Battery Disconnect Switch...
steve(at)tomasara.com
PostPosted: Mon Dec 09, 2013 8:06 am    Post subject: Battery Disconnect Switch... Reply with quote
Greetings,
I'm working on the wiring for a Solitare and it uses a small engine (KFM
Maxi 107) with only a 300W starter. I'm shopping for an appropriate
disconnect switch (in lieu of a master relay) that is capable of
disconnecting the starter current should the starter relay get stuck.
I don't know much about the starter motor other than the 300W listed in
the engine manual (PM? series wound?) but given the 300W it seems like
100A disconnect capable switch should be more than enough when taking
into account battery sag and motor inefficiency. However, if anyone has
a defensible way to come up with a better number, I'd love to hear it.
I'm looking for the physically smallest switch that is up to the task.
Does anyone have an suggestions an appropriate switch? The usual
race-car style battery disconnects are way over-kill and physically
quite large as a result.
All thoughts appreciated,
Steve Stearns
Boulder/Longmont, Colorado
Restoring (since 1/07) and flying again (8/11!): N45FC O235 Longeze
Cothern/Friling CF1 (~1000 Hrs)
Flying (since 9/86): N43732 A65 Taylorcraft BC12D
PostPosted: Mon Dec 09, 2013 8:28 am    Post subject: Battery Disconnect Switch... Reply with quote
Related question: How much do you have to de-rate the combined current
handling if you wire a DPST with the poles in parallel? I'm assuming if
you have a 30A DPST toggle switch (which I've found. Big, but not as big
as a battery disconnect switch) and you wire the poles in parallel, the
appropriate rating is something less than 60A. Anyone know?
Steve.
On 12/9/2013 9:05 AM, Steve Stearns wrote:
Greetings,
(KFM Maxi 107) with only a 300W starter. I'm shopping for an
appropriate disconnect switch (in lieu of a master relay) that is
capable of disconnecting the starter current should the starter relay
get stuck.
in the engine manual (PM? series wound?) but given the 300W it seems
like 100A disconnect capable switch should be more than enough when
taking into account battery sag and motor inefficiency. However, if
anyone has a defensible way to come up with a better number, I'd love
to hear it. I'm looking for the physically smallest switch that is up
to the task.
Steve Stearns
PostPosted: Mon Dec 09, 2013 9:05 am    Post subject: Battery Disconnect Switch... Reply with quote
At 10:05 AM 12/9/2013, you wrote:
--> AeroElectric-List message posted by: Steve Stearns <steve(at)tomasara.com>
Greetings,
I'm working on the wiring for a Solitare and it uses a small engine (KFM Maxi 107) with only a 300W starter. I'm shopping for an appropriate disconnect switch (in lieu of a master relay) that is capable of disconnecting the starter current should the starter relay get stuck.
I don't know much about the starter motor other than the 300W listed in the engine manual (PM? series wound?) but given the 300W it seems like 100A disconnect capable switch should be more than enough when taking into account battery sag and motor inefficiency. However, if anyone has a defensible way to come up with a better number, I'd love to hear it.
Does anyone have an suggestions an appropriate switch? The usual race-car style battery disconnects are way over-kill and physically quite large as a result.
Hi Steve,
It's been a long time since we've chatted.
Consider this item from Summit Racing
[img]cid:7.1.0.9.0.20131209105836.012a10e8(at)aeroelectric.com.0[/img]
It's their SUM-G1432
It's 'rated' with some pretty sedate currents
as a switch . . . but your switching requirements
are benign also. I'd bet this switch will CARRY
the starter currents just fine.
In any case, the price is right (about $20) and
the size is attractive too. There's also a Moroso
74101 that is about the same size and RATED for
much greater currents. A tad more expensive too
at $45 but almost certain to be suited to
the task. See:
http://tinyurl.com/kj5jwba
 Filesize:  29.78 KB
 Viewed:  2457 Time(s)
