Tue Oct 08, 2013 7:02 am    Post subject: Ray Allen position sensors Reply with quote
Jeff,
2 devices pop immediately to mind: a potentiometer (pot) or rotary encoder (like the TPS uses).
But first a few questions:
1. where do you want to mount the sensor?
-somewhere near the aileron
  -near the bell crank
-near aileron axis of the stick
2. what type of input does the Dynon have for this purpose. Is it expecting an analog voltage or a string of bits?
With a pot, it is trivial to deliver an analog voltage proportional to surface deflection. With a rotary encoder you will need some circuitry.
As far as connecting linkages & arms, you might look into RC model aircraft hardware. There are all kinds of arms, clevises, ball links, etc that could do the job. See these links for starters:
http://www.servocity.com/html/servo_power_gearbox_arms.html
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=&FVSEARCH=aluminum+servo+arms&search=Go
To: Aero_Electric_List <aeroelectric-list(at)matronics.com>
Sent: Monday, October 7, 2013 8:12 PM
Subject: Ray Allen position sensors
--> AeroElectric-List message posted by: Jeff Page <jpx(at)qenesis.com (jpx(at)qenesis.com)>
I would like the Dynon Skyview to record the position of my ailerons and elevators.
Do they provide mechanical resistance that would be felt as drag on the control stick ?
Alternatively, are there any automotive products that might be suitable, such as throttle position sensors ? The one used on my vehicle would be impractical to mount.
Jeff Page
Dream Air Use the Matronics List p; &n
Tundra10
PostPosted: Wed Oct 09, 2013 5:22 am    Post subject: Ray Allen position sensors Reply with quote
Jeff,
The most likely place for an aileron or elevator connection is to the
bellcrank in the wing (aileron) and under the cabin floor (elevator).
So the end of the rod connected to the bellcrank will swing an arc and
the other end of the rod would connect to the sensor. The Ray Allen
sensor might work, but only if it doesn't mind the slightly off axis
forces and the continuous motion (higher wear rate than a trim or flap
indicator).
If the Ray Allen is unsuitable, than another potentiometer device
would work, since the Dynon has analog 0-5V inputs. That open
possibilities of automotive throttle position sensors etc., but most
will likely be harder to mount and connect a rod to.
Joe Gores hall effect device has possibilities I will need to look
into (Thanks Joe !), although it looks like I might need to find a way
to temperature compensate it.
Jeff Page
Subject: Re: Ray Allen position sensors
Jeff,
But first a few questions. Where do you want to mount the sensor ? -somewhere
near the aileron -near the bell crank -near aileron axis of the stick ??
What type of input does the Dynon have for this purpose ? - Is it
expecting an
to surface
deflection. - With a rotary encoder you will need some circuitry. As far as
PostPosted: Wed Oct 09, 2013 7:39 am    Post subject: Ray Allen position sensors Reply with quote
Well, that makes it easy -- a 5-volt regulator, 10k pot driven from the bell crank & you're in business...
Sent: Wednesday, October 9, 2013 6:22 AM
Jeff,
The most likely place for an aileron or elevator connection is to the bellcrank in the wing (aileron) and under the cabin floor (elevator). So the end of the rod connected to the bellcrank will swing an arc and the other end of the rod would connect to the sensor.  The Ray Allen sensor might work, but only if it doesn't mind the slightly off axis forces and the continuous motion (higher wear rate than a trim or flap indicator).
If the Ray Allen is unsuitable, than another potentiometer device would work, since the Dynon has analog 0-5V inputs.  That open possibilities of automotive throttle position sensors etc., but most will likely be harder to mount and connect a rod to.
Joe Gores hall effect device has possibilities I will need to look into (Thanks Joe !), although it looks like I might need to find a way to temperature compensate it.
Jeff Page
From: Jeff Luckey <jluckey(at)pacbell.net (jluckey(at)pacbell.net)>
Jeff,
What type of input does the Dynon have for this purpose ? - Is it expecting an
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=&FVSEARCH=aluminum+servo+arms&am; sp; -================
retasker(at)optonline.net
PostPosted: Wed Oct 09, 2013 8:41 am    Post subject: Ray Allen position sensors Reply with quote
I am not sure about the Ray Allen position sensors, but if you do use a pot, make sure it is one designed to be used in
such an application where it will be almost continuously adjusted. All pots have a projected life before they start
acting flaky (technical term Wink ). Some are designed to be continuously adjusted, others are intended to be used only
occasionally.
While what you are contemplating is not a safety of flight issue, at least how I interpret what you want to do, it would
be a pain if you had to replace the pot every few months because it wore out and responded erratically.
Dick Tasker
*To:* aeroelectric-list(at)matronics.com
*Sent:* Wednesday, October 9, 2013 6:22 AM
*Subject:* Re: Ray Allen position sensors
Jeff,
connect a rod to.
Jeff Page
> From: Jeff Luckey <jluckey(at)pacbell.net <mailto:jluckey(at)pacbell.net>>
> Jeff,
PostPosted: Wed Oct 09, 2013 3:27 pm    Post subject: Re: Ray Allen position sensors Reply with quote
The Ray Allen pot can be mounted with a hinge. Then there will be no sideways force.
I bought one of those hall effect sensors to play with. One end of a magnet will make the output voltage go up. The other end of the magnet will make the output voltage go down. I think that a horseshoe magnet will give the largest output range as the magnet moves. The magnet will have to be located near the control pivot point because it only needs to move a fraction of an inch.
Another possibility is to use hall effect switches or magnetic reed switches.
Joe
Joe Gores
