graeme bird
Posted: Sun Oct 20, 2013 8:08 am Post subject: upholstery backing |
What have builders done in regard to attachment of upholstery: just stray glued material/leatherette to side walls etc? used a backing foam?
or used some form of sub panel. I am thinking mostly about the side walls.
I have found a decent fire retardant fabric and made some patterns.
I am concerned that if I just glue it it wont conform well to the shapes in the side wall.
I have considered card as a sub panel but am concerned about moisture absorption and flammability. Maybe very thin aluminium ? I cant think what would be suitable. I don't want to eat into the seat width a lot but it would be nice to be able to put your hand down the side for that camera or lost pen with scraping on the glass fiber.
I don't suppose anyone has a set of patterns kicking around?
_________________ Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk |
Posted: Sun Oct 20, 2013 8:34 am Post subject: upholstery backing |
Graeme, for the front side walls a 2mm foam covered by
Alcantara worked well for me, both fixed with Evostick
rubber glue. For the walls behind the seats I just used
spray paint in a compatible colour. But much to be said
for going to the Rally and looking inside. Lot of planes
to see wht you like the look of.
Regards, David Joyce, G-XSDJ
On Sun, 20 Oct 2013 09:08:21 -0700
"graeme bird" <graeme(at)gdbmk.co.uk> wrote:
some patterns.
around?
Graeme Bird
G-UMPY
Mono Classic/XS 912S/Woodcomp 3000/3W
Newby: 75 hours 18 months
g(at)gdbmk.co.uk
http://forums.matronics.com/viewtopic.php?p=410922#410922
Un/Subscription,
Forums!
Admin.
richard collings
Joined: 08 Jul 2011 Posts: 73 Location: warwickshire england
Posted: Thu Oct 31, 2013 10:21 am Post subject: upholstery backing |
Hi Graeme
I made made subpanels out of a 1mm thick sheets of styrene used by screen
printers, its light and stable and easy to cut to shape, it wont burn and
get this an 8ft x 4ft sheet costs £11 .00. I bought excess head lining
material [foam backed] from Woolies [www.woolies-trim.co.uk] and having
fitted the headlining using spray adhesive, used the remainder under the
leatherette attached to the side subpanels. I left excess leatherette at the
door edge and glued it onto the lower edge of the door opening and covered
it up with the door seal. The side panel are held in place with stick on
Velcro.
Best of luck if you want more info contact me off line.
Richard Collings
G-CGZV
01327 260045
graeme bird
Posted: Fri Nov 01, 2013 4:22 am Post subject: Re: upholstery backing |
That is all very helpful thanks; Uk Hide do Alcantra , got some samples, very nice but very expensive; as much as best leather at around £90 per sq meter.
Also very thin. Found some fire retardant fabric at John Lewis (£17). I'll see where I can find some styrene.
kit4 (Wagstaff) TBD
