rlborger(at)mac.com Guest
Posted: Tue Oct 08, 2013 12:32 pm Post subject: Battery questions |
Raimo,
I too have been known, on a rare occasion, to leave the master on. I think I've done that three times in the last 5 years. First two times it was with an Odyssey 680. First time it happened I put a charger on it and it came back like new. About 18 months later I did it again. Put the charger on it and it came back. But this time I was concerned so I replaced it with a new Odyssey and put the old Odyssey in an old Jeep we use at the hunting lease. It worked in that Jeep for about 4 years till my hunting bud left the key on for about 6 months. That pretty much killed it. Meanwhile, this spring, I replaced the Odyssey in the Europa with a tiny little, very light (and very expensive) LiFePo battery. The Odyssey I took out went into the Jeep. The new LiFePo battery seemed to work quite well for starting and running. Eventually, I did a run-down test to see how long it would operate the EFIS, EIS, Radio & Xponder. Turned out, not very long. After about 10 minutes things started dropping off. I recharged & balanced the LiFePo battery overnight and it was fine the next day. BTW, I kept the charger/balancer on whenever the aircraft was in the hanger. Flew a couple times over the next week and parked it to do more testing. This time I went off leaving the master on (with the charger attached, btw). Next day, the battery was DEAD. And I mean DEAD. Would not accept a charge. I put a new Odyssey back in the aircraft and plan to stick with them from now on.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Oct 8, 2013, at 2:32 PM, Raimo Toivio <raimo.toivio(at)rwm.fi> wrote:
I have a little Odyssey story:
once I forgot my IBBS (Integrated Battery Backup System) on for several weeks, which gives juice to my Gemini ADI (Tru Trak). It went empty and so went finally my lovely Odyssey. Normally there is like fixed 12,58 V but now hardly 4 V (four). I had a must to fly so I elected to fire upp engine w an external battery. I run the engine say 20 minutes and after that session it was fireable by Odyssey only. I never noticed any failures in that brave battery but just in case I ordered a new one (Odyssey retail shop is just 10 km from here). Now I have a reserve battery, which is year modell 2006, has been in use 6 years, went totally empty and still a new like. So far I will carry those extra kilos happily - want to hear more reports before updating more modern batt techs.
Cheers, Raimo
OH-XRT
My wife was licensed on Monday with w top ratings. Now I know how is it to try to sleep w a captain.
raimo.toivio(at)rwm.fi Guest
Posted: Tue Oct 08, 2013 9:25 pm Post subject: Battery questions |
WoW Bob,
that was a story which was expected.
If somebody has an obsession to update for a
LiFePo style battery, I would carry always omboard
a spare one (or have a dual system and not forget
a 2nd master on).
10 minutes is an awful short time to have
electricitet in the case alt/chg failure - that is
an another reason to have a dual system (if you
are a LiFePo - user boy).
Cheers, Raimo
-----Alkuperäinen viesti-----
Sent: Tuesday, October 08, 2013 11:31 PM
Subject: Re: Re: Battery questions
<rlborger(at)mac.com>
Raimo,
10 minutes thi!
from now on.
Bob Borger
AEIO-320 EXP
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
Cheers, Raimo
OH-XRT
browse
Un/Subscription,
FAQ,
Forums!
List Admin.
Fred Klein
Posted: Wed Oct 09, 2013 7:55 am Post subject: Battery questions |
On Oct 8, 2013, at 10:25 PM, Raimo Toivio wrote:
| Quote: | If somebody has an obsession to update for a LiFePo style battery, I would carry always omboard a spare one (or have a dual system and not forget a 2nd master on).
10 minutes is an awful short time to have electricitet in the case alt/chg failure - that is an another reason to have a dual system (if you are a LiFePo - user boy).
Once again we find that "there's no free lunch"...
Alan Carter
Joined: 02 Jul 2012 Posts: 378 Location: Kent, England.
Posted: Wed Oct 09, 2013 2:17 pm Post subject: Re: Battery questions |
Hi All.
I just have one Odyssey haven't a clue as to the size of it, also a 914,
But to me it seems crazy to rely totally on electrics for fuel supply.
If the fuel stops the engine stops.
Why hasn't the 914 a mechanical pump, as well as an electrical pump. What's the reason not have a mechanical pump in the system, the 912 have both.
Its the same as having a totally electric instrument panel, I much prefer
a dual system. Systems do fail and usually its the time when you really didn't want it too.
Alan
Posted: Wed Oct 09, 2013 6:02 pm Post subject: Battery questions |
Hi Alan,
The 914 requires higher pressure in the fuel bowl than the 912 due to the turbo. The Rotax fuel pump can not supply sufficient pressure to force fuel into the bowl. The Rotax stock method of supplying the fuel is to use two electric fuel pumps. Either of which is capable of feeding the engine. One to be powered from the main buss the other to be powered from the battery. So should the main generator drop off, the second pump will be fed directly from the the battery giving you time to get the aircraft safely on the ground.
Personally, I didn't like the arrangement either. I installed an engine driven fuel pump from Billet ( billetpump.com & http://www.billetpump.com/home2/pumps.html ). Not cheap, but it sure does work. And my engine is no longer electrically dependent. Obtaining a pump from them can be a trial. A couple years ago I tried to buy several pumps for folks in Switzerland and France and gave up after 18 months of trying. Kind of crazy company to deal with but they produce excellent products if you can ever get one.
I'd be happy to try them again should you or anyone else wish to acquire one of the pumps.
If you go to http://www.europaowners.org/main.php?g2_itemId=78854 you can see my pump and the work I went to for installation. I believe that they have refined the pump since then and installation can be much easier.
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
On Oct 9, 2013, at 5:17 PM, Alan Carter <alancarteresq(at)onetel.net> wrote:
Hi All.
Alan
Posted: Thu Oct 10, 2013 12:08 am Post subject: Battery questions |
Alan, you have in effect got a dual supply - the battery
and the alternator. If you have wired things according to
the Europa instructions you will find that you can switch
off both main & alternator switches in flight and the
engine keeps running. All the electrical instruments which
haven't got internal batteries go out, which is a bit
scary but the engine remains entirely happy, fuelled by
the electric pump run directly off the alternator.
Regards, David Joyce, G-XSDJ (914 mono)
On Wed, 9 Oct 2013 15:17:13 -0700
"Alan Carter" <alancarteresq(at)onetel.net> wrote:
Hi All.
it, also a 914,
for fuel supply.
Alan
http://forums.matronics.com/viewtopic.php?p=410164#410164
Un/Subscription,
Forums!
Admin.
Posted: Thu Oct 10, 2013 1:21 am Post subject: Battery questions |
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 10/10/2013 12:17 AM, Alan Carter wrote:
| Quote: | Why hasn't the 914 a mechanical pump, as well as an electrical
the 912 have both.
There are two reasons:
1) The 914 needs a higher fuel pressure.
2) The 914 runs hotter, and the inlet air has an elevated temperature
because of the compression by the turbo. A mechanical fuel pump
connected to the hot engine, plus its long hose routing through the
cowling, allows considerable heat transfer to the fuel. Then you have
the combination of hot inlet air and hot fuel. This increases the
chances of vapor lock (and detonation?) considerably. The Rotax
engineers designed the fuel system of the 914 setup such that you can
keep the fuel pumps outside the cowling, with no mechanical connection
to the hot engine, and with very little fuel hose exposed inside the
cowling. Together with the high return flow this ensures that the fuel
reaching the carbs won't get too hot.
The concept works, I don't remember having seen reports of a double
electrical fuel pump failure. Don't fix something that isn't broken!
If you want additional redundancy, I would recommend putting an extra
alternator on the engine. There are very small light weight
alternators that fit on the vaccuum pad of the engine and are able to
run a fuel pump plus some additional items. You can only use it of
course if you have no vacuum pump on the engine.
Frans
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.18 (GNU/Linux)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=N5Q2
-----END PGP SIGNATURE-----
JonathanMilbank
Joined: 14 Apr 2012 Posts: 397 Location: Aberdeen area
Posted: Thu Oct 10, 2013 5:40 am Post subject: Re: Battery questions |
My situation: this winter I'm upgrading from Rotax 912UL to 912S 100hp, but keeping the installation in the Classic engine bearer and retaining the original cowlings and firewall forward as far as possible. Therefore I MUST keep the old shorter starter motor.
For C of G reasons, the battery must be mounted in the rear fuselage behind the old (smaller) baggage bay and therefore the battery must be very safe and immune from risks of overheating. At the moment I have a simple ride-on lawnmower lead-acid battery, which might not have enough "oomph" to start the higher compression S engine.
What I'm hoping you can tell me is which is the most common battery used in UK LAA Permit Europas and referring to a friend's quote "I can't remember what the system voltage is with the engine running, but the odysseys need 14.1 to 14.7v to ensure avoidance of both sulphation and overcharging", should I be installing a different rectifier/regulator?
My 912UL engine only produces a maximum of 14.2 volts. Maybe I can manage with the ride-on lawnmower battery, but I doubt it.
paul.the.aviator(at)gmail Guest
Posted: Thu Oct 10, 2013 9:13 am Post subject: Battery questions |
Okay, I'll weigh in. I am with Frans on this one.
There are various strategies to overcome the risk of electrical dependency. I am using Bob Knuckles single battery E buss system and I can confirm that this works.
My Europa took a lightning hit which took out my main electrical system and I was able to switch over to the E buss and continue flying to the nearest airport. This system (if maintained) allows me to fly for over 90 minutes.
There are refined, well understood designs for single battery E buss, single battery dual alternator, or dual battery dual alternator systems.
Redesigning the Rotax fuel delivery system isn't what I would choose to do.
Just my 2 cents worth.
> the 912 have both.
The Rotax
Frans
clivesutton
Posted: Thu Oct 10, 2013 9:40 am Post subject: Re: Battery questions |
"My Europa took a lightning hit"
wow - that's a story - was there any structural damage or signs of plasma entry/exit? Any pictures? I have always thought a lightning strike would incapacitate a Europa airframe
Do tell
Clive
Fred Klein
Posted: Thu Oct 10, 2013 9:42 am Post subject: Battery questions |
On Oct 10, 2013, at 10:12 AM, Paul McAllister wrote:
| Quote: | There are various strategies to overcome the risk of electrical dependency. I am using Bob Knuckles single battery E buss system and I can confirm that this works.
Paul,
Can you recall which of the "Z" circuit diagrams you used as a guide?
Fred
Posted: Thu Oct 10, 2013 10:40 am Post subject: Battery questions |
Sorry Fred,
Its nearly 10 years since I wired up my airplane. I'd suggest to sign up to Bob's forum and put the question out there.
Paul
On Thu, Oct 10, 2013 at 12:41 PM, Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)> wrote:
Paul,
Fred
arget="_blank">http://www.matronics.com/Navigator?Europa-List
Alan Carter
Posted: Thu Oct 10, 2013 12:33 pm Post subject: Re: Battery questions |
Hi Bob ,David and All.
Many thanks for your reply's, it must have been a good question.
Very interesting on the Alternator wiring and the Battery, I will check it out,
but not in the air David, I did not build the plane, I have learnt something here and will post what I find,
Lots of Alternators and spare Battery's required, I much prefer Bobs mechanical pump and if well insulated should have no heat problem.
All these other options are work arounds and I have no doubt they all work but one should not have to do all these work arounds and if one buys a £30000 engine it should not be totally dependant on electricity, the pumps may be OK but if the Alternator fails and lets say an old battery or loose terminal the engine stops, This does not sound good design to me.
If you have a Vacuum drive generator I take it you have no Vacuum instrument ??,so down to electric only.
I will make do with what I have, just hope its wired Alternator pump, battery pump, so does mean that if the engine is not running my Number 2 pump will not run as I prim using the number on pump.
Many thanks.
Alan
pete(at)lawless.info Guest
Posted: Thu Oct 10, 2013 1:14 pm Post subject: Battery questions |
Hi All
Just a question for the all electric pumps installation - you are flying
happily along when that burning insulation smell starts followed by smoke
seemingly from behind the panel - what do you turn off?
Personally I would just like to kill all the electrics and still have my
engine running.
Pete
G-RMAC Classic 912ul
PS OK so it has not happened yet but that does not mean it won't!
brian.davies(at)clara.co. Guest
Posted: Fri Oct 11, 2013 12:16 am Post subject: Battery questions |
Jonathan,
I have been using a Varley Redtop 25 racing battery which is 16AH AGM
(absorbed glass matt). This is virtually identical spec to the Odyssey
PC680 which many people use for a Rotax 912S. It has provided perfect
starting for 6 years. The battery is behind the baggage bay and uses 4
gauge battery cables. I have never seen more than 14.2 volts system voltage
and on a fully charged battery it is mostly at 13.8 volts.
Provided you have good connections and big enough cable, I don't think you
will have any problems with a new Rotax 912S, even with the older starter,
as long as the sprag clutch is in good condition.
Brian Davies
Posted: Fri Oct 11, 2013 1:56 am Post subject: Battery questions |
Hash: SHA1
On 10/10/2013 11:14 PM, Pete Lawless wrote:
| Quote: | Just a question for the all electric pumps installation - you are
flying happily along when that burning insulation smell starts
followed by smoke seemingly from behind the panel - what do you
turn off?
First of all, it should not be possible that this happens. There is a
simple rule, always wire downstream of a CB or fuse with a wire gauge
suitable for carrying at least the max current of the CB or fuse. So,
even if something goes wrong, then still either the CB pops or nothing
happens.
Secondly, invest in a good amps gauge. I know from all equipment how
much current it is normally using; if something goes wrong I can
easily sort out which circuit is going south and pull the assosiated
CB. If there is smoke, there must be quite some current flowing
somewhere, and it should be relatively easy to find the corresponding
circuit.
Third, if you follow the Europa design you have the second fuel pump
wired directly to the alternator. This means that you can indeed turn
off everything and the engine keeps running. Unless the fault is in
the alternator or remaining pump, but then this means that the rest of
the system is still alive so you should be able to operate from the
other fuel pump. Of course this is only possible if there is a way to
isolate the alternator from the electrical system, either manually or
with a CB/fuse.
Last, I have two completely independant electrical systems, each with
its own alternator and battery. I can kill one complete electrical
system and operate the ship from the remaining bus.
| Quote: | Personally I would just like to kill all the electrics and still
have my engine running.
That is still possible.
Frans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=dYgV
Alan Carter
Posted: Fri Oct 11, 2013 2:09 am Post subject: Re: Battery questions |
That, what I would do Peter, Kill the lot, then pull all the breakers, and if I found I really needed something turn that one on. But before I do I must check David's wiring out, With my luck its probably wired wrong, and the engine will stop.
I am wiring my new FFM directly to the battery with fuse and switch, so in the event that If ever i kill the lot, I will still have engine running and fuel indications.
Alan
Posted: Fri Oct 11, 2013 2:16 am Post subject: Battery questions |
Hash: SHA1
On 10/10/2013 10:33 PM, Alan Carter wrote:
| Quote: | I much prefer Bobs mechanical pump and if well insulated should
I'm interested to learn how you are going to thermally insulate a
metal fuel pump bolted to a hot metal engine.
Remember that a hot fuel pump is exactly the place where you can
expect vapor lock and/or cavitating. And where it does the most harm
because the pump then works in a void and the fuel flow stops. There
is a reason why the Rotax engineers strayed off the obvious route and
came up with something else...
| Quote: | and if one buys a ï¿‚ï¾£30000 engine it should not be totally
You'd better get used to it. Fuel injection and fadecs are on the rise
and without doubt will soon every new engine be dependant on
electricity. The advantages far outweigh the disadvantages.
It may have escaped to you that the Rotax alternator has a very
special design. It has no brushes, no moving parts at all that can
fail. It is the very same alternator that produces the electricity for
the spark plugs. In fact, also the 912 is completely dependant on the
very same alternator; without it the spark plugs won't fire and also
the 912 won't fly any further. So, even if you have a mechanical fuel
pump you still have a complete engine stop if this alternator fails.
Luckily, it is quite unbreakable.
| Quote: | the pumps may be OK but if the Alternator fails
If the alternator fails the spark plugs won't fire anymore, so it
doesn't matter whether the pumps stop.
| Quote: | If you have a Vacuum drive generator I take it you have no Vacuum
instrument ??
Vacuum pumps suck. I hope you are not suggesting that vaccuum is more
reliable than electricity?
Frans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=C2Ah
Posted: Fri Oct 11, 2013 2:24 am Post subject: Battery questions |
Hash: SHA1
On 10/11/2013 12:09 PM, Alan Carter wrote:
| Quote: | I am wiring my new FFM directly to the battery with fuse and
What's wrong with wiring the fuel pump to the alternator?
If you wire it to the battery, you are defying the purpose of the
master switch. In a crash landing, I wouldn't care whether the spark
that ignites my leaking fuel was coming from my GPS or from my fuel
indicators or fuel pump. (Not to mention the fact that the fuel pump
may continue to run after the crash, something you might not desire if
there is a fuel leak upstreams).
If you wire to the alternator, nothing can go wrong, assuming that the
engine will stop at impact and the electricity is long gone before you
come to a stop.
I must say that I'm a bit surprised how many people easily modify the
fuel system and/or electrical system, without understanding what the
reasons were why it was designed in that specific way.
Frans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=G2IX
gilles.thesee(at)free.fr Guest
Posted: Fri Oct 11, 2013 4:04 am Post subject: Battery questions |
Frans Veldman a écrit :
Frans and all,
During the build of our project, we made a thorough study of the
electrical system of the Rotax 914.
We discovered that in some cases true redundancy is not achieved with
the schematic provided by Rotax, because of the Rotax voltage regulator
behavior.
That's why we had to resort to dual battery installation.
Concerning the fire hazard in a crash, it is admitted that skinny hot
conductors (less than 5 amp) present relatively low risk.
Let's remember that at least one always hot conductor exists between the
master switch and the main battery contactor, though the current is
limited by the contactor coil.
Best regards,
Gilles
http://contrails.free.fr
