Flow indicator
BobsV35B(at)aol.com
PostPosted: Mon Dec 02, 2013 3:45 pm    Post subject: Flow indicator Reply with quote
Good Evening All,
A few yeas ago someone on this list mentioned that a fellow had developed an electronic gadget that could indicate whether or not fuel was flowing through a line. It consisted of a stock AN aluminum T with the non inline portion containing some sort of light which could tell when fuel was flowing through the inline T portion. Nothing fancy and no measurement of the gallons or flow rate. Just whether or not fuel was flowing. It was pure solid state. No pin wheels or anything. Just light as I recall, and it only had to shine one way. It did not go through the T to another sensor. Does anyone else remember that gadget? If so, do you recall who it was that offered it?
I could sure use an accurate, though economical, way to tell when fuel is no longer being pumped through a line.
Happy Skies,
Old Bob
ceengland7(at)gmail.com
PostPosted: Mon Dec 02, 2013 5:13 pm    Post subject: Flow indicator Reply with quote
On 12/2/2013 5:44 PM, BobsV35B(at)aol.com (BobsV35B(at)aol.com) wrote:
Good Evening All,
Happy Skies,
Old Bob
These intended for flow, but they do detect the presence of liquid:
http://www.gemssensors.com/Products/Level/Single-Point-Level-Switches/Electro-optic
I've got a couple that I intend to try in the situation you describe, but I'm afraid it will take a bigger mount point than the leg of a T. No experience yet on whether they can see fluid in something as small as a fuel line.
Another option I've considered is a low pressure sensor on the output of the pump, with a slightly restrictive orifice after the sensor. If pressure drops below a preset level, it would trip an indicator.
If someone already has a simple & affordable solution, I'd love to hear about it, as well.
BobsV35B(at)aol.com
PostPosted: Mon Dec 02, 2013 5:31 pm    Post subject: Flow indicator Reply with quote
Good Evening Charlie,
The one I remember was built by a homebuilder and offered to the OBAM public. His was mounted in an AN T for 3/8ths inch line.
Thanks for the information provided.
Happy Skies,
Old Bob
In a message dated 12/2/2013 7:14:55 P.M. Central Standard Time, ceengland7(at)gmail.com writes:
Good Evening All,
A few years ago someone on this list mentioned that a fellow had developed an electronic gadget that could indicate whether or not fuel was flowing through a line. It consisted of a stock AN aluminum T with the non inline portion containing some sort of light which could tell when fuel was flowing through the inline T portion. Nothing fancy and no measurement of the gallons or flow rate. Just whether or not fuel was flowing. It was pure solid state. No pin wheels or anything. Just light as I recall, and it only had to shine one way. It did not go through the T to another sensor. Does anyone else remember that gadget? If so, do you recall who it was that offered it?
Happy Skies,
Old Bob
PostPosted: Mon Dec 02, 2013 5:59 pm    Post subject: Flow indicator Reply with quote
I did see this on the GEM site, but it's for 1/2" npt:
http://www.gemssensors.com/en/Products/Flow/Flow-Switches/FS-600%20No-Moving-parts
On 12/2/2013 7:30 PM, BobsV35B(at)aol.com (BobsV35B(at)aol.com) wrote:
[quote] Good Evening Charlie,
Happy Skies,
Old Bob
In a message dated 12/2/2013 7:14:55 P.M. Central Standard Time, ceengland7(at)gmail.com (ceengland7(at)gmail.com) writes:
Good Evening All,
Happy Skies,
Old Bob
BobsV35B(at)aol.com
PostPosted: Mon Dec 02, 2013 6:05 pm    Post subject: Flow indicator Reply with quote
That has to be getting close!
Happy Skies,
Old Bob
In a message dated 12/2/2013 8:00:59 P.M. Central Standard Time, ceengland7(at)gmail.com writes:
Happy Skies,
Old Bob
Good Evening All,
Happy Skies,
Old Bob
tp://www.aeroelectric.com/">www.aeroelectric.com
/ href="http://www.buildersbooks.com/">www.buildersbooks.com
http://www.homebuilthelp.com/">www.homebuilthelp.com
http://www.mypilotstore.com/">www.mypilotstore.com
//www.mrrace.com/">www.mrrace.com
p://www.matronics.com/contribution">http://www.matronics.com/contribution
ist href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List
s.matronics.com/">http://forums.matronics.com
glastar(at)gmx.net
PostPosted: Tue Dec 03, 2013 8:14 am    Post subject: Flow indicator Reply with quote
Hello "Old Bob",
I've got mine from PPA (a former Glastar builder) and they are in my
Glastar (highwing) warning me for unporting on a steep descent (3
minutes warning each side). I've bought again for my RV10 for exactly
the same reason.
http://www.pillarpointelectronics.com/sensors.html
Hope it helps some?
Cheers Werner
BobsV35B(at)aol.com
PostPosted: Tue Dec 03, 2013 8:32 am    Post subject: Flow indicator Reply with quote
Good Morning Werner,
Great information.
As I told Rob, that is just what I remember.
Thank you very much.
Happy Skies,
Old Bob
In a message dated 12/3/2013 10:16:19 A.M. Central Standard Time, glastar(at)gmx.net writes:
--> AeroElectric-List message posted by: Werner Schneider <glastar(at)gmx.net>
Hello "Old Bob",
the same reason.
Hope it helps some?
Cheers Werner
jonlaury
PostPosted: Tue Dec 03, 2013 8:32 am    Post subject: Re: Flow indicator Reply with quote
Hi OB,
I used a Gems ELS 900 optic level sensor in a 1/4" npt Tee to prevent a transfer pump from running dry. I used the output to trigger a relay controlling power to the transfer pump. I clocked the installation so the sensor is 45 deg up from level. No fuel in the line = no power to the pump. Works great
The ELS 900 is an older version of the Gems 14xxx series and comes in several flavors of thread, material and current sinking capability. Mine's polysulfone (OK with fuel) and I found it on Ebay for $5 Smile. Wish I'd bought more.
Good luck,
BobsV35B(at)aol.com
PostPosted: Tue Dec 03, 2013 8:44 am    Post subject: Flow indicator Reply with quote
Good Morning John,
More great data!
Thanks much.
Happy Skies,
Old Bob
In a message dated 12/3/2013 10:34:44 A.M. Central Standard Time, jonlaury(at)impulse.net writes:
--> AeroElectric-List message posted by: "jonlaury" <jonlaury(at)impulse.net>
Hi OB,
Good luck,
PostPosted: Tue Dec 03, 2013 11:29 am    Post subject: Flow indicator Reply with quote
On 12/3/2013 10:33 AM, jonlaury wrote:
Hi OB,
Good luck,
Hi John,
As I told Bob, I've had some of the Gems detectors in my parts drawer
for years, but have never tested them for flow detection. It's great to
hear that you've tested them & found that they work as flow sensors. Now
I know I won't be wasting my time when I install them. Smile
PostPosted: Tue Dec 03, 2013 6:35 pm    Post subject: Flow indicator Reply with quote
These devices are pretty sophisticated with
a price to match.
If you want a go/no-go detection of fluid motion
you can set up a pair of self-heated thermistors in two legs
of a bridge. One thermistor is situated out in
the fluid flow path, the other is in the same liquid
but out of the flow path . . . like the side port of
a t-fitting.
The electronics needed to read the two thermistors
and detect flow is pretty simple. Radio Shack
jelly-bean parts.
Bob . . . [quote][b]
jonlaury
PostPosted: Wed Dec 04, 2013 8:51 am    Post subject: Re: Flow indicator Reply with quote
[quote="ceengland7(at)gmail.com
Hi John,
[/quote]
Charlie[/quote]
Charlie,
One caveat is that the Gems sensor in my application indicates 'presence' but not flow.
