Anyone who can spare a small sample of Araldite 420?
asarangan(at)gmail.com
PostPosted: Wed Nov 06, 2013 9:55 am    Post subject: Anyone who can spare a small sample of Araldite 420? Reply with quote
I am hoping someone can send me a small sample of unexpired Araldite
420 for comparative testing.
I have a large batch of long expired Araldite 420.Although it seems to
cure as strong as when it was new, I want to do some quantitative
tensile tests before using it on critical parts. However, I would need
some unexpired samples to compare against. I would only need perhaps 2
or 3 ounces worth. If anyone would be kind enough to send me a small
vial of the unexpired resin and hardener, that would much appreciated.
Since I am in the U.S., mailing logistics may be easiest from
U.S.builders.
Of course, I would share the results of this tests with everyone once
I have them.
Thank you
PostPosted: Wed Nov 06, 2013 7:29 pm    Post subject: Anyone who can spare a small sample of Araldite 420? Reply with quote
Steve
Thanks for the reply. I was considering doing the tests on metal
plates to get a quantitative idea of the degradation, but what you say
makes more sense since the critical bonds on the Europa are mostly to
fiberglass.
On Wed, Nov 6, 2013 at 6:10 PM, hagargs <hagargs(at)earthlink.net> wrote:
Andrew:
You shouldn't need to do comparison testing. When doing tensile testing your joint should not fail at the adhesive. Your sample coupon should fail at the base material. Make your coupon out of the requisite number of fiberglass layers. You want to ensure your adhesive is stronger than the material you are gluing together. I've done tensile tests on my old adhesive and always had the fiberglass break before the adhesive gave way.
Steve Hagar.
PostPosted: Thu Nov 07, 2013 9:30 am    Post subject: Anyone who can spare a small sample of Araldite 420? Reply with quote
Nigel
Thanks much for your input, and the link to the strength data.
I had a similar issue with Aeropoxy, and was told by one of their reps
that it should not be a problem. The only change I have noticed is the
hardener (PH3660) turns red and eventually very deep red despite being
in the original sealed container. Although the bond strength appeared
to be good, the hardener is pretty cheap and easy to acquire
($35/quart) so that is what I did. But the Araldite 420 is pricey. It
doesn't seem possible just buy the hardener separately. The resin and
hardener comes as a single kit, and I was quoted $900 for a single can
from the only US source I could find.
On Thu, Nov 7, 2013 at 9:02 AM, nigel_graham(at)m-tecque.co.uk
<nigel_graham(at)m-tecque.co.uk> wrote:
Andrew,
I read your post with interest as I have pondered the same question.
I bought my first kit in 1994. It was supplied with two cans of Redux, one
of which I opened and began using until the project ground to a halt (like
so many), the other remained sealed.
Long after the “use-by” date, I resumed construction and mindful of the age
of the Redux but curios as to how it degraded with time, I contacted
Ciba-Geigy and was lucky enough to be able to speak to one of their research
chemists.
Refreshingly honest, he assured me that both resin and hardener are totally
inert and very stable and that, in theory, it would not degrade over time.
When I asked why they advised a 36 month “use by” shelf-life, he answered
that as epoxies were relatively “modern”, there was no historical evidence
of any degradation and that it was only added to placate various regulating
authorities. He did warn that the yellow resin would most likely
crystallize over time, but that chemically it was unaltered and a gentle
warming in a water bath would restore it to its original liquid state (the
opened can subsequently did, as predicted, and was restored exactly as
advised).
Returning to my two original cans, both had a use-by date of October 1998 –
I still have them and continue to use them today, 18 years after
manufacture. It works perfectly.
This also remains true of other epoxies. My SP Systems Ampreg 20 still
performs perfectly (expiry 1999) and my super-expensive Polyfibre
“Super-Fill” works perfectly too (expiry 1999).
Before the finger wagging begins, I should explain that I acquired the
mortal remains of a cart-wheeled Europa to allow me to develop repair
strategies for the compression fractured ailerons, flaps and tail. – The
time-ex’d epoxy was used on these. The resulting components are
indistinguishable from new-build parts. I keep test samples of each resin
mix in clear plastic egg-boxes, with encapsulated paper slips listing date,
batch no and component-used-on in each compartment for trace-ability.
Here is a link to the Redux (Araldite) 420 data sheet listing the target
peel strength test figures:
http://www.ambercomposites.com/downloads/datasheet/araldite-420-tds-v1.pdf
atb
Nigel
On 06/11/2013 17:54, Andrew Sarangan wrote:
Snip .....I am hoping someone can send me a small sample of unexpired
Araldite
PostPosted: Thu Nov 07, 2013 9:49 am    Post subject: Anyone who can spare a small sample of Araldite 420? Reply with quote
To add to that, the Araldite 420 I located in the U.S. seems to have a
different shelf life than the one I got from the UK. This is Araldite
420, not Epibond 420. The vendor (http://www.adhesivesforsale.com)
said his stock expires in 6 months. The original bottles were
apparently labeled for only 12 month expiry. So the expiration dates
are most likely related to regional issues such as liability and
record-keeping reasons more than the chemical itself.
On Thu, Nov 7, 2013 at 12:30 PM, Andrew Sarangan <asarangan(at)gmail.com> wrote:
Nigel
> Andrew,
> chemists.
> advised).
> atb
> Nigel
> Araldite
phillik747
PostPosted: Thu Nov 07, 2013 11:10 am    Post subject: Re: Anyone who can spare a small sample of Araldite 420? Reply with quote
There is always Graco.
http://www.gracosupply.com/CSearchs.aspx?Search=epibond+420&CategoryID=0&ManufacturerID=0&SectionID=3&PriceRange=0&SortBy=1&PageSize=12&AndOr=AND&DisplayMode=List&SearchPartNumbersOnly=0
They have a small 50ml tube.
I have been told, like the other builders here, that the expiration date really doesn't mean anything. Just test it first. My guess is that certified manufactures are required to adhere to non-expired items so this keeps the cash flow going in Huntsman's favor.
Kyle
Kyle
Europa Tri-gear (under construction)
