larkrv10(at)gmail.com Guest
Posted: Sat Jan 04, 2014 3:23 pm Post subject: nose wheel |
Hi all, I mounted my Desser tires and Leakstop tubes today on my Grove main wheels and Matco nose wheel. A couple of observations/questions.
The valve stem on the nose wheel tube has a washer and nut on it tight to the tube. Matco's drawing doesn't really show where the washer should go, but as far as I can tell, it has to go between the tube and the nut which fits in the nose wheel slot. Has anyone else come across this?
2nd observation. The Grove main wheels have nylon lock nuts which I replaced when I torqued the wheel bolts. The Matco wheel has metal lock nuts. I would think that due to heat from the brakes the main wheels should have the metal lock nuts. Does this seem reasonable or of no consequence?
Thx, Rick
#40956
Southampton, Ont
Posted: Sat Jan 04, 2014 7:06 pm Post subject: nose wheel |
Can't help with Q1 but for Q2: Â I have seen plastic lock nuts on brake calipers melted due to brake heat. Â So metal nuts are called for on the calipers. Â If you mean the nuts holding the wheel halves together, I'd expect much less issue there, but if you're concerned then go with metal.
Dave Saylor
831-750-0284 CL
On Sat, Jan 4, 2014 at 3:21 PM, Rick Lark <larkrv10(at)gmail.com (larkrv10(at)gmail.com)> wrote:
[quote] Hi all, I mounted my Desser tires and Leakstop tubes today on my Grove main wheels and Matco nose wheel. A couple of observations/questions.
Â
Â
Â
Thx, Rick
#40956
Southampton, Ont
_blank">www.aeroelectric.com
="_blank">www.mypilotstore.com
ank">www.mrrace.com
tp://forums.matronics.com
| [b]
rv10flyer
Posted: Sat Jan 04, 2014 7:36 pm Post subject: Re: nose wheel |
[quote="larkrv10(at)gmail.com"]Hi all, I mounted my Desser tires and Leakstop tubes today on my Grove main wheels and Matco nose wheel.� A couple of observations/questions.
The valve stem on the nose wheel tube has a washer and nut on it tight to the tube.� Matco's drawing doesn't really show where the washer should go, but as far as I can tell, it has to go between the tube and the nut which fits in the nose wheel slot.� Has anyone else come across this?
2nd observation.� The Grove main wheels have nylon lock nuts which I replaced when I torqued the wheel bolts.� The Matco wheel has metal lock nuts.� I would think that due to heat from the brakes the main wheels should have the metal lock nuts.� Does this seem reasonable or of no consequence?
Thx,� Rick
#40956
Southampton, Ont
I threw the nut and washer in the trash.
_________________ Wayne G. |
