mjb777
Posted: Mon Nov 11, 2013 5:56 am Post subject: Pulsar Template Sheet and Wing Rib Profiles Scanned! |
Hi all,
I have Scanned and Posted the 7 full size Skystar Pulsar Template Sheets.
I have also Posted Scanned tracings of Series 1 and XP Wing Rib sets.
I have posted the .PDF Files in the Yahoo Groups Pulsar Builders Files area in a Folder called "Pulsar Templates".
Here is a Drop Box link that I'll try to keep active for a while also if you cant get onto the Yahoo site:
https://www.dropbox.com/sh/c1ug5u6dsx30uq9/9165JIua1n
Many thanks to Keith Palmer of South Africa!!
Matt.
_________________ Pulsar 1 TD Kit.
Captain B777.
Licenced Aircraft Maintenance Engineer. |
mjb777
Posted: Thu Nov 14, 2013 12:45 am Post subject: Re: Pulsar Template Sheet and Wing Rib Profiles Scanned! |
Guys, I have just added a couple of .JPG pictures to the files I posted on the Yahoo Pulsar Builders List, to assist in scaling the sheets if you get them printed.
There may be accumulating errors from the calibration of the scanner I used and the printer you will use, so print off the sheets that the .JPG's refer to first to determine the correct scaling to introduce to make sure the sheets all print out to the right scale.
Matt.
Captain B777.
