		| Author | Message |
		| clivesutton
				|  Posted: Wed Dec 04, 2013 5:21 am    Post subject: fuel tank selectors? |   |
				| Gents (and Ladies),
 During this years maintenance, I'm considering putting a new fuel valve into my flying Europa to replace the 6749 valve - which I suspect is weeping a bit (responsible for the cockpit fuel smell problem?).  Does anyone have any advice/experience of using the Andair range of selectors fitted to the upper horizontal surface of the tunnel - just aft of the instrument panel?  Not sure in particular if at that height (about 350mm higher than the tank outlets) it may cause problems - and if to overcome that, if anyone has used a remote selector connected by a shaft to the valve sited closer to the fuselage floor?  Soonest replies appreciated.
 Clive Sutton
		| Back to top |  |
		| frans(at)privatepilots.nl Guest
				|  Posted: Wed Dec 04, 2013 5:56 am    Post subject: fuel tank selectors? |   |
				| On 12/04/2013 02:21 PM, gtagr wrote:
  	  | Quote: |  	  | Does anyone have any advice/experience of using the Andair range of selectors fitted to the upper horizontal surface of the
 I have such an Andair selector (like many others), and indeed mounted it
 quite low with an extension shaft to the selector knob. I'm very happy
 with the setup.
 The Europa supplied fuel valve is a piece of junk if you ask me, never
 installed it (like so many other supplied pieces). I got the impression
 it is for the water supply in the house and never intended for fuel, let
 alone for installation in an aircraft. It is heavy as well.
 Frans
		| Back to top |  |
		| kheindl(at)msn.com Guest
				|  Posted: Wed Dec 04, 2013 6:50 am    Post subject: fuel tank selectors? |   |
				| Hi Frans,
 My  Andair fuel valve is mounted on the fuselage floor, and the selector is on top of the tunnel at the very back. If I remember correctly, I obtained an extension piece from Andair.
 Karl
  	  | Quote: |  	  | Date: Wed, 4 Dec 2013 14:55:28 +0100 From: frans(at)privatepilots.nl
 Subject: Re: Europa-List: fuel tank selectors?
 --> Europa-List message posted by: Frans Veldman <frans(at)privatepilots.nl>
 with the setup.
 Frans
		| Back to top |  |
		| rowlandcarson(at)gmail.co Guest
				|  Posted: Wed Dec 04, 2013 7:22 am    Post subject: fuel tank selectors? |   |
				| On 4 Dec 2013, at 13:21, gtagr wrote:
  	  | Quote: |  	  | Does anyone have any advice/experience of using the Andair range of selectors fitted to the upper horizontal surface of the tunnel - just aft of the instrument panel?  Not sure in particular if at that height (about 350mm higher than the tank outlets) it may cause problems - and if to overcome that, if anyone has used a remote selector connected by a shaft to the valve sited closer to the fuselage floor?
 Clive - I installed my Andair selector before I bonded in the cockpit module (which is probably a lot easier than doing it as an upgrade to an existing installation).
 You can see some of the pictures of my installation at;
 http://www.rowlandcarson.org.uk/aviation/europa_435/fuel_valve_trial.php
 and
 http://www.rowlandcarson.org.uk/aviation/europa_435/fuel_pipes.php
 and other pictures nearby in the sequence.
 I haven't yet had official approval of this specific arrangement, but I believe it is quite similar to what some others have done.
 in friendship
 Rowland
 | Rowland Carson          ... that's Rowland with a 'w' ...
 | <rowlandcarson(at)gmail.com>            http://www.rowlandcarson.org.uk
 | Skype, Twitter: rowland_carson      Facebook: Rowland Carson
 | pictures: http://picasaweb.google.com/rowlandcarson
		| Back to top |  |
		| churchy
				|  Posted: Wed Dec 04, 2013 8:02 am    Post subject: fuel tank selectors? |   |
				| Hi Rowland - in your installation using metal fuel pipes instead of rubber hoses, where are your fuel filters - aren't they installed between the tank and the fuel selector when you use rubber hoses or have I misunderstood the build manual?
 Richard CC
 Sent from my iPad
  	  | Quote: |  	  | On 4 Dec 2013, at 15:21, Rowland Carson <rowlandcarson(at)gmail.com> wrote:
 and
 in friendship
 Rowland
		| Back to top |  |
				|  Posted: Wed Dec 04, 2013 9:09 am    Post subject: fuel tank selectors? |   |
				| On 4 Dec 2013, at 16:02, Sky Mail wrote:
  	  | Quote: |  	  | Hi Rowland - in your installation using metal fuel pipes instead of rubber hoses, where are your fuel filters - aren't they installed between the tank and the fuel selector when you use rubber hoses or have I misunderstood the build manual?
 Richard - sorry, I guess I should have explained that. After considerable thought, I've decided not to use the filters (as supplied in the kit and described in the manual) between the tank and the selector. I understand other aircraft have been cleared to fly with a similar arrangement to mine. (I think I've heard that the prototype Europa fuel system originally used a single filter downstream of the selector and this was only changed to separate ones because it could block so easily.)
 I'm using an Andair gascolator to be mounted under the baggage area near the electric fuel pump. It provides better filtering than the inline filters supplied in the kits, but nonetheless is more resistant to blockage by debris. I recognise it presents a potential risk as a single point of failure, but in contrast to the inline filters it offers easy checking (and particularly cleaning if necessary) before every flight.
 Another reason for discarding the supplied filters was that I couldn't find an elegant way of interconnecting them with the aluminium piping.
 in friendship
 Rowland
		| Back to top |  |
		| asarangan(at)gmail.com Guest
				|  Posted: Fri Dec 13, 2013 7:46 am    Post subject: fuel tank selectors? |   |
				| Frans
Why do you say "the Europa supplied fuel valve is a piece of junk"? I
 am not questioning it, just trying to understand. The same valve is
 also listed in the Aircraftspruce catalog, so I can only presume that
 it is an aircraft worthy valve.  I agree that it looks like a backyard
 water faucet, but besides the appearance are there any other factors
 that makes is less suitable?
 On Wed, Dec 4, 2013 at 8:55 AM, Frans Veldman <frans(at)privatepilots.nl> wrote:
  	  | Quote: |  	  |
 with the setup.
 Frans
		| Back to top |  |
				|  Posted: Fri Dec 13, 2013 8:11 am    Post subject: fuel tank selectors? |   |
				| -----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
 On 12/13/2013 04:45 PM, Andrew Sarangan wrote:
  	  | Quote: |  	  | Why do you say "the Europa supplied fuel valve is a piece of junk"? I am not questioning it, just trying to understand. The same valve
 is also listed in the Aircraftspruce catalog, so I can only presume
 that it is an aircraft worthy valve.  I agree that it looks like a
 backyard water faucet, but besides the appearance are there any
 other factors that makes is less suitable?
 It is not made of light weight materials, it has no "locking feature",
 and if I remember correctly one even has to modify it. "Piece of junk"
 is maybe exaggarated but at the time of classification I was
 frustrated how much I spent on kit-parts that I never used because of
 the inferior quality or suitability for something that was going to be
 a "once-in-a-lifetime" project of proud. And I never thought it would
 be in the Aircrafspruce catalog but assumed it was indeed a backyard
 water faucet.
 Frans
 -----BEGIN PGP SIGNATURE-----
 Version: GnuPG v2.0.22 (GNU/Linux)
 iQIcBAEBAgAGBQJSqzErAAoJEC+zXxqs0ZzVdscP/0MLCdrmMxy1+H7b5yqiUbCi
 FfX8dg/2jQA71fedjbNUZChgd2y2vEiwqnKtQVxiaVf8JWcBMgg6iWuyl2Ll8gOA
 EWxcMwv9MzWgrVFd4NuwqYtBHif24F57Ey1co2+Qs9lONXr8acJ0gW3c4zLa9KM1
 bJR3MUGkiEWp+YnvOME51/pArjr4mNf722Vin1+J8AKxgPlf4D6LneyjElspztJA
 Ow1l77LiIyxDEkXqWXzaDvUD6oEBaP5dDXOErdsVeQuZjymquux4dTSh4Dt9uMoa
 zOGGAKnGp68zxda0VO3IWi8kgvWqyUx/1v3bNaWx5fjhEOMQ3CJdZHnQwbTV3fRI
 t0mpv+vecS1ApxICUHCFmBHwybKlwZH+w+2ljgt5AJFVq3jA2mLopKYog7J+uXEg
 sRx8ilpGHDMlYyYqunN115dS+O0OcpyVcet/E6Kwn0AAUW2eLmJEoLW/iz9rNKvi
 /7dQHnP1a0lbq4CVinzk4NFwIe4+SKlK6GKVsS+RLnDo2HMpSuREV9gwiySjKnDm
 6bZcheusSO7jYRlESizagBdxfarFsAJqzc3vSmfKGuXmZsEJCnjpyNCqNuleGRe2
 v1jqUJg+0I9QVDYGn3XbJUhqVt8jnuuiEsi7stWqJ4CY7PcF0ffrLC9iG9HmW2Mv
 gXCV9YFvlgmTtuVUvIza
 =xWJD
 -----END PGP SIGNATURE-----
		| Back to top |  |
		| paul.the.aviator(at)gmail Guest
				|  Posted: Fri Dec 13, 2013 9:22 am    Post subject: fuel tank selectors? |   |
				| Mine has functioned fine since 2004.  I believe some people have had problems with them getting tight over time.
		| Back to top |  |
				|  Posted: Fri Dec 13, 2013 9:51 am    Post subject: fuel tank selectors? |   |
				| Aircraftspruce also sells a big red handle (similar to Andair) to
replace the stock handle. Surprisingly this handle costs than the
 valve itself. It seems this is the setup used in all RV aircraft.
 On Fri, Dec 13, 2013 at 11:09 AM, Frans Veldman <frans(at)privatepilots.nl> wrote:
  	  | Quote: |  	  |
 Hash: SHA1
 water faucet.
 Frans
 =xWJD
		| Back to top |  |
		| dg.watts(at)talktalk.net Guest
				|  Posted: Fri Dec 13, 2013 10:03 am    Post subject: fuel tank selectors? |   |
				| Mine too, and that is since 1997 and now at 2040 hours (and I didn't replace anything else in what I thought was an excellent kit). (But what do I know!!!)
Dave Watts G-BXDY Classic Monowheel
 On 13 Dec 2013, at 17:21, Paul McAllister <paul.the.aviator(at)gmail.com (paul.the.aviator(at)gmail.com)> wrote:
 [quote]Mine has functioned fine since 2004.  I believe some people have had problems with them getting tight over time.
		| Back to top |  |
		| max8992
				|  Posted: Fri Dec 13, 2013 10:22 am    Post subject: fuel tank selectors? |   |
				| Mine is 11 years old (2002). I have gas smelt in the cockpit when open it after few days and still can’t find a solution. I will repalce the pipe between the cap filler and the tank with an appropriate pipe and the selector by an Andair and … let you know.
 Max  Cointe
 mcointe(at)free.fr (mcointe(at)free.fr)
 F-PMLH Europa XS_TriGear
 Kit #560-2003 912ULS/AirmasterAP332 490 hours
 F-PLDJ Dyn’Aéro MCR 4S
 Kit #27-2002 912ULSFR/MTProp MTV7A 1600 heures
 De : owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] De la part de David Watts
 Envoyé : vendredi 13 décembre 2013 19:03
 À : europa-list(at)matronics.com
 Objet : Re: fuel tank selectors?
 0123456789012345678901234567890123 	  | Quote: |  	  | Mine has functioned fine since 2004.  I believe some people have had problems with them getting tight over time.
        -- Please Support Your Lists This Month --           (And Get Some AWESOME FREE Gifts!)   November is the Annual List Fund Raiser.  Click on
 Max8992
 Europa XS #560 F-PMLH
		| Back to top |  |
		| peterz(at)zutrasoft.com Guest
				|  Posted: Fri Dec 13, 2013 10:28 am    Post subject: fuel tank selectors? |   |
				| wow.... 2040hrs!  Is that the highest time Europa?
 I am curious as to how the control linkages / system has held up over those many hours.  Is there much increased free play?
 Cheers and thx,
 Pete
 A239
 On Fri, Dec 13, 2013 at 1:02 PM, David Watts <dg.watts(at)talktalk.net (dg.watts(at)talktalk.net)> wrote:
 [quote]Mine too, and that is since 1997 and now at 2040 hours (and I didn't replace anything else in what I thought was an excellent kit). (But what do I know!!!)
		| Back to top |  |
				|  Posted: Fri Dec 13, 2013 11:19 am    Post subject: fuel tank selectors? |   |
				| I do not have the highest houred Europa, as I know of one other with more and there may be others.
 As for control play, there is no more now than there was at the end of the build although there are a couple of jobs that I have had to do along the way
		| Back to top |  |
		| grahamsingleton(at)btinte Guest
				|  Posted: Fri Dec 13, 2013 1:06 pm    Post subject: fuel tank selectors? |   |
				| Max
if you have the cobra filler it may have a misshapen moulding flash behind the
 bottom hose joint. If the moulding flash is not smooth the hose won't seal and will smell.
 Graham
 Sent: Friday, 13 December 2013, 18:21
 Subject: RE: fuel tank selectors?
 Max  Cointe
 Objet : Re: Europa-List:  fuel tank selectors?
		| Back to top |  |
