donjohnston
Posted: Thu Oct 10, 2013 9:22 am Post subject: iPad charger? |
I've been looking for an accessory adapter that will charge an iPad (while in use). All the adapters I've found so far either don't put out enough power to charge the iPad or, if they can, get really hot and eventually fail.
Has anyone found a charging adapter that will work (on 14v and 28v aircraft)?
I was also thinking of building one with a panel mount USB port. But so far, every circuit I've found has... issues. Does anyone have a suggestion for such a circuit?
email(at)jaredyates.com Guest
Posted: Thu Oct 10, 2013 10:34 am Post subject: iPad charger? |
I picked up a few cigarette lighter adapters from Dealxtreme that were supposed to be able to provide ipad current. Some couldn't, and one made my car radio unusable whenever it was plugged in. Sorry to not be able to provide any more help, other than to say that you may have mixed results with the seemingly easy and cheap import options.
http://forums.matronics.com/viewtopic.php?p=410227#410227
edpav8r(at)yahoo.com Guest
Posted: Thu Oct 10, 2013 11:10 am Post subject: iPad charger? |
Dan,
I mentioned this once in passing and have avoided further mention for fear of sounding like a marketing wonk, but since you're interested...
I've been developing a product to do exactly what you need. As it's shaping up, it should be a board about 1.25 x 2.5 inches with a rugged dual-USB receptacle at one end and a connector for ship's power at the other. It will comfortably charge two iPads -- or pretty much any other USB-charged device -- at once, and will include noise filtering and automatic shutoff in the event of charging system failure. The USB receptacle is a panel-mount unit that uses two #4-40 screws. It can be mounted in a custom cutout in the panel, or I plan to offer sub-panels to fit standard instrument cutouts. You could of course also fabricate your own mounting solution.
Stay tuned; I'm pushing hard to have it ready ASAP.
Eric
dennis.glaeser(at)gm.com Guest
Posted: Thu Oct 10, 2013 11:17 am Post subject: iPad charger? |
I use a 12 volt cigarette plug from Radio Shack that puts out the required amps for 2 iDevices. I haven’t looked for a 28V charger.
You do have to specify that is for an iDevice to get one with the proper power output.
Dennis Glaeser
Nothing in this message is intended to constitute an electronic signature unless a specific statement to the contrary is included in this message.
Confidentiality Note: This message is intended only for the person or entity to which it is addressed. It may contain confidential and/or privileged material. Any review, transmission, dissemination or other use, or taking of any action in reliance upon this message by persons or entities other than the intended recipient is prohibited and may be unlawful. If you received this message in error, please contact the sender and delete it from your computer. [quote][b]
handainc(at)madisoncounty Guest
Posted: Thu Oct 10, 2013 11:51 am Post subject: iPad charger? |
Eric -
I would certainly like to have a couple of them for my project. Big
problem on my trip to Alaska. We had purchased 3 or 4 expensive USB
recharging receptacles and converters. By the time we got to Calgary,
every one of them had crapped out, two of them wouldn't even work on
plugging them in, although they all worked when we checked them prior to
the trip. We got a ride to a Radio Shack, and bought a couple more, and
those managed to work until we got to Anchorage. We were flying with 2
iPads for redundance, thank goodness, plus had the weather on the
Stratus ADS-B, and an iPhone for a back up panel. Sure enough, we lost
a vacuum pump about an hour out of Ft. Nelson, Canada, and the iPhone
app made it a non event, even with weather closing in. Had to make a
couple of more legs before we could find a replacement vacuum pump.
That experience has convinced me to include USB plugs plan for extra
electrical taps for whatever hand held equipment is available when I get
it completed. Plus, I just hate having all the cords running all over
the cockpit.
M. Haught
On 10/10/2013 2:09 PM, Eric Page wrote:
Quote: |
Dan,
Eric
Posted: Thu Oct 10, 2013 12:16 pm Post subject: iPad charger? |
Marvin,
Thanks for this story! That's *exactly* why I'm designing this product. The market is flush with USB chargers of every size, brand, color and price. Sadly, apart from a few OEM products, they seem to share one trait in common: poor design, parts quality and manufacturing.
It's obvious that portable touch-screen devices are the way forward for many pilots, and USB has become ubiquitous for charging them. Now we need a reliable charger.
Eric
On Oct 10, 2013, at 12:50 PM, "H. Marvin Haught Jr. " <handainc(at)madisoncounty.net> wrote:
Quote: |
Eric -
I would certainly like to have a couple of them for my project. Big problem on my trip to Alaska. We had purchased 3 or 4 expensive USB recharging receptacles and converters. By the time we got to Calgary, every one of them had crapped out, two of them wouldn't even work on plugging them in, although they all worked when we checked them prior to the trip. We got a ride to a Radio Shack, and bought a couple more, and those managed to work until we got to Anchorage. We were flying with 2 iPads for redundance, thank goodness, plus had the weather on the Stratus ADS-B, and an iPhone for a back up panel. Sure enough, we lost a vacuum pump about an hour out of Ft. Nelson, Canada, and the iPhone app made it a non event, even with weather closing in. Had to make a couple of more legs before we could find a replacement vacuum pump.
That experience has convinced me to include USB plugs plan for extra electrical taps for whatever hand held equipment is available when I get it completed. Plus, I just hate having all the cords running all over the cockpit.
M. Haught
> Dan,
> Eric
> do not archive
rd2(at)dejazzd.com Guest
Posted: Thu Oct 10, 2013 12:19 pm Post subject: iPad charger? |
Hi Eric,
Is it a "no-noise" circuit or switched w/minimal noise ?
BTW I've been very pleased with the 24V to 19 V (for Lenovo tablet) no noise charger/PS you made for me.
Rumen
---- Eric Page <edpav8r(at)yahoo.com> wrote:
Dan,
Eric
Posted: Thu Oct 10, 2013 12:45 pm Post subject: iPad charger? |
And you need to design so that the unit can be hard wired into the panel, not just portable.
M. Haught
On Oct 10, 2013, at 3:15 PM, Eric Page wrote:
[quote]flush with USB chargers of every size, brand, color and price. Sadly, apart from a few OEM products, they seem to share one trait in common: poor design, parts quality and manufacturing.[b]
scott(at)n696js.com Guest
Posted: Thu Oct 10, 2013 12:49 pm Post subject: iPad charger? |
I bought one from Best Buy about 3 years ago - I use it in my truck for my
iPhone most of the time; but it has had no problem on long trips keeping
the iPad going. It even has a USB adapter on the top of the cigarette
plug that I have used simultaneously to charge another device. Works like
a charm.
Scott R. Shook
eventually fail.
aircraft)?
Ooops! Sorry, Eric, I was to fast, obviously not paying attention as to who the originator was -
I was referring to Eric Jones (Perihelion Design) in my earlier post.
Rumen
P.S. You are right, I've been burned twice with these "nice, professionally looking" 5 V devices on ebay.
Now, I am testing this one: tinyurl.com/l7h235y
Presume it's a switcher, but no noticeable noise; hope it doesn't burn out (and my tablet).
Would appreciate feedback from others, if anyone else is using it.
Marvin,
Eric
Quote: |
Eric -
M. Haught
> Dan,
> Eric
> do not archive
Posted: Thu Oct 10, 2013 1:06 pm Post subject: iPad charger? |
You got lucky! I've got one that I use in my truck too that has been a good one. But the ones we took to Alaska were junk.....and 3 of them were expensive, which we bought under the premise that "you get what you pay for". Not so! We took all of them apart in the motel to see if we could fix them....just junk. I've got one from my old Noki smart phone that is really good, and two Apple units that are in constant use.
M. Haught
a charm.
Scott R. Shook
> eventually fail.
> aircraft)?
Posted: Thu Oct 10, 2013 1:09 pm Post subject: iPad charger? |
That looks exactly like the most expensive one we had on the trip, but ours did not have the big lable. Lasted only the first day in the airplane. I think we paid $30 or $40 for it in an electronic shop at home.
M. Haught
Rumen
Marvin,
Eric
> Eric -
> M. Haught
>> Dan,
>> Eric
>> do not archive
>>> Read this topic online here:
Posted: Thu Oct 10, 2013 2:10 pm Post subject: iPad charger? |
What voltage did you use them/it on?
I might be wrong, but it seems that most of the products advertised for 12-24 V can't really handle well the 24-28V bus. I had one toasted the instant it was plugged in, free running, no load.
R
M. Haught
Rumen
Marvin,
Eric
> Eric -
> M. Haught
>> Dan,
>> Eric
>> do not archive
Michael Wynn
Joined: 10 Jan 2006 Posts: 148 Location: San Ramon, CA
Hi Eric,
I have been thinking about how to do this too. The panel mount would be ideal. When you get it ready to test or sell, sign me up.
Michael Wynn
RV 8 Finishing
San Ramon, CA
In a message dated 10/10/2013 1:17:21 P.M. Pacific Daylight Time, edpav8r(at)yahoo.com writes:
Quote: | --> AeroElectric-List message posted by: Eric Page <edpav8r(at)yahoo.com>
Marvin,
Eric
Quote: | --> AeroElectric-List message posted by: "H. Marvin Haught Jr. " <handainc(at)madisoncounty.net>
Eric -
M. Haught
> Dan,
> Eric
> do not archive
>> --> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com>
>> = Use ilities ay - MATRONICS WEB FORUMS - List Contribution Web Site p;
_________________ Michael Wynn
RV 8
San Ramon, CA |
earl_schroeder(at)juno.co Guest
Posted: Thu Oct 10, 2013 2:17 pm Post subject: iPad charger? |
Eric,
Please let me know when you have this product ready!
Thanks, earl
Posted: Thu Oct 10, 2013 2:44 pm Post subject: iPad charger? |
12 Volt - two of the cheaper ones did the same thing, even though we had tested them at home. Alternator at the time was putting out 13.8 volts according to the volt meter.
M. Haught
R
M. Haught
> Rumen
> Do not archive
> Marvin,
> Eric
> do not archive
>> Eric -
>> M. Haught
>>> Dan,
>>> Eric
>>> do not archive
Posted: Thu Oct 10, 2013 4:49 pm Post subject: iPad charger? |
Rumen: No worries. I think I've seen three Erics on the List! I haven't seen the charger you've got, but I'm sure it's a switcher. They all are. Getting enough current at 5V to rapid-charge an iPad through a linear regulator fed with 14V would make an 18-watt heater!
Marvin: Panel mounted and hard wired is exactly my plan. Nice, neat installation and zero hassle during use.
Michael and Earl: Thanks for your interest; I'll add you to my contact list.
Cheers,
Eric
wgreenley
Joined: 09 Jan 2010 Posts: 100 Location: Dowagiac, MI
Posted: Thu Oct 10, 2013 5:10 pm Post subject: iPad charger? |
Also interested.
Bill Greenley
Posted: Fri Oct 11, 2013 4:10 am Post subject: iPad charger? |
Add me to the list - I already have the panel spot and fuse slot identified.
Is there an 'easy' way to determine externally whether a given cheapo or
high price cig plug usb charger is the switcher/linear regulator type or
the type that has some chance of working for awhile? 'Easy' being
defined as with a multi-meter or perhaps even a quick peek inside.
I've been thru a number myself. I have one that seems to work on my
other non-iPad devices but I've been saving it for an emergency iPad charge.
In the end, I was so ashamed of having cigarette plug in my '10 that I
hid it behind a back seat cushion. Given the variety of devices needing
a USB charge, I can't wait to put something up front. I figure by the
time I get it, the USB standard will change but that's life.
Bill
Cheers,
Eric
henador_titzoff(at)yahoo. Guest
Posted: Fri Oct 11, 2013 4:31 am Post subject: iPad charger? |
Eric, as you can see, there's quite a bit of interest in your iPad charger. Not sure what switching IC you will use, but I woild like to see an automotive charger that provides two USB outputs. The ones I've used are flakier than hell, and I'm starting a 6,000 mile USA round trip in December. I want to take my Garmin 496 so I can capture breadcrumb trails to send home to mama. That will require one 12 cigarette socket and two USB outputs. Anyone know of something reliable that exists today?
Henador Titzoff
On Thu, 10/10/13, Eric Page <edpav8r(at)yahoo.com> wrote:
Subject: Re: iPad charger?
To: "aeroelectric-list(at)matronics.com" <aeroelectric-list(at)matronics.com>
Date: Thursday, October 10, 2013, 5:48 PM
heater!
use.
Cheers,
Eric
List Contribution Web Site -
-Matt
Dralle, List Admin.
