List: RV10 Window Junction Cracks - Any Advise?
gommone7(at)bellsouth.net
PostPosted: Wed Jun 14, 2006 8:32 am    Post subject: List: RV10 Window Junction Cracks - Any Advise? Reply with quote
Because everybody make an opinion ,here is mine,from the boating industries,give a try at 3M 5200,
the toughest products you can handle ,in 4 to 5 days not even the knife go trough,and still flexible for vibrations.this products adhere even under water,it come in the fast cure version.
you can purchase the small tube and a scrap of plexi and give a try,.
only my opinion,
Hugo,40456
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: 2006/06/14 Wed AM 11:29:22 EDT
Subject: RE: RV10 Window Junction Cracks - Any Advise?
glastar(at)gmx.net
PostPosted: Wed Jun 14, 2006 9:06 am    Post subject: List: RV10 Window Junction Cracks - Any Advise? Reply with quote
Tough indeed but know where to use it, I did use it to have my defrost
air channel glued to the glare shield, not a good example as the T you
build cracked after 200hrs (and several time getting the glare shield in
and out), however the turbulators on my aluminum wings are still rock
solid with the 5200 as well as my sidepanel covers on the door. I did
glue the windows with silpruf and I'm more then happy as well as I think
the 5200 is quite heavy. Oh and yes, this is on a Glastar too.
br
Werner
only my opinion,
Hugo,40456
>To: <rv10-list(at)matronics.com>
phil(at)asibuildings.com
PostPosted: Wed Jun 14, 2006 9:20 am    Post subject: List: RV10 Window Junction Cracks - Any Advise? Reply with quote
Hugo,
Can you paint over it?
Phil
40122
only my opinion,
Hugo,40456
PostPosted: Wed Jun 14, 2006 11:10 am    Post subject: List: RV10 Window Junction Cracks - Any Advise? Reply with quote
yes ,it is.allow 10 to 20 days ,when it complete the dring process.
hugo
Date: 2006/06/14 Wed AM 06:20:34 EDT
Subject: Re: List: RV10 Window Junction Cracks - Any Advise?
Hugo,
Phil
40122
>only my opinion,
>Hugo,40456
>do not archive
PostPosted: Wed Jun 14, 2006 11:20 am    Post subject: List: RV10 Window Junction Cracks - Any Advise? Reply with quote
Yes you rigth is tough,but you can use 4200 wich is a less hard and easy to remove,in my opinion I rather have a wind (blow out) proof window and worry later if the window or the windshiel need to be remove,if you by any chance go in that problem of replace the windshield,I thinks clean the condor's feathers from the back seat will be the mayor task
Hugo
Date: 2006/06/14 Wed PM 01:04:58 EDT
br
Werner
>only my opinion,
>Hugo,40456
>do not archive
