		rleffler
				 Posted: Mon Oct 14, 2013 1:50 am    Post subject: Mechanical fuel pump pressure |
				I'm looking for the amount of fuel pressure that the mechanical fuel pump (engine attached) on a yio-540-d4a5 is supposed to yield.  Aircraft Spruce's listing states 25-30psi.  Is this what I should expect?
 The reason I'm asking is that mine is only generating about 23 psi.
 Is there any effective way to test, short of taking it off and sending back to Lycoming or a certified shop?
  _________________ Bob Leffler
N410BL - Phase I
		Kelly McMullen
				 Posted: Mon Oct 14, 2013 5:05 am    Post subject: Mechanical fuel pump pressure |
				23 is fine. The Bendix fuel injection needs approx. 15 psi as a minimum. 30 is generally considered a maximum. I don't know why Spruce lists the numbers they do.
  On Mon, Oct 14, 2013 at 2:50 AM, Bob Leffler <rv(at)thelefflers.com (rv(at)thelefflers.com)> wrote:
  	  | Quote: | 	 		   --> RV10-List message posted by: Bob Leffler <rv(at)thelefflers.com (rv(at)thelefflers.com)>
  http://forums.matronics.com
  le, List Admin.
  - sent from the microchip implanted in my forearm
A&P/IA, EAA Tech Counselor
KCHD |
				 Posted: Mon Oct 14, 2013 5:31 am    Post subject: Mechanical fuel pump pressure |
				Bob, I took a look in the Operators manual.  It seems to indicate that
 between 14 to 45psi is normal for input to the fuel injector.
 I took a look at a few random flight logs and see that my fuel pressure
 stays between 18 and 21 psi.  I think I have the alarm set at 15psi and
 it has gone off a few times over the last 300+ hours.  During climb on a
 hot day as I recall but not sure.  I haven't been concerned.
 On 10/14/2013 5:50 AM, Bob Leffler wrote:
		Bob Turner
				 Posted: Mon Oct 14, 2013 7:37 am    Post subject: Re: Mechanical fuel pump pressure |
				I agree with the above post.
 Bob, if you bought the engine thru Vans you should have received a white binder with all the numbers in it.
  _________________ Bob Turner
RV-10 QB |
		Bob Turner
RV-10 QB |
		rleffler
				 Posted: Mon Oct 14, 2013 9:57 am    Post subject: Re: Mechanical fuel pump pressure |
				I missed it when I flipped through the manual early this morning.   It indeed states the numbers that Bill mentioned.
N410BL - Phase I
				 Posted: Mon Oct 14, 2013 1:43 pm    Post subject: Mechanical fuel pump pressure |
				BTW, that kind of thing will happen a lot as you transition from
 building to flying and maintaining,  at least it did to me.
   Just when I got near the top of learning curve I suddenly found myself
 staring up at another.  However, whenever I found my self sitting in the
 pilot's seat making airplane noises, I was at 5,000' and 170
 knots....and there was no fiberglass dust!
 Bill "leaving this little knot of gray rainy weather for FL soon" Watson
		rv10flyer
				 Posted: Tue Oct 15, 2013 8:16 pm    Post subject: Re: Mechanical fuel pump pressure |
				Mine runs 28-29 in cruise, 20-25 in a steep hot full power climb. Check actual pressure with a gage setup.
  _________________ Wayne G. |
