Posted: Fri Oct 11, 2013 4:29 am Post subject: Battery questions |
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 10/11/2013 02:03 PM, GTH wrote:
| Quote: | During the build of our project, we made a thorough study of the
electrical system of the Rotax 914. We discovered that in some
cases true redundancy is not achieved with the schematic provided
by Rotax, because of the Rotax voltage regulator behavior. That's
why we had to resort to dual battery installation.
I have that too. But in the original setup it is as close as you can
get to full redundancy.
| Quote: | Concerning the fire hazard in a crash, it is admitted that skinny
hot conductors (less than 5 amp) present relatively low risk.
I'm more concerned about sparks. Remember it is also a spark which
ignites the fuel in the cylinders. Any cable carrying current *will*
spark when ripped apart. And a glass aircraft won't bend but break, so
the risk is very high that cables will get sheered off (at the same
moment the fuel hoses break as well).
| Quote: | Let's remember that at least one always hot conductor exists
between the master switch and the main battery contactor, though
the current is limited by the contactor coil.
That's true. In my ship it is the only "live" wire in the whole
aircraft. But you can eliminate the ability to spark if you use a 10
cent transistor to switch the contactor coil (and a diode to
extinguish the back flow current). So, there is now nothing that can
spark once the master switches are off.
Indeed, this is where I diverted from the original plans: I think that
keeping the stall warner and trim alive by routing them around the
master switch is plain stupid. Then you could keep as well the flaps,
the radio and a dozen other "essential" goodies alive.
My idea is to keep the electrical systems running until established at
"final" (whatever the target of the controlled crash will be) and then
fly the remainder without fuel and electricity. I should be close to
trimmed out for the intended landing speed and I can well do without a
stall warner if necessary. Anyway, I don't want to have any live wires
running through the ship at that moment (not to mention electric fuel
pumps that keep pumping out fuel once the crash landing has been
finished).
Frans
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.18 (GNU/Linux)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=rQhz
-----END PGP SIGNATURE-----
peterz(at)zutrasoft.com Guest
Posted: Fri Oct 11, 2013 4:48 am Post subject: Battery questions |
Question though....is there not a a capacitor anywhere in the rotax charging setup? If there is, the switches would not save one from sparks as the charge on the capacitor will more than happily provide a spark when it's wires get shorted in a crash.
Cheers,
Pete
| Quote: | On Oct 11, 2013, at 6:24 AM, Frans Veldman <frans(at)privatepilots.nl> wrote:
Hash: SHA1
> On 10/11/2013 12:09 PM, Alan Carter wrote:
> I am wiring my new FFM directly to the battery with fuse and
> switch, so in the event that If ever i kill the lot, I will still
> have engine running and fuel indications.
What's wrong with wiring the fuel pump to the alternator?
If you wire it to the battery, you are defying the purpose of the
master switch. In a crash landing, I wouldn't care whether the spark
that ignites my leaking fuel was coming from my GPS or from my fuel
indicators or fuel pump. (Not to mention the fact that the fuel pump
may continue to run after the crash, something you might not desire if
there is a fuel leak upstreams).
If you wire to the alternator, nothing can go wrong, assuming that the
engine will stop at impact and the electricity is long gone before you
come to a stop.
I must say that I'm a bit surprised how many people easily modify the
fuel system and/or electrical system, without understanding what the
reasons were why it was designed in that specific way.
Don't fix something that isn't broken!
Frans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=G2IX
Posted: Fri Oct 11, 2013 5:43 am Post subject: Battery questions |
Hash: SHA1
On 10/11/2013 02:47 PM, Pete wrote:
You can put a bleed resistor over the capacitor, which is a good
common practice with all large capacitors. About 500 ohms (for a 12V
setup) won't put a serious load on the capacitor but quickly drain it
in a few seconds once the feeding voltage disappears.
Frans
iQIcBAEBAgAGBQJSWABWAAoJEC+zXxqs0ZzVpGwP/iQ3J7pG1bBSIjdtoHb0MRUA
FQE+ZDFKDeQJtadz7b09dD8pdtJ6IQQkWrmDjtubPtUrksx/eLcMqypKBOAmBk1H
RP0FI4nn8YCbWiHBX7TT3ORQvorj+rZ+bWd4zjtPld0qWfkNsjKihUmQsxeK5rHz
nlUToR2dy0AbY5DZ3PXAyAE/Nd1fGdbXKtFQ2xz+NxdKrKxAIi2Sf/rszQQyWi4b
AAt3cHixdjy+bON8zjtBdMaMzlpJ2GAgfplgBUy8iNK6gdKgm+COT57js1jG0//a
yvTYLLh3+4OszO0S+4sOkhAAbfxR6XlgwXv5op+Tye6jZflpKpZe2JY7Zzb6TEVq
4XhWZ0pUTv0WXU1rSke6yMR+VPAXd4x8/a1nAznqLNUWsxYjJ6Ec9CTo1b/mjzst
9WvDannXmE5YteujFj2FQ6kP0pKKLABNIRHZzJbb+RMfNS5y26/6tj1UJzheW195
uTNciYyauYmASBBm1oH0DcThic0bRzsYA1B+jGPpJGiruCQ9np5xHuIP0Adn/faB
Gip5zbL9kUDp7hHJJg91gGMjpuKgG4M3y7f8j1+1Ms17lNpxNXKO+n00KCTCIUow
jJpeDvwEinnBnTlVgy69A1d+gHdVhtxIC1XB2oKd0gLOgxU5TIFdCOPHs0T83n+t
NvfpwrNpfW+48n0+cc1Y
=qYh9
Alan Carter
Joined: 02 Jul 2012 Posts: 378 Location: Kent, England.
Posted: Fri Oct 11, 2013 7:11 am Post subject: Re: Battery questions |
Hi Frans.
I am getting a bit lost here, I think you are saying if my Alternator Fails I won't get the spark to keep the engine running,
I am not sure if this is correct, surely my battery will keep the power to the ignition modules for a while.? or am I miss under standing you.
With ref to the mechanical pump I believe some 914 in the world have been fitted, there is usually a way to get round cooling, maybe a thermal barrier in the gasket, or water jacket, I am not doing any of these mods, but i have learnt a few things from this topic which I will check out, and hope they are as stated on the forum.
The 914 and the 912 I must say I find it hard to believe there is a huge temperature difference under the cowling, why is it so hot.
regards
Alan
Posted: Fri Oct 11, 2013 7:31 am Post subject: Battery questions |
Hash: SHA1
On 10/11/2013 05:11 PM, Alan Carter wrote:
<alancarteresq(at)onetel.net>
Hi Frans. I am getting a bit lost here, I think you are saying if
running,
There are mutiple coils in this alternator. Two are used for the
ignition, the rest for charging the battery.
| Quote: | I am not sure if this is correct, surely my battery will keep the
No, the ignition coils are not connected to the battery.
| Quote: | With ref to the mechanical pump I believe some 914 in the world
Why would you go that complicated route if there is a better solution?
| Quote: | The 914 and the 912 I must say I find it hard to believe there is a
The 914 has a turbo. A turbo compresses the inlet air. A side effect
of compressing air is that the temperature goes up. The inlet air
passes through the carbs after it has been compressed (and heated!) by
the turbo.
So, as the carbs have quite a higher temperature than in the 912, it
is not a good idea to feed them hot fuel as well. The combination of
heat and fuel lead to an increased change of vapor lock and detonation.
Hence the Rotax engineers made a few modifications to the fuel system:
1) The return feed is largely increased. This increases the flow, so
the fuel stays a shorter time in the cowling and heat is transfered away.
2) The mechanical fuel pump (a heat source) is eliminated and replaced
by cool running electrical pumps, that can remain outside of the hot
cowling.
3) By changing the location of the fuel pump the fuel hose routing can
be kept much shorter.
Think about it: When the Rotax engineers developed the 914 they had
already their convenient mechanical fuel pumps on the shelf. They sure
must have a good reason to block off the fuel pump connector on the
gear housing and change the whole setup.
It is not wise to revert back to mechanical pumps, especially since
there are no practical problems with the dual electrical pump setup.
Hundreds of airplanes are flying happily around with them.
Frans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=S322
Fred Klein
Posted: Fri Oct 11, 2013 8:32 am Post subject: Battery questions |
On Oct 11, 2013, at 8:30 AM, Frans Veldman wrote:
| Quote: | It is not wise to revert back to mechanical pumps, especially since
I recall a conversation years ago with an electrical engineer who was touting the advantages of electrical over mechanical devices.
"...with electrical things there is only on mode of failure...w/ mechanical things, all sorts of things can fail..."
m.j.gregory(at)talk21.com Guest
Posted: Fri Oct 11, 2013 8:35 am Post subject: Battery questions |
Alan,
To reinforce the point that Frans has made, it's helpful to recognise that
what is often referred to as "alternator failure" is actually failure of the
rectifier/regulator feeding DC to the 12/14 V electrical system (and in the
case of the 914 word according to the Europa circuit diagram, the 2nd
electrical fuel pump).
Failure of the actual alternator, which has permanent magnets rotating
inside the fixed stator, such that both of the 2 independent coils that
supply the ignition modules direct failed, would indeed be extremely rare.
The point made earlier about bypassing the the master switch to provide a
live feed from the battery to the trim switch was a subject of much
discussion back in 1996. Ivan Shaw was insistent that in the event of smoke
in the cockpit caused by a wiring fault, the immediate action would be to
turn off the master switch and land as soon as possible - but the aircraft
could be very difficult to control if they were large forces on the elevator
because the trim could not be adjusted. Similarly, in later years people
have fitted electrical stall warners - and again it would probably be a good
idea to have this system working while attempting a sensible forced landing.
The risk of either circuit (each protected by a very-low-value fuse) causing
a fire during a crash landing I personally believe to be acceptable.
Mike
Dr Mike Gregory
Europa Club Safety Officer
JonathanMilbank
Joined: 14 Apr 2012 Posts: 397 Location: Aberdeen area
Posted: Fri Oct 11, 2013 10:16 am Post subject: Re: Battery questions |
Jonathan,
I have been using a Varley Redtop 25 racing battery which is 16AH AGM
(absorbed glass matt). This is virtually identical spec to the Odyssey
PC680 which many people use for a Rotax 912S. It has provided perfect
starting for 6 years. The battery is behind the baggage bay and uses 4
gauge battery cables. I have never seen more than 14.2 volts system voltage
and on a fully charged battery it is mostly at 13.8 volts.
Provided you have good connections and big enough cable, I don't think you
will have any problems with a new Rotax 912S, even with the older starter,
as long as the sprag clutch is in good condition.
Brian Davies
Many thanks Brian. An endorsement is exactly what I needed.
Alan Carter
Posted: Fri Oct 11, 2013 12:20 pm Post subject: Re: Battery questions |
Hi All
Many thanks for the information given, there was a lot I did not know about the system, many of the points I agree with you all, but some I don't so will have to differ,
Sorry Mike but I would go along with Ivan Shaw, by turning the master off.
The trim forces from Straight and level to landing are minimal, my trim indicator only move a couple of divisions, stall warning I haven't , all I need is an ASI, next time I fly I will try a landing without touching the trim.
See how I get on.
How ever the wiring of the fuel pumps., I think think??? both of mine run on the ground with the Alternator Switch in the OFF position, is this standard, ie is the number 2 pump dual supplied by both battery and alternator.
Or should it not run
Regards.
Alan
Posted: Fri Oct 11, 2013 12:56 pm Post subject: Battery questions |
Alan,
Perhaps I did not make it clear that it was Ivan's point to insist that the
pitch trim should remain live if you had to switch off the master switch,
e.g. because of fumes in the cockpit, and he wanted to ensure that you did
not have to fight high stick forces while trying to concentrate on landing.
There is of course nothing to stop you switching off the trim and any other
still live circuits once you are committed to a forced landing and are
making the final approach.
If you have one pump being fed directly from the alternator and the other
from the bus bar, then they will both run when the engine is running
regardless of whether the alternator switch is closed or open. You can then
turn off the master switch connecting the bus to the battery, and you should
find that the pump fed by the alternator remains running while the other
stops. This is as close as you can get to independent power supplies for
essential services when you have just one battery and one alternator.
Mike
Posted: Fri Oct 11, 2013 1:15 pm Post subject: Battery questions |
Alan, Back in 2003 I was flying on my own out to Czech
Republic, and approaching the border there was nothing but
forest from horizon to horizon, and I was thinking what a
bad place it would be for the engine to pack up! This
thought possibly got to my bladder so I got my pee bottle
out from under the left side of my thigh rest and
leisurely sorted myself out. When I was all zipped up and
strapped in again I looked at the panel to find to my
dismay that everything electrical was showing no sign of
life! My two electrical pumps immediately sprang to mind
and I started a rapid check round the panel. I found that
both master and alternator switches were off, having
caught my left trouser bottom on the toggles. I switched
them back on before there was any squeak from the engine
and breathed a very big double sigh of relief!
Being a public spirited sort of chap I felt I should
own up on this forum to stop anyone else being so dumb and
possibly not being so lucky. One of the technical whizzes
from the company answered to say that as long as I had
wired it to the standard instructions the engine would not
stop anyway, and I checked this to be the case on my next
flight.
I would personally avoid doing any landings out
of trim unless you cannot avoid it. You just need some
other distraction for things to go seriously pear shaped.
Half the ditching deaths in the Uk in the last 22years
were actually due to the pilot losing control and
effectively crashing, almost certainly because they had
suddenly remembered they hadn't got their lifejacket on or
their PLB out of the back, or whatever, and forgot about
flying the plane.
Alan Carter
Posted: Fri Oct 11, 2013 2:18 pm Post subject: Re: Battery questions |
Hi David.
You have flown to some wonderful places, Im UK only no longer have that confidence, when i was in my 20s yes I would have.
Im no expert on the plane never looked into it, but all the planes I have flown the engine is entirely separate from the aircrafts electrics and you have just confirmed that with Master off and Alternator off and the a pump and spark keeps the engine going, or should do.
So the spark is not influenced by either switch,
and the pump get it power from either a separate circuit within the Alternator or the battery which will slowly run down.
Rotax must say somewhere how long you have on battery and pump only.
or maybe not?
We know with the Master and Alternator off the engine will run OK.
But with a serviceable system how do I check its failure capabilities ??
Alan
Posted: Sat Oct 12, 2013 12:12 am Post subject: Battery questions |
Alan, I get the impression that you are doing your very
best to reinvent the wheel here. It ain't bust! Why try
and fix it? David Joyce
On Fri, 11 Oct 2013 15:18:14 -0700
"Alan Carter" <alancarteresq(at)onetel.net> wrote:
Hi David.
would have.
run down.
and pump only.
or maybe not?
will run OK.
capabilities ??
Alan
http://forums.matronics.com/viewtopic.php?p=410354#410354
Un/Subscription,
Forums!
Admin.
craigb(at)onthenet.com.au Guest
Posted: Sat Oct 12, 2013 1:30 am Post subject: Battery questions |
Please keep in mind also that most fully wound type alternators will continue to charge
As long as their speed is above about 800 rpm, even if the battery is completely removed
| Quote: | From the system, so on a permanent magnet alternator the result would be the same, so as long
As the electric fuel pump and ignition (for the non magneto users) feed directly from the alternator which I believe someone Said is the case then you should be able to turn off the master and keep flying, shouldn’t you?
carl(at)flyers.freeserve. Guest
Posted: Sat Oct 12, 2013 7:23 am Post subject: Battery questions |
As stated by others the charging/ electrical power coils are separate from the ignition coils - basically as long as the engine is turning there will be power to the ignition circuit.
We had an instance not so long ago where the ignition switch failed to short out the ignition circuit and the engine continued to run even though we had switched everything off. This is the normal arrangement for the majority of aircraft systems (ie: ignition will function even if the switch fails). The only way to stop the engine is to shut off the fuel.
I'm a little puzzled though as to why the Rotax 914 has electric fuel pumps instead of the mechanical pump used on the 912 - anyone know the reason for this - or is a mechanical fuel pump optional.
I had a look at the Rotax brochure on the 914 and the photo would suggest that a mechanical pump could be fitted if desired.
Alan Carter
Posted: Sat Oct 12, 2013 9:40 am Post subject: Re: Battery questions |
Hi Carl.
If you look back a few post Frans gave an explanation of why the 914 has electric pump,
No David not trying to invent the wheel, but its as I thought in the first place the Master switch has no part to play in keeping the engine running,
It all started from why is there no Mechanical Pump on the 914 , Rotax opted for a Dual electrical system, Personally I like Alternative system, ie
Air, hydraulic, Mechanical, Vacuum, so I think the 912 has a better system, My Choice is, Alternative systems,
Craigb.
Old Honda Civic, Alternator no battery, towed and bump started, engine run.
Regards.
Alan
Posted: Sat Oct 19, 2013 2:42 am Post subject: Battery questions |
Alan, I work on the assumption that if I keep my Odyssey
battery in good nick and replace it before it dies then I
should have a significant proportion of the nominal17 amp
hrs available when/if the rectifier packs up. The Rotax
maintenance manual gives the current demands of the pump
as 2 amps at lower pressures rising to 3 at highest
pressure. With the ammeter fitted to my plane I can
readily see what usage I have as I switch off inessential
items. As I remember it when my rectifier packed up over
the North Sea the fuel pump took something nearer 2 amps
than 3 with radio on as well.
I wouldn't rely on being able to fly for lots of
hours over sea but would be pretty comfortable about
flying a few hours over land to get home, rather than put
down somewhere totally inconvenient and get stuck until a
new rectifier arrived. For glider pilots this is after
all, the normal modus operandi, and you get to be fairly
relaxed about popping it into a field if your means of
staying airborne disappears!
Regards, David Joyce, G-XSDJ
Hi David.
would have.
run down.
and pump only.
or maybe not?
will run OK.
capabilities ??
Alan
Un/Subscription,
Forums!
Admin.
Alan Carter
Posted: Sat Oct 19, 2013 12:39 pm Post subject: Re: Battery questions |
Hi David.
That all seems reasonable, nothing to gripe there,
But to check the wiring and operation of a working serviceable system, and see it is functioning correctly as per wiring if correctly done, as there is no testing circuit, I guess the only way is to have the engine running and remove on of the battery leads, to check the engine and pumps will solely running on the power from the Alternator. Maybe some one has a better way to check this.
Alan
Posted: Sun Oct 20, 2013 1:56 am Post subject: Battery questions |
Alan, If your master switch is wired correctly switching
that off has much the same effect as disconnecting the
battery. Regards, David
On Sat, 19 Oct 2013 13:39:09 -0700
Hi David.
this.
Alan
http://forums.matronics.com/viewtopic.php?p=410884#410884
Un/Subscription,
Forums!
Admin.
Posted: Sun Oct 20, 2013 2:22 am Post subject: Battery questions |
Hash: SHA1
On 10/19/2013 10:39 PM, Alan Carter wrote:
| Quote: | But to check the wiring and operation of a working serviceable
this.
Make sure the capacitor is installed if you do that. Without the
capacitor, the system may start surging, destroying all running
avionics in the process.
The capacitor acts as a very tiny battery, just large enough to buffer
some of the charge, damping out oscillations in the voltage feed back
system of the "rectifier".
Frans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=bpUo
