zsmith3rd(at)earthlink.ne Guest
Posted: Tue Jun 20, 2006 5:08 am Post subject: Slosh |
Geoff,
This may not be the method you want to use....
Add a bit of red food coloring to whatever you slosh.
The stuff is cheap, very concentrated, and will certainly show your pinholes.
Don't get it anywhere except in the tank....you'll have red fingers for a week.
Juat a suggestion,
Zed
Geoff Heap
Joined: 12 Jan 2006 Posts: 266 Location: Lindenwold, New Jersey
Posted: Tue Jun 20, 2006 6:07 am Post subject: Re: Slosh |
Zed to the rescue. Thanks, I'll bear the food coloring in mind but what is it that I slosh.Some kind of sealant? and is it NECCESARY or is it OPTIONAL. Again, this is an alum tank.....Geoff
bryanmmartin
Posted: Tue Jun 20, 2006 7:16 am Post subject: Slosh |
Sloshing compound should not be necessary in a welded aluminum tank
if the welds are any good. In fact, sloshing compound should be
avoided if at all possible. It's expensive, it adds weight, it's a
mess to work with and will possibly need to be redone after several
years in use.
If you think the welds might leak, seal up all the openings, put a
little bit of air pressure in the tank and use bubble solution to
look for leaks. If you find any, either reweld them or use some JB
Weld to seal them up. Don't use high pressure air to pressurize the
tank, you can easily destroy the tank. You can tie a balloon over one
of the tank openings and use enough pressure to inflate the balloon.
That will pretty much guarantee you won't over pressurize the tank
On Jun 20, 2006, at 10:08 AM, Geoff Heap wrote:
Bryan Martin
do not archive.
_________________ --
Bryan Martin
do not archive. |
noelloveys(at)yahoo.ca Guest
Posted: Tue Jun 20, 2006 9:58 am Post subject: Slosh |
Ingenious use of a balloon. I like that one. It could be used to pressure
test heat muffs too.
Noel
[quote] --
Geoff Heap
Posted: Tue Jun 20, 2006 12:43 pm Post subject: Re: Slosh |
I used the Balloons too. They inflated at 3 psi. Didn't like the noises coming from my tank. I certainly would not use more than 3 psi. I guess I don't need to use any sealing compound in them.
Bye the way I'm on wheels now I started from plans in 1991 and never thought I'd see this day. ....Geoff
172.46 KB |
347 Time(s) |
