		rv10flyer(at)live.com Guest
				 Posted: Tue Oct 29, 2013 8:23 am    Post subject: power settings for descent or climbs |
				Looking for the initial reduction/increase power change needed for climbs  or descents to keep the same airspeed? (example- landing at 120kts, aircraft is  setup at cruise to be at 120kts when reach OM, how much power would I need to  pull for every 100 fpm? so if it’s 500fpm it would be 5X that setting)
  Thank you!
  Pascal
		Jim Berry
				 Posted: Tue Oct 29, 2013 9:18 am    Post subject: Re: power settings for descent or climbs |
				If you are landing at 120 K, I hope you have a very long runway. Only partially answering your question, I get the following from my -10:
 17" clean = 120K
 15" clean = 110K
 12" & flaps1 = 85K with 500 fpm descent
 Jim Berry
 RV-10
				 Posted: Tue Oct 29, 2013 10:12 am    Post subject: power settings for descent or climbs |
				Here is a start I did for this.  Adjust as needed.
 I have been using 120 knots for initial approach, 100 knots at the IAP, and 87 knots at the FAF (full flap speed).
 Carl
 N7ZK Power/Speed Configuration Setting
                         May 26, 2013
                                     MP      RPM   IAS     VS
 Climb                          24        2400    130      1000
 Cruise Dec                 14        2300    130      -500
                                     18        2350    170      -500
 Appr Level                 18        2200    120       ----
 Prec Appr Dec           14        2200    87        -300
 N-Pres Appr Dec       12        2200    87        -700
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal
 Sent: Tuesday, October 29, 2013 12:24 PM
 Subject: power settings for descent or climbs
 Thank you!
 Pascal
  	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?RV10-List  | 	  01234567
				 Posted: Tue Oct 29, 2013 10:40 am    Post subject: power settings for descent or climbs |
				Thank you Carl! what I was looking for as a start.
  Pascal
   From: Carl Froehlich (carl.froehlich(at)verizon.net)
  Sent: Tuesday, October 29, 2013 11:12 AM
  Subject: RE: power settings for descent or  climbs
 Carl
                          May 26, 2013
                                      MP      RPM   IAS      VS
                                      18        2350     170      -500
 To:  rv10-list(at)matronics.com
 Thank  you!
 Pascal
 8
		Kellym
				 Posted: Tue Oct 29, 2013 12:29 pm    Post subject: power settings for descent or climbs |
				You must not fly into very many busy airports. Why not fly 120 to Loc
 intercept and 100 from FAF to DH? Most any precision approach will have
 at least 7-8000 ft runway to get slowed down to land, and you are only
 needing to lose 30 kts with flaps.
 I use 105 from turn on to final in my Mooney and that is due to gear
 speed limit of 105, so I can drop gear at glideslope intercept. No
 problem slowing from there to 70 kts over runway end with the same 87kt
 flap speed limit as the -10. I don't use flaps until have runway in
 sight. Makes for easier missed approach and better fit with faster traffic.
 On 10/29/2013 11:12 AM, Carl Froehlich wrote:
  	  | Quote: | 	 		   Here is a start I did for this.  Adjust as needed.
  Carl
                           May 26, 2013
                                       MP      RPM   IAS     VS
                                       18        2350    170      -500
  Thank you!
  Pascal
KCHD |
		napolin(at)me.com Guest
				 Posted: Tue Oct 29, 2013 1:01 pm    Post subject: power settings for descent or climbs |
				I think if the weather is down to minimums you might want to come in slow to give yourself the best chance of seeing the runway.
 Nikolaos Napoli
  	  | Quote: | 	 		   On Oct 29, 2013, at 4:28 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
  You must not fly into very many busy airports. Why not fly 120 to Loc intercept and 100 from FAF to DH? Most any precision approach will have at least 7-8000 ft runway to get slowed down to land, and you are only needing to lose 30 kts with flaps.
  I use 105 from turn on to final in my Mooney and that is due to gear speed limit of 105, so I can drop gear at glideslope intercept. No problem slowing from there to 70 kts over runway end with the same 87kt flap speed limit as the -10. I don't use flaps until have runway in sight. Makes for easier missed approach and better fit with faster traffic.
 > Carl
 >                         May 26, 2013
 >                                     MP      RPM   IAS     VS
 >                                     18        2350    170      -500
 > Thank you!
 > Pascal
				 Posted: Tue Oct 29, 2013 1:03 pm    Post subject: power settings for descent or climbs |
				Before this goes off on landing approaches, I was using that as an example. I really should have asked what power change is needed at cruise to keep airspeed at (constant) for a 500fpm descent or climb.
 I'll go out and fly around and figure this out. Was just trying to recall what a change of 1MP would do.
 Thx
 Pascal
  	  | Quote: | 	 		   On Oct 29, 2013, at 1:35 PM, "Kelly McMullen" <kellym(at)aviating.com> wrote:
 > Carl
 >                         May 26, 2013
 >                                     MP      RPM   IAS     VS
 >                                     18        2350    170      -500
 > Thank you!
 > Pascal
		Bob Turner
				 Posted: Tue Oct 29, 2013 1:18 pm    Post subject: Re: power settings for descent or climbs |
				The traditional rule of thumb is 1" MP gives you 100 ft per minute, same speed.
  _________________ Bob Turner
RV-10 QB |
				 Posted: Tue Oct 29, 2013 1:46 pm    Post subject: power settings for descent or climbs |
				Yep - adjust approach speed as needed for the environment.
 Carl
