planecrazzzy Guest
Posted: Thu Jun 15, 2006 1:13 pm Post subject: Re: Tie Down Suggestions |
Hey Jack,
You gave me an idea on those Dog tie downs...
I think I'll cut it like you did....then heat it and make a loop and weld it.
I'll have to screw'em down with a straight bar....but it should make'm
lighter and smaller.... Thanks !
Gotta Fly...
Mike in MN
Russ Kinne
Posted: Thu Jun 15, 2006 1:25 pm Post subject: Tie Down Suggestions |
David
FWIW, I disagree with your 1-d) -- I suggest you put the rope through
the ring AND around the strut -- I saw a 172 that went over on its
back when the steel-ring weld broke.
And you should not hold the stick back with the seatbelt -- this puts
the elevators UP and tailwinds will try to raise the tail.
Much better to secure the stick FORWARD, putting the elevators down
and causing the wind-forces to hold the tail firmly on the ground.
If the stick is back and the tailrope breaks she can be on her nose
quickly.
I always used tie-down screws, like big heavy dog tethers, for my
170. Carried a hardwood stick to screw them in with -- until a
grabbed it and ran off! Short pieces of rebar work OK (2 for each
wing) but are heavy too
On Jun 15, 2006, at 10:51 AM, David Paule wrote:
On my Cessna Skywagon, I use two stakes, plain straight rods with
sharpened
ends, about 18' long, at each location. They are pounded into the
ground so
they cross - there's a bracket that holds them in that position.
Simple and
works a charm.
The stakes are titanium; it's the best combination of strength and
lightness.
The aluminum bracket has a hole for the rope to the wing.
Here's what I've learned at Boulder Airport, watching airplanes get
blown
over in our high winds.
These things not what most people do. Most people do it wrong.
1. Rope stretch lets the airplane bounce around, and the dynamic
overloads
break the airplane loose. Here's how to avoid that:
a) Make the ropes out of polyester. One of the marine ropes like
Sta-Set is
excellent. Do not use nylon or polypropylene ropes or straps. It's too
stretchy. If possible, double up on the ropes.
b) Tie the ropes tight! I mean so tight that when you're pulling on
them,
the airplane squeaks.
c) Tie the wing tiedowns first, then pull the plane back with the
tail one.
That makes the ropes tighter.
d) Don't tie the ropes over the strut - tie them so that they can't
possibly
slip down and pull the strut out of column.
2. Orientation is important. If you can predict where the wind will
come
from, place the plane so that it's a quartering headwind. Sideways
is okay.
Head into the wind is bad, because that way the wing will work, and
the
possibility of dynamic overloads is high. Don't have the wind
coming from
behind at all, because of the potential for control surface damage.
Got a question now - how do y'all tie the ropes to the wings? On my
Firestar, there's no tiedown points.
Thanks!
Dave Paule
Boulder, CO
Richard Pike
Posted: Thu Jun 15, 2006 1:41 pm Post subject: Tie Down Suggestions |
That is what I did. Works just fine. And you can nestle them all
together, which takes up less space.
Richard Pike
MKIII N420P (420ldPoops)
planecrazzzy wrote:
Hey Jack,
Gotta Fly...
Mike in MN
http://forums.matronics.com/viewtopic.php?p=41297#41297
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
planecrazzzy Guest
Posted: Thu Jun 15, 2006 5:42 pm Post subject: Re: Tie Down Suggestions |
Hey Guys,
Just so happens I had to take my dog to Petco for her shots...
I looked around and found the screws....they had two sizes...18" & 16"
I bought 3 of the 18" ones at only $4.49 ea....
I'm trying to get things ready for my first cross country....(300 miles aprox)
I want to fly to Baraboo WI to check out the Tailwind Fly-in ....
I'll start building mine soon, So I'm hunting for more info & Pictures...
Also I was promised a ride in one too...
Hey Hauck, any "tips" on tools to bring....I'm thinkin the basics
Gotta Fly...
Mike in MN
Posted: Thu Jun 15, 2006 6:15 pm Post subject: Tie Down Suggestions |
| Gotta Fly...
| Mike in MN
Mike:
What ever you think you may need to keep your bird in the air long
enough to get you there and home again.
Basically, I use an old Rotax tool kit, the one that is plastic and
rolls up. I have added a few wrenches, pliers, allen wrenches, etc.
Duct tape, safety wire, nylon tie wraps, are always handy for
temporary repairs.
With a two stroke, definitely a socket and rachet to pull plugs and
something to gap them with.
As you gain experience flying your Kolb, you will find out what it is
going to take to keep you going.
_________________ John Hauck
Titus, Alabama |
Posted: Fri Jun 16, 2006 6:20 am Post subject: Tie Down Suggestions |
I ran across the link for the titanium tie downs it is
http://www.airtimemfg.com/
Rick Neilsen
Redrive VW powered MKIIIc
Jim Baker
Posted: Fri Jun 16, 2006 8:11 am Post subject: Tie Down Suggestions |
X-SpamReason %%SpamReason%%:
I'd be intersted to see if a magnet will stick to these items.....
Jim Baker
580.788.2779
Elmore City, OK
lcottrell
Posted: Fri Jun 16, 2006 8:33 am Post subject: Tie Down Suggestions |
The answer to that question is no! I have both items and they would not
stick together.
Larry, Oregon
dpaule(at)frii.com Guest
Posted: Fri Jun 16, 2006 6:19 pm Post subject: Tie Down Suggestions |
Thanks for the thoughtful comments on my tiedown suggestions.
I'll comment on some of them now. Before I do, I want to reiterate the most
important point - don't permit any slack or any stretch in the tiedowns,
because it's aircraft motion in strong winds that destroys airplanes.
1. John Hauck suggested that I "Use the bottom tang on the upper lift strut
tang to weld a sturdy ring" on my Firestar. Mine already has a tiedown ring
as an eyebolt for one of the strut through-bolts. I was unsure if that was
adequate and so far, haven't used it (I've kept the plane out of the wind,
actually).
2. TheWanderingWench asked where she could get similar tiedown hardware and
what the bracket was. The bracket is a piece of round aluminum bar, about
two and a half inches in diameter and about an inch thick. There are two
perpendicular diametrical holes for the stakes, offset so the stakes don't
touch, and a hole parallel to the axis but offset so it'll clear the stakes,
for the rope. The stakes are home made, with the titanium purchased from
Titanium and Alloys. I don't have any contact information now for them.
3. George T. Alexander, Jr. hoped that I meant that the stakes were about 18
inches long, rather than 18 feet long, as I'd written. Yes, George, they are
indeed the shorter length, thanks for checking.
4. Jim Baker suggested: "Why not just replace the lift strut pin with an
AN44 or AN45 eye bolt? Same tensile strength. Carabiner or other similar
attachment can be used to connect to the eye hole....." My Firestar has
something like that but with a big hefty welded ring in each. I don't know
where the builder got them.
5. Russ Kinne reminded me to "put the rope through the ring AND around the
strut...." Russ, I do this. Honestly! I just forgot to mention it. But I do
it for exactly the reasons you mention. I've noticed that Cessna tiedown
rings can take more load than Piper ones, though, at least as evidenced by
airplanes flipped over.
6. However, Russ also recommended that the elevator be held forward to keep
the tail down in tailwinds. It doesn't seem to matter much, at least with
production general aviation planes, as long as the controls are locked. For
the Firestar, it's probably good advice, because it's best to keep the plane
from ever moving during a windstorm, and the horizontal tail's stronger for
a down load than an up load.
Thanks again for the great comments!
Dave Paule
Boulder, CO
rap(at)isp.com Guest
Posted: Thu Jun 29, 2006 3:53 am Post subject: Tie Down Suggestions |
I saw a home made version of the claw made with 3/16"stainless steel air
craft cable. Had a center ring with three 1 foot runners with collars with
rings weld to them. Works on same principal as the claw pull up on the
center just puts the angle driven rods in a bind.
Rick Pearce Mark3 amphib
do not archieve
