stuart(at)harnerfarm.net Guest
Posted: Thu Jan 23, 2014 7:27 am Post subject: Kolb detail photos (now rudder cables) |
Your clearance problem is exactly the way my firefly is. Only a problem at
full up elevator. Also caused by the compression sleeves, not the cable
itself.
At this point I don't see what can be done to change the design enough to
make it work better, but it needs to have something done to it.
Since the problem is the compression sleeves, and mostly the second one in
from the end, maybe a making a new cable with the second sleeve either moved
forward another 1/2" or positioned right up next to the first sleeve.
Either way, it would mean making all new cables which is something I am not
prepared to do just yet. Had I known about this before I made the cables, I
might have tried something else.
After looking at some other airplane cables I am not convinced that a double
sleeve is needed (I need to look in AC 43 to see what it says about the
subject), however I am not willing to go with just one sleeve on the rudder
cables without a pretty compelling reason.
When compressing the sleeves, a small ridge rolls up right at the outer
edges, at least with my compression tool anyway. What I plan on doing when
I take the tail feathers off for covering is to lightly file those sharp
ridges down a little so they do not dig into the elevator horn as much.
A small piece of heat shrink tubing on the cable will help ramp the cables
over the elevator horn when they make contact and will soften the contact.
There are downsides to this as it will not last forever and it will possibly
trap moisture and then hide it from inspection. So, one may be making a
more dangerous situation, as you can easily watch and touchup the elevator
horn when needed. I wonder if you can buy clear heat shrink tubing?
I have some heat shrink tape that is not very useful for electrical work,
but I may try to put some on the elevator horn. It can be replaced as
needed.
As a perfectionist, the other thing that bothers me is all the cables just
lay on the bottom of the tail boom, rubbing both the boom and the other
cables. In a perfect world they would all be riding on pulleys and not
touching anything else. To do this, even if I could figure out how, would
add quite a lot of complexity and some weight. Some have suggested perhaps
working a very thin sheet of some tough plastic material into the boom and
then a few rivets to hold it down. Again, hard to do and traps moisture.
Realistically, how many times do you have to move those cables to actually
cause any damage, and how many flight hours would that be? When I stop and
think about it, that perfectionist side of me needs to be tamed down a
little.
Stuart
Posted: Thu Jan 23, 2014 7:45 am Post subject: Kolb detail photos (now rudder cables) |
Kolbers:
There are a lot of Kolbs out there, all models, with clanging cables
smacking the tail boom when taxiing, rubbing against each other, etc. I do
not know of any that have failed for any reason in the last 30 years that I
have been building and flying Kolbs. My MKIII has over 3,200.0 hours on the
airframe, has all the symptoms of clanging cables, and is still safe and
flying strong.
My MKIII also had the problem of nicopress sleeve hitting rudder horn. I
filed the ridge off the offender when I built it in 1991. I don't cover up
nicopress sleeves. I want to be able to see them.
If something bothers you, fix it, and remember how many of these Kolbs are
out there flying and how long they have been flying.
Titus, Alabama Airframe: 3,229.5 hours Engine: 611.0 hours
_________________ John Hauck
Titus, Alabama |
Ducati SS
Posted: Thu Jan 23, 2014 9:08 am Post subject: Re: Kolb detail photos (now rudder cables) |
Yes you can buy clear heat shrink , I have some. Of course it needs to go on the cable prior to pressing. Another possible solution I have considered is to remove the bell crank, fabricate a curved support saddle for the bottom half of the tube and using my shop press, press a small flat relief at the sleeve contact site. I am considering going experimental with the plane and though I see no safety issue I wonder if the FAA may have a problem with the interference.
koxxy
Joined: 19 Oct 2011 Posts: 28 Location: Beaverton, OR
Posted: Thu Jan 23, 2014 11:38 am Post subject: Kolb detail photos (now rudder cables) |
I am building an Earthstar eGull, just lurking here. Mark Beierle solved the "chafing cable" issue by placing a "comb" on the forward face of the boom, UHMW or teflon, 1/8" thick, with slits where the cables are supposed to be. Simple, light weight, and should last a while (unless your angle change is large).
On Thu, Jan 23, 2014 at 7:26 AM, Stuart Harner <stuart(at)harnerfarm.net (stuart(at)harnerfarm.net)> wrote:
[quote]--> Kolb-List message posted by: "Stuart Harner" <stuart(at)harnerfarm.net (stuart(at)harnerfarm.net)>
itself.
needed.
little.
Stuart
Posted: Thu Jan 23, 2014 11:58 am Post subject: Kolb detail photos (now rudder cables) |
Thanks John, that is the kind of feedback I need to keep from going
overboard.
Having never been around a Kolb of any version before, my only point of
reference is the certified stuff I used to fly, and I know that even there,
sometimes perfect is still way beyond safe and reasonable.
I think that there has to be a merging of good enough, craftsmanship and
perfection.
Stuart
Posted: Thu Jan 23, 2014 12:55 pm Post subject: Kolb detail photos (now rudder cables) |
Maybe I don't understand the problem you are having. Did you run out of
space/clearance between the rudder horn and the inside of the tail boom?
Did you speak to Kolb Aircraft Company to see if this was a production
problem or make a onetime screw up?
Everything produced at Kolb is welded in jigs.
Titus, Alabama |
Posted: Thu Jan 23, 2014 1:28 pm Post subject: Kolb detail photos (now rudder cables) |
Mine is a quick build, so all of those parts were installed by the factory.
All I did was make and install the cables.
If the rudder horn is moved up, then the cables would hit the top of the
tail boom, all of the time. The only time the cables touch the elevator
horn is when the elevator is at the uppermost deflection. Still the
nicopress sleeves scrape the paint off of the elevator horn, exposing bare
steel to rusting.
I think I can cure this with a little smoothing of the edges of the sleeves
and a small wear block on the elevator horn. I have to do some scrounging
but I think a very small piece of pvc pipe that will fit over the horn may
do the trick. Say an inch long for each cable location. Split the pipe so
that it can be pried on over the elevator horn. Maybe a small drop of
silicone to secure it. Check on it at preflight and remove and replace when
needed.
This idea just popped into my head, I need to go to the shop and see what I
can invent.
Stuart
Posted: Thu Jan 23, 2014 1:37 pm Post subject: Kolb detail photos (now rudder cables) |
Recommend calling Bryan Melburn
at Kolb to see what he suggests.
Titus, Alabama |
Posted: Thu Jan 23, 2014 4:00 pm Post subject: Kolb detail photos (now rudder cables) |
At 09:08 AM 1/23/2014 -0800, you wrote:
........................ I am considering going experimental with the plane
Nice looking FireFly.
If you plan to fly it as an ultralight vehicle (AC 103-7) the FAA has
nothing to do with checking anything.
The only thing the FAA can do is to ask you to provide proof that your
ultralight vehicle meets AC 103-7 requirements.
Jack B. Hart FF004
Winchester, IN
Ducati SS
Posted: Fri Jan 24, 2014 4:32 am Post subject: Re: Kolb detail photos (now rudder cables) |
My first flights were part 103, but now I am considering a larger fuel tank which would move the plane out of 103.
