Arizona Flyer
Joined: 09 May 2013 Posts: 31 Location: Casa Grande Arizona
Bill Long
Posted: Sun Nov 03, 2013 1:56 pm Post subject: How to remove tail wheel? |
Should just slid off. Use some penetrating oil.
Sent: Sunday, November 3, 2013 1:50 PM
Subject: How to remove tail wheel?
--> Kolb-List message posted by: "Arizona Flyer" <heracesthesun(at)yahoo.com (heracesthesun(at)yahoo.com)>
On my Firestar II the pizza cutter tail wheel is worn. I bought a new one from Travis at Kolb. I tried to take the old wheel off but it won't budge. It seems like the wheel collar is press fit onto the shaft? I could remove the snap ring and just install the new wheel, but as long as I bought the wheel fixed onto new bearings I'd like to use the new bearings also. I've banged on the wheel collar trying to get if off the shaft but afraid of doing damage. Is it a press fit onto the shaft? I bought a snap ring pliers to just replace the rubber wheel but having a hard time getting those snap rings to come out of the old & new wheels. So often a seemingly simple job turns into an ordeal
"Life should be lived as a bold adventure, I refuse to tiptoe through life just to arrive safely at death"
http://forums.matronics.com/viewtopic.phroElectric www.aget="_blank" href="http://www.buildersbooks.com/">www.buildersbooks.comnbsp; * My Pilot Store www.mrrace.com</ &nbsuch ==
Posted: Sun Nov 03, 2013 2:55 pm Post subject: How to remove tail wheel? |
Tail wheel bushing will rust to the 4130 chromoly axle.
Beating on it could deform the chromoly tube and make it more difficult to separate
It will probably take a press.
You might try heat.
Good penetrating oil like Kroil:
http://www.kanolabs.com/
Kroil beats all the others I have tried.
_________________ John Hauck
Titus, Alabama |
zeprep251(at)aol.com Guest
Posted: Sun Nov 03, 2013 6:18 pm Post subject: How to remove tail wheel? |
The tail wheel looks like it's pressed onto a short tube that slides into the larger pivot assy. tube.You had to drill a hole through both and put a cotter pin in it to keep them together.I'm sure they rust together eventually.Look for that pin,I think it's on the pilots side of the assy,and you can probably see a tube in a tube from that side.
G.Aman
herbgh(at)nctc.com Guest
Posted: Sun Nov 03, 2013 6:26 pm Post subject: How to remove tail wheel? |
Take a saws all (reciprocating saw) and cut through the old wheel, being careful not to nip the axle too much...Herb
At 08:17 PM 11/3/2013, you wrote:
[quote]The tail wheel looks like it's pressed onto a short tube that slides into the larger pivot assy. tube.You had to drill a hole through both and put a cotter pin in it to keep them together.I'm sure they rust together eventually.Look for that pin,I think it's on the pilots side of the assy,and you can probably see a tube in a tube from that side.
G.Aman
Posted: Sun Nov 03, 2013 6:27 pm Post subject: How to remove tail wheel? |
Sorry Jeff,
That tail wheel assy is a hybrid.The wheel part is stock, and should remove as I said earlier, but the full swivel deal is a welded marriage of the two kinds.It was painful to hacksaw that 200.00 unit in half, but it worked great!
G.A.
ceengland7(at)gmail.com Guest
Posted: Sun Nov 03, 2013 7:30 pm Post subject: How to remove tail wheel? |
Sorry about that, John; that was sent from my "new" nexus7, which apparently replies to the actual sender instead of the list. And the tractor was only 50 yrs old (the nexus likes to exaggerate, too).
On Nov 3, 2013, at 7:31 PM, Charlie <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
[quote]50/50 mix of acetone & plain old ATF. I tried it rebuilding a 500 yr old tractor; it works.
You might try heat.
ctric.com
| Quote: | www.buildersbooks.com
uilthelp.com
otstore.com
matronics.com/contribution
://www.matronics.com/Navigator?Kolb-List
cs.com
Arizona Flyer
Posted: Wed Nov 06, 2013 1:06 pm Post subject: Re: How to remove tail wheel? |
| zeprep251(at)aol.com wrote: | Sorry Jeff,
G.A.
-- | Thanks for the input guys. Gary; No problem. I'm just going to replace the wheel and hope the older bearings keep working, thanks...
_________________ "Life should be lived as a bold adventure, I refuse to tiptoe through life just to arrive safely at death" |
woody
Posted: Sun Nov 10, 2013 5:04 pm Post subject: Re: How to remove tail wheel? |
I changed out my "pizza cutter" earlier this year. It had been together for 10 yrs. and didn't want to come apart either. I had to remove the entire assembly, use a vice, torch and vice grips. It did finally yield but not with out considerable effort on my part. While I had it apart I changed out the springs to compression type. I used a Dunn caster & springs from Aircraft Spruce.
Have fun with that tail-wheel....
