houlihan(at)blueyonder.co Guest
Posted: Sun Oct 20, 2013 3:02 am Post subject: Battery questions |
HI Fran.
Having had a regulator failure recently I agree with your message though in my case the capacitor then failed within a few minutes and vented its internals past the windscreen.
Just for information if you have the Schicke regulator installed they say that the capacitor is no longer required, also over ten years ago I fitted the overvoltage protection module that was widely mentioned in the Europa Flyer of the time. This actually worked for me and maybe it saved my radio and transponder and other stuff from being damaged .
G-BZTH
On 20 October 2013 11:22, Frans Veldman <frans(at)privatepilots.nl (frans(at)privatepilots.nl)> wrote:
[quote]--> Europa-List message posted by: Frans Veldman <frans(at)privatepilots.nl (frans(at)privatepilots.nl)>
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 10/19/2013 10:39 PM, Alan Carter wrote:
> But to check the wiring and operation of a working serviceable
> system, and see it is functioning correctly as per wiring if
> correctly done, as there is no testing circuit, I guess the only
> way is to have the engine running and remove on of the battery
> leads, to check the engine and pumps will solely running on the
> power from the Alternator. Maybe some one has a better way to check
> this.
Make sure the capacitor is installed if you do that. Without the
capacitor, the system may start surging, destroying all running
avionics in the process.
The capacitor acts as a very tiny battery, just large enough to buffer
some of the charge, damping out oscillations in the voltage feed back
system of the "rectifier".
Frans
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.18 (GNU/Linux)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=bpUo
-----END PGP SIGNATURE-----
target="_blank">http://www.matronics.com/Navigator?Europa-List
http://forums.matronics.com
le, List Admin.
creightonious
Posted: Sun Oct 20, 2013 5:39 am Post subject: Battery Questions |
This is an interesting thread.
But we must all keep in mind that the "nominal" 17 amp hours of the Odyssey battery (or of any other) is predicated on a 20 hour discharge rate and has an endpoint of 11volts.
Therefore any discharge rate over one (1) amp will result in a battery capacity of far under 17ah. At even at a 3 amp discharge rate a fresh Odyssey 17 ah battery will be perilously close to complete discharge after 3 hours.
Food for thought.
Creighton Smith Classic EFI 912
[quote] On Oct 20, 2013, at 3:02 AM, Europa-List Digest Server <europa-list(at)matronics.com> wrote:
Today's complete Europa-List Digest can also be found in either of the
of the Europa-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 13-10-19&Archive=Europa
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 13-10-19&Archive=Europa
Europa-List Digest Archive
Total Messages Posted Sat 10/19/13: 10
Today's Message Index:
1. 03:42 AM - Re: Re: Battery questions (David Joyce)
2. 03:56 AM - Re: Classic Centre Console (spcialeffects)
3. 04:21 AM - Dummy spars (spcialeffects)
4. 05:09 AM - Re: Re: Classic Centre Console (Carl Pattinson)
5. 06:42 AM - KEVV - Evansville Indiana EAA Chapter 21 Wings and Wheels this weekend (Steve Eberhart)
6. 08:16 AM - Re: Dummy spars (Andrew Sarangan)
7. 08:43 AM - Re: Dummy spars (David Joyce)
8. 08:49 AM - Re: Dummy spars (Richard Wheelwright)
9. 10:00 AM - Re: Dummy spars (Rob Housman)
10. 01:39 PM - Re: Battery questions (Alan Carter)
________________________________ Message 1 _____________________________________
Time: 03:42:23 AM PST US
Subject: Re: Re: Battery questions
Alan, I work on the assumption that if I keep my Odyssey
battery in good nick and replace it before it dies then I
should have a significant proportion of the nominal17 amp
hrs available when/if the rectifier packs up. The Rotax
maintenance manual gives the current demands of the pump
as 2 amps at lower pressures rising to 3 at highest
pressure. With the ammeter fitted to my plane I can
readily see what usage I have as I switch off inessential
items. As I remember it when my rectifier packed up over
the North Sea the fuel pump took something nearer 2 amps
than 3 with radio on as well.
I wouldn't rely on being able to fly for lots of
hours over sea but would be pretty comfortable about
flying a few hours over land to get home, rather than put
down somewhere totally inconvenient and get stuck until a
new rectifier arrived. For glider pilots this is after
all, the normal modus operandi, and you get to be fairly
relaxed about popping it into a field if your means of
staying airborne disappears!
Regards, David Joyce, G-XSDJ
On Fri, 11 Oct 2013 15:18:14 -0700
> Hi David.
> You have flown to some wonderful places, Im UK only no
> longer have that confidence, when i was in my 20s yes I
> would have.
> Im no expert on the plane never looked into it, but all
> the planes I have flown the engine is entirely separate
> from the aircrafts electrics and you have just confirmed
> that with Master off and Alternator off and the a pump
> and spark keeps the engine going, or should do.
> So the spark is not influenced by either switch,
> and the pump get it power from either a separate circuit
> within the Alternator or the battery which will slowly
> run down.
> Rotax must say somewhere how long you have on battery
> and pump only.
> or maybe not?
> We know with the Master and Alternator off the engine
> will run OK.
> But with a serviceable system how do I check its failure
> capabilities ??
> Regards
> Alan
> http://forums.matronics.com/viewtopic.php?p=410354#410354
> Un/Subscription,
> Forums!
> Admin.
________________________________ Message 2 _____________________________________
Time: 03:56:44 AM PST US
Subject: Re: Classic Centre Console
So after much thought I have decided to do mod 24, however I'm abit scared to make
the first cut of the centre console as it seems to be quite a drastic mod
to get extra bum room but I am going to do it. I just wanted to ask, before I
start it, to anyone here who has done this mod if they could post some pictures,
give any tips but most of all how far into the tunnel did you go? I.e how much
extra bum space did you achieve. Now the instruction sheet I have says to
make sure you miss the rudder cables and flap arm but I am looking at doing this
mod with the bear module so it is easier to lay up the inside so any measurements
would be appricated. Failing all of that if you are selling an XS module
please contact me also. Thanks Frank
http://forums.matronics.com/viewtopic.php?p=410863#410863
________________________________ Message 3 _____________________________________
Time: 04:21:13 AM PST US
Subject: Dummy spars
If anyone has a set of dummy spars I could borrow or buy I would be very grateful
as this will allow me to put my fuselage in many more positions within my workshop
then rigging the wings. Thank Frank
http://forums.matronics.com/viewtopic.php?p=410864#410864
________________________________ Message 4 _____________________________________
Time: 05:09:04 AM PST US
Subject: Re: Re: Classic Centre Console
From: Carl Pattinson <carl(at)flyers.freeserve.co.uk>
I don't have a copy of mod 24 to hand but seem to remember the factory method was
a bit of a "bodge" IMHO which is why we opted for a different solution. We
created our LA inserts on the workbench (in the shape of a half kidney) then
reduxed them onto the hole we had cut in the cockpit module sides - then 4 layers
of bid inside and outside at the join edges for added strength.
I would be inclined to leave this as late in the build as possible as you really
need the swinging arm and tyre in place to get an accurate fit. We got it wrong
first time around and the tyre jammed in the up position - solved that little
hitch by fitting a narrower tyre and judicious use of a hot air gun to reform
the bulge in the LA inserts.
With hindsight I think it would be possible to construct the innermost bid layer
of the LA bulge once the wheel was in place. It would then be relatively easy
(once cured) to bond in the thin foam layer and complete the outside layers
of bid from outside. If you had access to a vacuum pump you could vacuum mould
the foam and bid layers onto the original inner layers of glass which would give
a strong air free structure.
I have some pics somewhere - will try and dig them out.
Carl Pattinson
G-LABS
Sent from my ASUS Pad
make the first cut of the centre console as it seems to be quite a drastic mod
much extra bum space did you achieve. Now the instruction sheet I have says to
________________________________ Message 5 _____________________________________
Time: 06:42:43 AM PST US
Subject: KEVV - Evansville Indiana EAA Chapter 21 Wings and Wheels
this weekend
Our Third Annual Wings and Wheels event is this Saturday
We have had over 200 Cruisers at each of our first two Wings and
Wheels This year should continue building on our great start.
Cruise-In or Fly-In and help us set a new attendance record this year
10:00 AM till 3:00 PM Central time.
Tri-State Aero (KEVV), Ramp and Parking Lot.
Here are some pics of previous Wings and wheels. Our 2013 Wings
and Wheels event will be at Tri-State Aero October 19th, 2013.
http://www.eaa21.org/WingsandWheels.jpg
http://www.youtube.com/watch?v=ka1Sg7tmULc
http://www.eaa21.org/coppermine1/thumbnails.php?album=2
________________________________ Message 6 _____________________________________
Time: 08:16:37 AM PST US
Subject: Re: Dummy spars
I do have a dummy spar which I have no use for, so I can send it to
you if needed.
On the other hand, I wouldn't recommend using the dummy spars for
aligning the spars to the cockpit module. It only takes a fraction of
a mm misalignment of the bushings to make the pin insertion and
retraction very stiff.
> On Sat, Oct 19, 2013 at 7:20 AM, spcialeffects <spcialeffects(at)aol.com> wrote:
workshop then rigging the wings. Thank Frank
________________________________ Message 7 _____________________________________
Time: 08:43:49 AM PST US
Frank, I would advise making your own, lining them up
precicely on your wing spars and only doing it when you
are ready to use them. If they are made of wood or most
anything non metallic there is a danger of change in
humidity altering their dimensions oherwise. Regards,
David Joyce, G-XSDJ
On Sat, 19 Oct 2013 11:15:42 -0400
> send it to
> you if needed.
> spars for
> a fraction of
> insertion and
>> I would be very grateful as this will allow me to put my
>> fuselage in many more positions within my workshop then
> Un/Subscription,
> Forums!
> Admin.
________________________________ Message 8 _____________________________________
Time: 08:49:04 AM PST US
From: "Richard Wheelwright" <rpwheelwright(at)yahoo.co.uk>
Frank,
I also recommend using the wings.
I also have a dummy spar you can have (Never Used)
Richard Wheelwright
G-IRPW
First Flight 24th July 2013
http://forums.matronics.com/viewtopic.php?p=410872#410872
________________________________ Message 9 _____________________________________
Time: 10:00:38 AM PST US
Subject: RE: Dummy spars
I must take exception to the part about "...make the pin insertion and
retraction very stiff." In my case the word "impossible" is substituted for
"stiff." The "dummy" in dummy spar is the builder who uses it.
Best regards,
Rob Housman
Europa XS A070
Rotax 914
Airframe complete
Avionics a work in progress
_________________ Creighton Smith
A 036 |
Posted: Sun Oct 20, 2013 6:59 am Post subject: Battery Questions |
Creighton, If you look at the Odyssey technical manual for
the p680 you will find they give 8 hrs for a 2amp
discharge rate and 5hrs for the 3amp discharge. Perhaps
what you say applies to ordinary lead acd batteries but
not to the superior technology of the Odyssey.
Regards, David Joyce, G - XSDJ
On Sun, 20 Oct 2013 09:38:58 -0400
hours.
Food for thought.
>either of the
>Digest formatted
>Hyperlinked Indexes
>plain ASCII version
>generic text editor
> HTML Version:
> Text Version:
>10
>Joyce)
> (spcialeffects)
>Pattinson)
> From: "David Joyce" <davidjoyce(at)doctors.org.uk>
>I
>amp
>inessential
>put
>a
>> Hi David.
>> would have.
>> run down.
>> and pump only.
>> or maybe not?
>> will run OK.
>> capabilities ??
>> Regards
>> Alan
>> Un/Subscription,
>> Forums!
>> Admin.
> From: "spcialeffects" <spcialeffects(at)aol.com>
>quite a drastic mod
>a half kidney) then
>strength.
>the outside layers
> Carl Pattinson
> G-LABS
>did you go? I.e how
> From: Steve Eberhart <steve(at)newtech.com>
> this weekend
>Saturday
>two Wings and
>great start.
> Our 2013 Wings
>19th, 2013.
> From: Andrew Sarangan <asarangan(at)gmail.com>
>send it to
> you if needed.
>spars for
>a fraction of
>insertion and
>positions within my
> David Joyce, G-XSDJ
>> send it to
>> you if needed.
>> spars for
>> a fraction of
>> insertion and
>>> Read this topic online here:
>> Un/Subscription,
>> Forums!
>> Admin.
> Frank,
> Richard Wheelwright
> G-IRPW
> From: "Rob Housman" <rob(at)hyperion-ef.com>
>insertion and
>uses it.
> Best regards,
> Rob Housman
> Europa XS A070
> Rotax 914
> Airframe complete
frans(at)privatepilots.nl Guest
Posted: Mon Oct 21, 2013 1:52 am Post subject: Battery Questions |
Hash: SHA1
On 10/20/2013 04:59 PM, David Joyce wrote:
Quote: | Creighton, If you look at the Odyssey technical manual for the p680
you will find they give 8 hrs for a 2amp discharge rate and 5hrs
This is for optimum conditions:
1) Perfect temperature
2) Perfect charge state
3) Fresh battery
In reality you can't count on the advertised capacity.
1) In cold weather the battery capacity can easily be 50% of the
advertised capacity. Elevated temperatures (like under the cowling)
are detrimental as well.
2) A full charge van only be obtained when charging with at least 14.5
Volts. My experience with the Rotax "rectifier" is that it tapers of
at around 13.7 Volts. This is good for battery life, but it means you
will roughly only get 70% of the capacity.
Furthermore, the startup sequence can consume quit some capacity, and
it takes a while to recharge this loss. If you get the engine failure
soon after the take off, the recharging might not have been completed.
Last but not least quite some capacity can get lost between the time
of the alternator failure and the pilot taking appropriate action. If
a "low voltage" warning is your first sign of trouble, it means you
have trouble indeed because the battery has already given away most of
its precious amp-hours.
3) Batteries age. Some people keep the battery for 4 years or longer.
Much of the capacity is gone by then, but you won't notice a thing
until you really need it. Voltage does not sag due to aging, and
starting will remain as usual. As soon as starting capacity is
noticably going down, you have lost about 90% of the capacity.
It might be a good thing to measure the capacity of the battery once a
year. Put on the fuel pump and a few other necessities, and measure
how much time it takes before you hit 11 Volts.
Note that such a run down test is bad for the battery but if you do
that only once a year it doesn't matter too much.
Quote: | Perhaps what you say applies to ordinary lead acd batteries but not
It is still a lead acid battery and all the physics apply to it
nevertheless.
Anyway, I wouldn't count on an advertised capacity; I would land as
soon as possible if the battery is the only current source to keep the
fuel pump going.
Frans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=bNaj
Posted: Mon Oct 21, 2013 3:23 am Post subject: Battery Questions |
Frans, As always there is much in what you say, but an
Odyssey is a gas recombinant lead acid battery and has
many characteristics quite different from conventional
lead acid batteries, such as the ability to withstand many
cycles of deep discharge, to have a significantly longer
life, to work normally at very cold temperatures and more
specifically to charge to 97% on a voltage of just 13.5v
and to retain 80% of its rated capacity until the end of
its useful life.
None of that of course makes it a good idea to be
in the habit of flying around assuming that it will keep
the pumps going for hours!
Regards, David
On Mon, 21 Oct 2013 11:50:31 +0200
Hash: SHA1
>for the p680
>and 5hrs
3) Fresh battery
50% of the
the cowling)
at least 14.5
it tapers of
it means you
capacity, and
engine failure
been completed.
between the time
it means you
given away most of
years or longer.
notice a thing
aging, and
capacity is
capacity.
battery once a
and measure
but if you do
>batteries but not
apply to it
nevertheless.
would land as
source to keep the
fuel pump going.
Frans
=bNaj
Un/Subscription,
Forums!
Admin.
Fred Klein
Posted: Mon Oct 21, 2013 7:36 am Post subject: Battery Questions |
This is an issue I've spent a lot of time on recently as I endeavor to ensure safe flight following an alternator failure in my totally electrically dependent MPEFI engine. Much of that time has been spent on the AeroElectric-list (at) matronics which I've found to be an excellent source of information...particularly for one who is an electrical neophyte.
One of the things I've learned is that a battery's (available) cranking power says nothing about it's ability to provide sustained power when there's a significant load. Don't assume that just because it could start the engine it has an ample reserve of amps to be drawn upon.
In my case, the total draw of fuel pump, ECU, fuel injectors, and coils is between 10 and 11 amps...add to that the draw for minimal components on an endurance bus (intercom, xpndr, some minimal cockpit lighting, etc.).
At this point as I continue to refine a basic circuitry diagram, among other things, I will have 2 Odyssey 680s wired as one, and will replace one at some interval (either annually, bi-annually, or at some interval as experience dictates) in order to raise the level of probability that alternator failure will be a low pucker factor event.
..on this misty morning, a pair of bald eagles taunt me over the sea beyond my kitchen window,
Fred
klinefelter.kevin(at)gmai Guest
Posted: Mon Oct 21, 2013 5:22 pm Post subject: Battery Questions |
Atta Boy Fred,
I went with a second alternator on the 914 and one PC680. I have our Subaru Legacy fitted with a PC680, so when I pull the battery every two years out of the Europa, it goes in the car for two years. Just about the time the car seems to crank a little slower in cold weather, it's two years are up.
Kevin
...on this misty morning, a pair of bald eagles taunt me over the sea beyond my kitchen window,
Fred
f.kyle(at)sympatico.ca Guest
Posted: Tue Oct 22, 2013 5:41 am Post subject: Battery questions |
At the risk of sounding the Old Man Bell, may I support Fred, Frans, Kevin and David in their suggestions on care and feeding of batteries?
The F-86 had four hydraulic systems mainly because one is never enough. Without suitable hydraulic power, the Sword became a lawn dart as there was no direct physical connection with the flight controls. The engine produced preferred hydraulic pressure, the battery a back-up.
The word was - if you must reduce demand from or shut down the engine, the battery would produce sufficient power to operate one system and get you back to the bar in good order. With this puerile acceptance we wheeled and spun about the blue.
One day, a thinking Engineering Officer cranked a Sword up on orange boxes and sat aboard with only the battery, gear retracted, wheeling and dealing with abandon. Of course there was no resistance from moving the flight controls in the air at speed, but it lasted four and a half minutes. Even supersonic dives couldn’t get you on the runway before she froze.
In those days there was no hacking of the web, so everything was done by telephone. Don’t tell the drivers - so alternate circumstances grounded each machine until new batteries were tested and installed. I still think about this, sixty-five years later.
Mind the battery.
Ferg
Fred Klein
Posted: Tue Oct 22, 2013 8:39 am Post subject: Battery questions |
Love it Ferg...thanks...Fred
On Oct 22, 2013, at 6:43 AM, <f.kyle(at)sympatico.ca (f.kyle(at)sympatico.ca)> <f.kyle(at)sympatico.ca (f.kyle(at)sympatico.ca)> wrote:
[quote] At the risk of sounding the Old Man Bell, may I support Fred, Frans, Kevin and David in their suggestions on care and feeding of batteries?
Alan Carter
Joined: 02 Jul 2012 Posts: 378 Location: Kent, England.
Posted: Thu Oct 24, 2013 1:23 pm Post subject: Re: Battery questions |
Hi All.
Went flying today first time for a couple of weeks.
Tested out a few things, on the 914.
Master Switch OFF, Alternator On, engine kept running,
Alternator OFF, Master ON, engine kept running, Ammeter 11.9
Both OFF, engine kept running ,Alternator providing spark, then later stopped starved of fuel.
I must say even sitting on the ground when the engine quit it was alarming, I was under the impression it was the same as the spark, with its own little separate circuitry that would keep one pump going regardless of switch position.
Having seen 11.9 volts on battery with everything turned off , I think I would make for the nearest airfield, Anyone every done a test on this, Obviously it will depend on how good you battery is, so a middle of the road figure would be useful.
Regards.
Alan
