fraser221
Posted: Wed Jan 15, 2014 12:43 pm Post subject: Tp12 s |
can anyone help in identifying the material used in the construction of the TP 12 Drive plates as i need to have some custom ones made as they have worn and replacements are now a different size?
thanks
fraser
kjburns(at)btinternet.com Guest
Posted: Wed Jan 15, 2014 2:44 pm Post subject: Tp12 s |
Fraser,
Andy Draper at the LAA has a wealth of knowledge of the material specifications, including the interference fit of the TP 14 pins, you remove the tp 12 fitting, by pulling these pins you will also have to go to the next oversize on these pins too, then ream your assembled parts to the correct interference fit, or you will find movement in the assembly when you re-fit.
If tp 12 pins are worn , I would also do an inspection and if worn replace tp 13, ( the socket that is bonded in to the tail plane) , if this assembly is jigged together while bonding should take care of slight welding errors.
Kevin
Sent: Wednesday, 15 January 2014, 20:43
Subject: Tp12 s
--> Europa-List message posted by: "fraser221" <vicflett(at)tiscali.co.uk (vicflett(at)tiscali.co.uk)>
thanks
fraser
http://forums.matronics.com/viewtopic.php?p=416961#416961http://forums.matronics  tronics.com/contribution" target="_blank">http://www.matronics.com/contri================
