goff
Posted: Wed Oct 23, 2013 4:12 am Post subject: Coolant Radiator |
The coolant radiator in G-CHOX (XS Rotax 912ULS) is leaking. We need to replace it asap. Europa O4 are out of stock.
Does anyone know of any other source?
Goff Moore
289.19 KB |
15016 Time(s) |
pjlevi(at)gmail.com Guest
Posted: Wed Oct 23, 2013 5:36 am Post subject: Coolant Radiator |
Goff,
Mine is a Rotax UL but I had the same problem last April and Europa factory could not help. It is actually a motor cycle radiator and my engineer contacted the original manufacturers (who had previously supplied Europa). I know they provided an excellent service very quickly, they did not replace the radiator but repaired it and gave it a full renovation job for about a third of the cost Europa would have charged for a new one. It came back looking like new and in perfect condition.
I have spoken to my engineer and inspector, Gary Johnson, he recalls (from memory) it was a company in Saffron Walden, but will check out the name and contact details tonight and send them to you. He can be contacted on <thehighflyer(at)aol.com (thehighflyer(at)aol.com)> .
I have just searched on Google and found a firm of motor cycle repairers and restorers in Saffron Walden called Motorcycle Restoration Company (next to Audley End Station), Unit 3, Wenden Court, Station Road, Wendens Ambro, Saffron Walden, Essex, CB11 4LB, tel. 01799 542323/07734 591456, www.motorcyclerestorationcompany.com. There is also another motorcycle shop in Saffron Walden, Bert's Motorcycles, 13b Debden Road, Saffron Walden, Essex, CB11 4AA, Tel. 01799 525611. I have no idea whether it was either of them or neither, but worth a phone call. Otherwise contact Gary tonight or he will contact you.
Yours sincerely,
Philip
Philip J. Levi
Europa Monowheel Classic, G-BWWB , based at Old Warden.
On 23 October 2013 13:12, goff <goffmoore(at)aol.com (goffmoore(at)aol.com)> wrote:
[quote] --> Europa-List message posted by: "goff" <goffmoore(at)aol.com (goffmoore(at)aol.com)>
Goff Moore
http://forums.matronics.com/viewtopic.php?p=411177#411177
http://forums.matronics.com//files/rad_dimensions_115.jpg
target="_blank">http://www.matronics.com/Navigator?Europa-List
le, List Admin.
mike.davies210(at)gmail.c Guest
Posted: Wed Oct 23, 2013 5:55 am Post subject: Coolant Radiator |
Try Neville Eyre he may be able to help
He had one made for me last year
Mike G-MLXP On Oct 23, 2013 1:15 PM, "goff" <goffmoore(at)aol.com (goffmoore(at)aol.com)> wrote:[quote] --> Europa-List message posted by: "goff" <goffmoore(at)aol.com (goffmoore(at)aol.com)>
Goff Moore
le, List Admin.
kjburns(at)btinternet.com Guest
Posted: Wed Oct 23, 2013 6:04 am Post subject: Coolant Radiator |
Try Richard at
http://www.eesaviation.com/ Has had radiators repaired, and if really bad re-cored , his contact details are
01858 880807 His hanger / workshop is at Coventry Gliding club ...Hanger 3 , LE17 6JJ,
Kevin
Sent: Wednesday, 23 October 2013, 13:12
Subject: Europa-List: Coolant Radiator
Goff Moore
http://forums.matronics.com//files/rad_dimensions_115.jpst" target="_blank">http://www.matronics.com/Navigator?Europa-List [quote][b]
Posted: Wed Oct 23, 2013 6:08 am Post subject: Coolant Radiator |
Hi! Geoff ........from the dim and distant past I'm thinking Matco/Masters
Auto Radiators but I can't seem to turn up anything other than that probably
Neville will jump in with a conversion part number. I would have thought
Europa would give you a guide
Bob Harrison. G-PTAG
frans(at)privatepilots.nl Guest
Posted: Thu Oct 24, 2013 1:55 am Post subject: Coolant Radiator |
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Take a look at www.aluminiumradiators.com
They produce the Rotax radiators. The quality is high, support is
excellent and the prices are very reasonable.
They are also quite easy at building radiators at custom spec. I had
my special radiator made there too.
If you replace the standard SX-radiator, you might consider to make it
"thinner" (less "depth"). Although this sounds contradictionary, this
improves the airflow through the radiator and enhances cooling. The
standard radiator is way too thick.
Think about it this way: the air flowing through the radiator is
picking up heat. When it arrives at the rear half of the radiator, the
air has been warmed up during its journey through the front half, and
is unable to offer much further cooling.
The math says that if you double the depth of the radiator with 100%,
it only offers 25% more cooling. However the airflow reduces due to
internal friction, so at some point a thicker radiator will even offer
less cooling than a thinner one. The Europa-XS radiator is way past
the top of that curve, especially at lower airspeeds (like on the ground).
You won't find such a thick radiator in other modern airplanes. Yes,
the P51 had a thick radiator, but it was flying with quite a different
speed than your Europa.
In my airplane I have a thin radiator, and it was only when I took out
the large bulky radiator that all my cooling issues disappeared.
So, if you have to swap your radiator anyway, it might well worth it
to allow for a little improvement.
Frans
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.18 (GNU/Linux)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=NmR0
-----END PGP SIGNATURE-----
goff
Posted: Thu Oct 24, 2013 7:42 am Post subject: Re: Coolant Radiator |
Philip, Gary, Mike, Kevin, Bob & Frans,
Thanks so much for your replies, so many good sources out there. I've learned a lot.
Based on Philip & Gary's recommendation we shipped our radiator for repair today to http://www.gmxradiators.co.uk/
This is probably the cheapest and easiest option for us at the moment, but I love Frans' idea of a thinner rad. For five years we've had to manage coolant temperatures rather than forget about them. We'll certainly look into this.
Goff
goff
Posted: Thu Oct 24, 2013 7:58 am Post subject: Re: Coolant Radiator |
Frans,
Your link to www.aluminiumradiators.com doesn't work.
Do you have another?
Goff
N6ZY
Posted: Thu Oct 24, 2013 8:17 am Post subject: Coolant Radiator |
The correct address is www.aluminiumracing.com, and I can vouch for the quality of their rads. The one I got from them was beautifully made, and considerably cheaper than the Rotax one.
Jerry Fisher
neveyre(at)aol.com Guest
Posted: Thu Oct 24, 2013 8:34 am Post subject: Coolant Radiator |
Philip,
I'm afraid I have to tell you, you are talking out of your southern hemisphere !
The XS radiator was made specifically for Europa, by a well established Motorsport supplier, never was from a motorcycle, and not from anyone in Saffron Walden, or in fact anywhere in Essex. I know who and where, 'aint in Essex !
The company who make these for Europa have a very long lead time, I understand a new batch is due to arrive at Europa some time very soon. Having one custom made will cost more than having a stock one from Europa.
Having said that, I would look at having the original one repaired, any good alloy welder could do it easily. Do a pressure test, in a bucket of water to be sure all is well before refitting.
Nev.
paul.the.aviator(at)gmail Guest
Posted: Thu Oct 24, 2013 8:46 am Post subject: Coolant Radiator |
Hi
Had mine repaired and pressure tested for $50 by local radiator shop. Failing that I have a second hand one that I probably won't use if you want to buy it.
Paul
On Thu, Oct 24, 2013 at 11:33 AM, Neville Eyre <neveyre(at)aol.com (neveyre(at)aol.com)> wrote:
[quote] Philip,
Nev.
tonyrenshaw268(at)gmail.c Guest
Posted: Thu Oct 24, 2013 1:38 pm Post subject: Coolant Radiator |
Hi Philip,I live in the Southern Hemisphere, and whilst I know most of the worlds population doesn't, we have feelings down under. We aren't precious though.
TR
[quote]On Thu, Oct 24, 2013 at 11:33 AM, Neville Eyre <neveyre(at)aol.com (neveyre(at)aol.com)> wrote:
[quote] Philip,
Nev.
