Posted: Mon Nov 11, 2013 2:06 pm Post subject: How does the Cessna Ground pwr socket work? |
At 12:22 PM 11/11/2013, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Carlos Trigo" <trigo(at)mail.telepac.pt>
Gents
Just to be sure on how the Cessna (3-lug) ground power socket works:
I followed figure Z-31A, where the third and thinner lug is connected to one
of the contactor coil's terminal.
Where does that thinner lug on the Cessna female socket gets power to
energize the contactor's coil?
Carlos
That ground power connector has been around
for a very long time . . . it dates back to
WWII or earlier. The latest version MS3506
http://tinyurl.com/nc6ybc3
replaced the earlier version AN2552 back in
the 60s
The 'skinny' pin is smaller because it's not intended
to carry much current . . . generally no more than what's
needed to close the ground power contactor in the airplane.
It's very robust for that current level because ground
power jacks on an airplane take a beating . . . a contact
physically sized for 2A or so wouldn't last long in the
all-weather flight-line fast-moving-line-boy environment.
The real 'magic' of this pin is based on its length.
It's shorter than the other two. As you push a hot plug
into the jack, the two current carrying pins are electrically
engaged before the pilot pin . . . this means that the
power pins cannot be loaded before they are engaged
for carrying the load. Similarly, when you pull the plug,
the pilot pin will break first, open the ground power
contactor and prevent arcing at the power pins should
they happen to be loaded at the break.
Next time you're at an FBO and can take a peek
at their ground power plug . . . I think every one
I've seen had blackened and arc-pitted power contacts.
No doubt damaged by hot-plugging or hot-disconnecting
under load where the supported vehicle did not have
a ground power contactor.
Bob . . . [quote][b]
Posted: Mon Nov 11, 2013 2:19 pm Post subject: How does the Cessna Ground pwr socket work? |
Oops!! . . . didn't answer the question. The pilot
pin is often jumpered to the (+) power pin right
next to it. In some cases, the ground power source
control panel wants to manage the ground power
contactor in the vehicle so a 3rd wire is
brought back to the source for extra attention.
In any case, the pilot pin gets + voltage from the same
source as the adjacent power pin.
Posted: Mon Nov 11, 2013 4:03 pm Post subject: How does the Cessna Ground pwr socket work? |
Thanks Bob
Both explanations were welcome.
Got the general idea and the trick of the designer.
Best
Carlos
