cjhukill(at)cox.net Guest
Posted: Tue Jun 06, 2006 7:00 pm Post subject: rear seat heat |
After much thought, and taking into consideration what comments I've received from fellow listers, I have decided on my cabin heat solution. I have talked to Don ( RV8 builder) at Aviacomp (503) 543-3986, whom manufactures all the heat/ vent ducting parts for Vans, as well as Cirrus, etc, etc., and he is going to modify the T duct (Van's p/n VA-175 Heat Duct Tee) which is just aft of the firewall, to include a selector valve that will allow me to direct the forward heat to go left, right or mix both. This will be a direct replacement for the non selector T valve, and will mate to the existing Vans VENT DL-102.4 flanges. This will allow me to control the left/right heat volume in the forward footwell area. In addition, Don will provide me with another selector valve, which I will install in the rear heat supply line, that will allow me to mix (divert) the aft heat to a duct for defog function This is a solution that allows me the most flexibility, with minimum weight and complexity (two additional control cables). Don will provide similar components for anyone else interested in a similar system, just give him a call.
Chris Hukill
Workin the tunnel
jesse(at)itecusa.org Guest
Posted: Wed Jun 07, 2006 7:37 am Post subject: rear seat heat |
Did he provide any price information?
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Hukill
Sent: Tuesday, June 06, 2006 11:02 PM
Subject: rear seat heat
Chris Hukill
Workin the tunnel
Vern(at)teclabsinc.com Guest
Posted: Wed Jun 07, 2006 8:22 am Post subject: rear seat heat |
Hi,
Would this be a good way to get heat up to a defroster? I know there has been some discussion on using computer fans to blow air on the windscreen. I have to admit I haven’t really looked that far ahead in the plans to know what provisions are incorporated.
Vern Smith (wing flaps)
Sent: Tuesday, June 06, 2006 8:02 PM
Chris Hukill
Workin the tunnel
KiloPapa
Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
Posted: Sat Jun 17, 2006 8:01 pm Post subject: Re: rear seat heat |
Check out the Aviacomp Worldwide website at:
http://www.aviacompworldwide.com/heatboxes.html
Kevin
40494
