XS Tri-Gear Speed Kit Parts.
Richard Wheelwright
PostPosted: Sat Jan 04, 2014 7:21 am    Post subject: XS Tri-Gear Speed Kit Parts. Reply with quote
UK List,
I'm thinking of now fitting the Europa Speed Kit to G-PW and just wanted to see if anyone in the UK had any of the parts available, and wanting to to sell them? even if it is just one Item will help.
Thank you in advance
Contact email rpwheelwright(at)yahoo.co.uk
Richard Wheelwright
G-IRPW
First Flight 24th July 2013
JonathanMilbank
PostPosted: Sat Jan 04, 2014 1:43 pm    Post subject: Re: XS Tri-Gear Speed Kit Parts. Reply with quote
Now that I've removed the monowheel and fitted "trainer wheels" dangling in the breeze, there's no doubt that I've lost about 8 knots in the cruise, not to mention the loss of about 45 lbs load capacity. However the peace of mind in runway crosswind situations more than compensates.
The speed kit in its entirety doesn't appeal, because I don't fancy having to clean grass and mud repeatedly from inside the spats, nor having to struggle to check brake pads and inflate tyres.
But I see that some folk only fit "pants" on the legs and fairings over the hinges. My question is "What are the different figures between the two arrangements, with or without wheel spats, in terms of weight and speed gain?"
It seems to me that the speed kit without wheel spats would offer relatively little speed gain and therefore is of questionable value.
ptag.dev(at)talktalk.net
PostPosted: Sat Jan 04, 2014 3:26 pm    Post subject: XS Tri-Gear Speed Kit Parts. Reply with quote
Hi! The next time I clean out spats will be the first .....other than doing
tyre changes.
The only problem I have is that without spats the underside of the wings
are always covered in shit.
With regards to weight factors I can't give you factors but I've never
failed to lift off !
Happy New Year.
Bob Harrison G-PTAG
frans(at)privatepilots.nl
PostPosted: Wed Jan 08, 2014 6:08 am    Post subject: XS Tri-Gear Speed Kit Parts. Reply with quote
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 01/04/2014 04:21 PM, Richard Wheelwright wrote:
UK List, I'm thinking of now fitting the Europa Speed Kit to G-PW
Item will help.
I have the flap hinge fairings for sale (although I don't live in the
UK but mailing these things is not a big problem).
Frans
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.22 (GNU/Linux)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=XMHm
-----END PGP SIGNATURE-----
PostPosted: Wed Jan 08, 2014 6:25 am    Post subject: XS Tri-Gear Speed Kit Parts. Reply with quote
Hash: SHA1
spats, nor struggling to check brake pads and inflate tyres.
My "home field" is a muddy grass strip. But I never have to clean out
the spats (but I would have to clean the underside of the wing after
every landing without the spats). If your home field is a grass strip,
you don't have to worry much about the brake pads, but if your home
field is a hard surface you don't have to worry about mud and grass.
I remove the spats once a year, sufficient for maintenance, brake pad
checks, and cleaning out the inside of the spats.
But I see that some folk fit "pants" on the legs and fairings over
Never measured these things individually, but from what I know about
it is that tubular constructions (like the legs) are extremely draggy
(some folks even claim that leg fairings have a greater benefit than
wheel spats) and that the hinge fairings are probably adding drag
instead of removing it. The hinges are pretty much knifes slicing
through the air, but with the fairing there is much more skin drag due
to the increased surface, and the opening at the rear is one of the
worst things you can do to any aerodynamic profile. I have left the
hinge fairings off, made a few tiny simple fairings for the transition
between wing and hinges to just cover the bolts and reduce
interference drag and keeping the rest of the hinge as is, and
optimised the outboard "double" hinges which are legacy things from
the monowheel (to avoid recertification of the wings and controls
after changing the gear lay out).
Frans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=FUD0
