msmeredith
Posted: Tue Jan 14, 2014 7:03 pm Post subject: ELT Antenna |
Hi - I'm installing a Kannad Integra 406AF ELT with built in GPS. The cheapest antenna for this ELT is the whip, which is what I bought with it. The blade/vane for this unit are hundreds/thousands more expensive. But now I'm trying to figure out where to put the whip! It's a monstrosity.
Aircraft is a Super Chipmunk which I'm totally rebuilding. (Google "Super Chipmunk Restoration".) I successfully completed a new electrical system using the Z-11 architecture and knowledge gained from the Aeroelectric Connection and this list. (Thanks!!) The ELT is the last thing on the to-do list before I secure all the wire bundles.
This is an unusual Chippy - it's single seat open cockpit, and I installed an 8 foot long turtleback/headrest to conceal a rollover bar behind the rear seat. It's .025 alum, about a foot high/wide at the cockpit then tapering to about 4 inches at the fin. I'd like to mount the antenna 2 feet back on the top of the main fuselage structure, so the rubber part is inside the turtleback, then poke the steel whip out the top through a small hole/grommet. That approach would be unobtrusive, avoid an ugly 2 foot tall antenna with fat black base, and avoid beefing up the turtleback top to support it. My question: would the ELT still be heard with the bottom 8 inches or so of base hidden under .025 alum?
Thanks!
_________________ Mark Meredith
Super Chipmunk N7DW |
kuffel(at)cyberport.net Guest
Posted: Tue Jan 14, 2014 7:55 pm Post subject: ELT Antenna |
Mark,
<< would the ELT still be heard with the bottom 8 inches or so of base
hidden under .025 alum? >>
Yes.
You are much more likely to not be heard by having the external part of the
whip sheared off in the crash.
The longer answer involves not only the shielding effect caused by the
aluminum but also the feed mismatch, both of which will reduce signal
output. But the application is so direct there is no doubt you could be
heard by a satellite. If you wish to be sure, build a mock up with foil
over cardboard and scrap tubing. See how it works with and without the
foil. Don't forget the rules about when and how to test ELTs.
Tom Kuffel
stuart(at)stuarthutchison Guest
Posted: Tue Jan 14, 2014 8:30 pm Post subject: ELT Antenna |
The Kannad whip antenna is base-loaded, so the ugly first 6" black base is
part of the radiating element that needs to be exposed. I'll be making an
angled mount with fibreglass fairing like a COM antenna for the underside of
my Rocket, since I also have a manual 406 GPS PLB. I figure any automatic
activation of the ELT will be because of a sudden stop, so I'll probably be
upside down about then. My life may depend on the automatic system pointing
skywards from the underbelly.
Kind regards, Stu
F1 Rocket VH-FLY http://www.mykitlog.com/RockFLY
www.teamrocketaircraft.com
msmeredith
Posted: Wed Jan 15, 2014 5:10 am Post subject: Re: ELT Antenna |
Tom Kuffel[/quote]
Tom,
Good idea. What do I need to measure the output with this mockup?
msmeredith
Posted: Wed Jan 15, 2014 5:31 am Post subject: Re: ELT Antenna |
Stu,
I've thought about the "impact" of a rollover which is why I added the rollbar. But think I'll stick with an assumption the airplane is still airborne or upright in big pieces if the ELT is ever activated!
I have a very small cockpit and don't plan to carry a PLB. There are very few places to put even a portable GPS for trips, so I went with the installed ELT (best I can tell, aircraft has never had one since it was built in 1951). Kannad has an internal antenna also so works without the whip in a handheld mode, though I'd need a screwdriver and a good hand to access it...
Posted: Wed Jan 15, 2014 7:09 am Post subject: ELT Antenna |
Mark,
<< works with and without the foil. .... Good idea. What do I need to measure the output with this mockup? >>
The ELT still transmits on 121.5 so any aircraft band hand held will do the job. Most hand helds have a signal strength indicator but a better way (although tedious) is to see how far away (over flat ground) you can hear it without the foil/cardboard. Then try it with the shield. No guarantee it will be just as good at 406MHz but the odds are likely.
Or contact a local amateur radio club (find at arrl.org). Many ham UHF hand helds can receive 406MHz. You will easily find a ham who would enjoy helping with your experiment.
<< But think I'll stick with an assumption the airplane is still airborne or upright in big pieces if the ELT is ever activated! >>
My experience suggests this is not a valid assumption. When this is true, the people are ambulatory, can remove the ELT from its mount, attach the portable antenna, or just talk on the aircraft radio. But in most crashes I have seen, if the occupants are badly injured (and so really need an ELT) then most external antennas are no longer working. Carrying a PRB in your pocket might be a good Plan B.
If you do run the test, let us know the results.
Tom Kuffel
msmeredith
Posted: Wed Jan 15, 2014 10:17 am Post subject: Re: ELT Antenna |
[quote="kuffel(at)cyberport.net"]Mark,
<<works>>
Tom Kuffel
Tom,
Thanks. I'll run the test and let you know. I have some extra .025 alum so will use that for the mockup.
msmeredith
Posted: Wed Jan 15, 2014 10:50 am Post subject: Re: ELT Antenna |
kuffel(at)cyberport.net wrote: | Mark,
<<works>>
Tom Kuffel |
Tom and other listers,
Second thoughts. My bent comm and blade transponder antennas are under the belly amidships behind the wing, close to the ELT transmitter's position above them. If I mount the ELT whip antenna underneath also, can I bend the steel rod beyond the black base so it's shaped similar to my comm antenna? Would I need a large bend radius to prevent it from breaking, and would this affect the transmit functionality? I could move it forward a foot or so (just aft the flaps) to separate it from the comm antennas. I just need to be careful not to tune my radio to 121.5 when testing the ELT.
Of course that round antenna base will be a big source of drag, but mounting it underneath would solve the rollover and aesthetic issues. Though now the assumption is the landing gear stay with the airplane!
Posted: Wed Jan 15, 2014 2:53 pm Post subject: ELT Antenna |
I presume you're talking about the AV-200 described in
Kannad's manual . . . .
http://tinyurl.com/olaccxt
Probably not. That "bottom 8" is probably the 406 mHz
part of the antenna. Further, given that this product
doesn't have a separate GPS antenna, I'm assuming that
the single antenna assembly serves the GPS receiver
as well.
I think you should take pains to install per the
manufacturer's recommendations.
Posted: Wed Jan 15, 2014 5:32 pm Post subject: ELT Antenna |
Mark,
<< If I mount the ELT whip antenna underneath also >>
This is probably the worst location for an ELT antenna. Any kind of brush
at an off-airport landing will wipe it off the fuselage.
<< can I bend the steel rod beyond the black base so it's shaped similar to
my comm antenna? >>
Don't know why not.
<< Would I need a large bend radius to prevent it from breaking, >>
No idea. If the antenna there is just a steel rod as you say, then bending
it around a 1" pipe or so should work. But once again, this is a very bad
location.
<< would this affect the transmit functionality? I could move it forward a
foot or so (just aft the flaps) to separate it from the comm antennas. >>
The nearness of other VHF antennas will affect performance more than a bend.
The above fuselage location has two ground planes of isolation from your Com
antenna.
Is it time yet to consider making the cover out of fiberglass instead of
aluminum?
Tom Kuffel
Posted: Wed Jan 15, 2014 6:46 pm Post subject: ELT Antenna |
The ELT antenna is almost never radiating and when it is activated, COM
radio performance is unlikely to be relevant. Bob may be able to confirm,
but I believe the ELT antenna proximity to VHF COM antennas can be
problematic because radio transmissions have been known to activate the ELT.
I acknowledge Mark's comment about the possibility of an underbelly antenna
being wiped off, which is why the base of mine will be firmly mounted
(midships) angled aft at about 45 deg (rather than bend the whip element)
and the fat part faired with fibreglass to minimise/absorb antenna impact
damage and or carve a path through the brush/grass. Perhaps different with
a tricycle undercarriage, but I can expect the taildragger to be upside down
if I land in scrub (with the main wheels so far forward and a heavy engine),
so my priority is to have the antenna less shielded by the aircraft when
inverted. If it were mounted on top, then it may also wiped off as the
aircraft comes to rest inverted or be pinned flat against the ally skin.
Preserving the coax link between the transmitter and antenna is a known
problem in major crashes, so keep the coax run short, protected and flexible
too if possible.
Kind regards, Stu
Kellym
Posted: Wed Jan 15, 2014 7:17 pm Post subject: ELT Antenna |
Almost all ELTs, especially the older ones do in fact radiate anytime
they are near high powered VHF transmitters in the FM, TV, etc bands.
That radiation will in fact severely affect Com radio reception.
The antenna for ELT is integral to its TSO so no home brew antennas
fullfill the TSO. While I think most DAR's are somewhat tolerant as to
antenna placement, most install instructions do call for installation on
top of the fuselage, and the install instructions are also part of the
TSO approval.
So while you may have valid points about final resting of a crash being
upside down, during the touchdown, prior to rollout odds are very high
that any belly antenna will be wiped off the airframe. IMHO, with about
equal experience between tail wheel(mostly off pavement in Alaska) and
nose dragging aircraft, in off field landing situations of soft surface,
nose wheel is far more likely to cause flipping than tail wheel.
Non-compliance with TSO is between you and your DAR, but most discussed
here will be at least technical non-compliance.
Kelly
too if possible.
Kind regards, Stu
KCHD |
tim2542(at)sbcglobal.net Guest
Posted: Wed Jan 15, 2014 7:47 pm Post subject: ELT Antenna |
DAR approval not needed as the ELT is not even required unless there are 2 or more seats, or for phase 1 testing. Not saying its wise or will work, but it will not be required to be present for airworthiness.
[quote] On Jan 15, 2014, at 7:16 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
Almost all ELTs, especially the older ones do in fact radiate anytime they are near high powered VHF transmitters in the FM, TV, etc bands.
The antenna for ELT is integral to its TSO so no home brew antennas fullfill the TSO. While I think most DAR's are somewhat tolerant as to antenna placement, most install instructions do call for installation on top of the fuselage, and the install instructions are also part of the TSO approval.
So while you may have valid points about final resting of a crash being upside down, during the touchdown, prior to rollout odds are very high that any belly antenna will be wiped off the airframe. IMHO, with about equal experience between tail wheel(mostly off pavement in Alaska) and nose dragging aircraft, in off field landing situations of soft surface, nose wheel is far more likely to cause flipping than tail wheel.
Non-compliance with TSO is between you and your DAR, but most discussed here will be at least technical non-compliance.
Kelly
> too if possible.
> Kind regards, Stu
Kellym
Posted: Wed Jan 15, 2014 7:55 pm Post subject: ELT Antenna |
Agreed if a single seater is all that is involved.
> Kelly
>> too if possible.
>> Kind regards, Stu
KCHD |
Posted: Thu Jan 16, 2014 5:02 am Post subject: ELT Antenna |
This phenomenon IS demonstrable . . . and rare. The
ELT isn't actually producing any output power unique
to its function. Very strong sources of local radiation
(typically FM stations and the old analog TV stations)
would find its way backwards into the output stage of
the ELT's transmitter (constantly hooked to the antenna -
receiver circuits are not so prone to exhibit this
behavior). If there are two or more strong sources,
then they can MIX or heterodyne against each other
and produce a variety of spurious signals on lots
of frequencies.
Analog TV is gone and about the only source of such
coherent energy would be an FM transmitter but you are unlikely
to spend much time flying around in the FM station's
radiation pattern and in close proximity . . . within
a mile or two.
One might hypothesize that the modern ELT's with
TWO transmitters attached to the antenna are even
more likely to exhibit the behavior . . . but you
still need to be poking around the vicinity of the
strong transmitter at altitudes generally 1000'
AGL or less.
I've heard the rumor that some ELT's were triggered
by local radiation from a comm transmitter . . . but
I've not seen any documentation or FMEA that supported
the assertion. Certainly, modern ELTs are subjected
to the standard DO-160 radiated susceptibility testing
and perhaps even HIRF (high intensity RF) testing.
None of this testing will concern itself with the
intermodulation phenomenon cited above but it would
watch for damage to the ELT and/or false triggering.
Posted: Thu Jan 16, 2014 5:09 am Post subject: ELT Antenna |
I don't recall the source now . . . it was many
moons ago . . . but the common wisdom circulated
on the TC side of the house was that on top of
the fuselage, just ahead of the vertical fin, was
the best location for ELT antennas.
If the wreckage did flip over, this location offered
the highest probability for protection by vertical
fin structure.
The 406 mHz signal will be heard nicely even if
the airplane is upside down . . . as long as the
antenna isn't broken off.
Given the magic multi-frequency design of modern
ELTs and their antennas, I suggest the installer
would do well to bite the bullet and strive for
as pristine an installation as possible per the
Hence, bottom side location or bending of the antenna
is discouraged.
gerry.vandyk(at)shaw.ca Guest
Posted: Thu Jan 16, 2014 5:44 am Post subject: ELT Antenna |
<nuckolls.bob(at)aeroelectric.com>
bands.
a mile or two.
Just to throw out a thought...
Yesterday the Canadian government opened the bidding to the 700 Mhz spectrum
to cell phone companies. The departure of analog television to digital
freed up the 700 Mhz band. At some point in the future at least in Canada a
smart phone in a pilot's pocket will be communicating on the former analog
TV band. Is this something we should be worrying about this side of the
border? Any thoughts about mitigating such risks?
Gerry van Dyk
Posted: Thu Jan 16, 2014 6:36 am Post subject: ELT Antenna |
Good question . . . and far outside my personal
experience history. But then, that's what all this
DO-160/254/178 etc. etc is suppose to explore, identify
and fix. That doesn't mean the occasional 'gotcha' won't
surface in spite of best efforts . . . recent lithium
battery issues are a good example. But that's part
and parcel of any evolving technology.
I'm working on an article for Kitplanes that will attempt
to put some perspective on the lithium battery market as
it relates to our airplanes. I'm not going to suggest
that everybody pry the lead out of their airplanes
and plunk lithium down in the hole . . . but lithium
IS a rising star on the horizon . . . and there are
ways to minimize risks while exploring POTENTIALLY
attractive returns on investment.
There was a similarly bumpy start up for ni-cad batteries
on airplanes too . . . Wwwaaaayyyy back when. They offered
some spectacular performance . . . but we set a few airplanes
on fire with those batteries too. Today, the ni-cad is
still attractive for some operators but it has not displaced
the lead-acid products. Perhaps lithium will evolve to the
same kind of market position . . . perhaps not . . .
I'd say that the risks from the new phones are VERY low.
Consider the actual radiate power of any hand held device,
particularly a telephone. Digital communications technologies
work very hard to maximize performance while minimizing
energy consumption. This tends to make radiators less
hazardous and receivers more resistant to co-located
interference.
Kellym
Posted: Thu Jan 16, 2014 7:11 am Post subject: ELT Antenna |
Hmm, I don't know why the switch to digital TV will make much
difference. They are still broadcasting in my area on VHF RF channels 7
and 8 through 13 in my local area. I used to have an antenna
configuration on my Mooney that consisted of VHF com in front of
windshield, top of fuselage behind baggage compartment, Loran about 18
in. behind that, followed by ELT antenna right in front of vertical
stab. When flying VFR transition over Phoenix Sky Harbor I would get bad
squelch break anywhere within 10 nm of the antenna farm located on South
Mountain, approx 8 mi south of Sky Harbor. Made hearing controllers very
difficult.
I isolated it to the ELT by doing a flight with external ELT antenna
disconnected, which completely eliminated problem even within a mile of
the transmitters. This was a 1st generation ELT. Moving 1st com antenna
from in front of windshield to the belly virtually eliminated the
interference. Removing Loran antenna (custom version of Comant CI121)
helped as well.
I understand later versions of ELTs have somewhat better isolation of
the transmit oscillator, but doesn't completely eliminate. Good
separation between ELT and com antennas is probably best defense.
Kelly
of frequencies.
a mile or two.
AGL or less.
KCHD |
msmeredith
Posted: Thu Jan 16, 2014 4:06 pm Post subject: Re: ELT Antenna |
All,
After digesting everyone's points, I decided I better pay attention to function over beauty...I'm going to mount the ELT antenna on top of the turtleback. It'll be a foot or so forward of the fin - can't reach inside much farther than that anyway to beef it up and install hardware. Ordered a longer coax today. Thanks much for all your inputs and ideas!
