Extra fuel tank
trigo(at)mail.telepac.pt
PostPosted: Wed Nov 06, 2013 4:57 pm    Post subject: Extra fuel tank Reply with quote
Guys
My partner insists in installing an extra fuel tank in the -10.
In fact he has a point because he intends to use the airplane in Africa, where it is very difficult to find AvGas in vast extensions of the territory.
Does anybody know if any builder has already installed an extra fuel tank (in the baggage compartment or anywhere else), or if there is any aftermarket kit?
Carlos
Enviado do meu iPhone
arplnplt(at)gmail.com
PostPosted: Wed Nov 06, 2013 5:07 pm    Post subject: Extra fuel tank Reply with quote
I have seen at least one -10 with two standard tanks per wing.
Their is an aftermarket tip tank kit but I don't have the info.
Dave Leikam
On Nov 6, 2013, at 6:58 PM, Carlos Trigo <trigo(at)mail.telepac.pt> wrote:
Guys
Carlos
jesse(at)saintaviation.co
PostPosted: Wed Nov 06, 2013 5:25 pm    Post subject: Extra fuel tank Reply with quote
We have installed an additional half tank outboard of the stock tanks for a total of 90 gallons on a number of planes. The tanks are separate and you transfer into the mains. It's a big job, but it works well.
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
Dave Leikam
> Guys
> Regards
> Carlos
Kelly McMullen
PostPosted: Wed Nov 06, 2013 6:08 pm    Post subject: Extra fuel tank Reply with quote
I recall some one offered a 7.5 gal tank to go in each wing tip to achieve 75 gal, or 1 extra hour endurance.
Many aircraft have added baggage compartment tanks, either ridgid or bladder, that could be teed into one of the main tanks with a wobble pump or electric pump.
On Wed, Nov 6, 2013 at 6:24 PM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
--> RV10-List message posted by: Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)>
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: [url=tel:352-427-0285]352-427-0285[/url]
O: [url=tel:352-465-4545]352-465-4545[/url]
F: [url=tel:815-377-3694]815-377-3694[/url]
> On Nov 6, 2013, at 8:07 PM, David Leikam <arplnplt(at)gmail.com (arplnplt(at)gmail.com)> wrote:
> --> RV10-List message posted by: David Leikam <arplnplt(at)gmail.com (arplnplt(at)gmail.com)>
> Dave Leikam
>> On Nov 6, 2013, at 6:58 PM, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
>> --> RV10-List message posted by: Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)>
>> Guys
>> Regards
>> Carlos
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
et="_blank">www.mypilotstore.com
"_blank">www.mrrace.com
le, List Admin.
http://forums.matronics.com
- sent from the microchip implanted in my forearm
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
PostPosted: Wed Nov 06, 2013 6:51 pm    Post subject: Extra fuel tank Reply with quote
Safeair1, I think, has the tip tanks.
Sent from my iPad
On Nov 6, 2013, at 9:07 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
[quote]I recall some one offered a 7.5 gal tank to go in each wing tip to achieve 75 gal, or 1 extra hour endurance.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
> Dave Leikam
>> Guys
>> Regards
>> Carlos
le, List Admin.
PostPosted: Sat Nov 09, 2013 2:26 am    Post subject: Extra fuel tank Reply with quote
Thank you all for the answers.
Since almost all were about extra tanks in the wings, is anyone out there aware of extra tanks on the baggage compartment?
Builders who done it, or after-market kit?
CarlosĀ
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: quinta-feira, 7 de Novembro de 2013 02:51
Subject: Re: Extra fuel tank
Sent from my iPad
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
Dave Leikam
> Guys
> Regards
> Carlos
le, List Admin.
Jim Combs
PostPosted: Sat Nov 09, 2013 4:55 am    Post subject: Extra fuel tank Reply with quote
One Caution.
Putting additional weight out at the tips of the wings will change spin / roll characteristics.  Make sure who ever is supplying the tanks will verify spin testing has been performed for the additional mass / moment arms involved.
But then you are the manufacturer and you own that verification.
Jim C
Almost flying again
N312F
On Sat, Nov 9, 2013 at 5:25 AM, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
Carlos
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Jesse Saint
Sent from my iPad
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
Dave Leikam
> Guys
> Regards
> Carlos
le, List Admin.
RV-10 -> N312F - Flying as of 12/2008
kevino
PostPosted: Sun Nov 10, 2013 6:37 am    Post subject: Re: Extra fuel tank Reply with quote
I have an 18 gal metal tank in baggage comp. plumb it directly into and and air four way valve. Use while enroute
Wt and bal is good. Helps with forward cg. Am very pleased with it. Weighs about 15#. Had a local fabricator build it for me. Obviously cannot use with four people in ac.
carl.froehlich(at)verizon
PostPosted: Sun Nov 10, 2013 10:54 am    Post subject: Extra fuel tank Reply with quote
While I don't see any need for an extra fuel tank for my needs, I can see
someone wanting a ferry tank.
My neighbor is the guy who now owns the world record for single engine
non-stop endurance, Guam to Jacksonville. He did it in a Lancair 4. I
watched him make the five or so ferry tanks that fit exactly into each
available space inside the airplane. All tanks were made of carbon fiber
and are exceptionally light.
If I ever want a ferry tank I'd go the same way he did. I suspect I'd build
them to fit in the rear seat passenger foot wells, then perhaps another tank
going across the top of those two tanks and extending over the rear seat
deck. This would help with W&B and as there would be no rear passengers
with all this added fuel weight taking up the passenger space is not an
issue.
Carl
PostPosted: Mon Nov 11, 2013 10:27 am    Post subject: Extra fuel tank Reply with quote
Hi Kevino
That's exactly what I was looking for. I am going to to send you a PM.
Carlos
Bob Turner
PostPosted: Mon Nov 11, 2013 10:39 am    Post subject: Re: Extra fuel tank Reply with quote
I note that the 18 gal tank will put 120 lbs in the baggage area. When I built my 10, Vans recommended a max of 150 lbs in the baggage area. But I see that current kits have a recommended limit of 100 lbs. Does anyone know why the change was made? Does the recommendation apply to all aircraft or only newer ones (was there a structural change?)?
Bob Turner
RV-10 QB
Tim Olson
PostPosted: Mon Nov 11, 2013 11:15 am    Post subject: Extra fuel tank Reply with quote
I think it may have always been 100. I know I've seen that for many years
and was always curious as to why.
Bob Turner
RV-10 QB
rv10flyer(at)live.com
PostPosted: Mon Nov 11, 2013 11:30 am    Post subject: Extra fuel tank Reply with quote
When you do the weight and balance it pulls everything aft. forget trying to
put an adult back there with the fuel loaded up, however, that will take you
out of C/G.
I can tell you that the tail section can tolerate 170lbs. I tested it when I
did and do my annuals, so I doubt it's a structural issue with the baggage
area.
Bob Turner
PostPosted: Mon Nov 11, 2013 11:33 am    Post subject: Re: Extra fuel tank Reply with quote
The weight and balance paperwork that came with my finish kit definitely says 150 lbs.
Bob
Bob Turner
RV-10 QB
Bob Turner
PostPosted: Mon Nov 11, 2013 11:44 am    Post subject: Re: Extra fuel tank Reply with quote
area.
I believe the issue is what it can tolerate if you pull 3.8g, e.g., if the load limit is 100 lbs then it needs to be able to support 380 lbs static.
Bob Turner
RV-10 QB
