stuart(at)harnerfarm.net Guest
Posted: Fri Jan 31, 2014 6:04 pm Post subject: Firefly flap question |
OK guys, with the aileron in the neutral position, when you go to full flaps, how far does the trailing edge of the flaps drop?
The reason I ask is I am working on the flaperon handle. I clamped everything in place to make sure it was all aligned properly before drilling and riveting. With the slider all the way back (handle in the down most slot) everything lines up fine. When I move the handle to the uppermost slot (full flaps) the slider only moves a little more than halfway of non-painted area of the torque tube.
So, is there more travel on the torque tube than needed, or does the flap handle bracket not allow enough travel?
From the plans, total trailing edge movement of the ailerons is 8” (4” up and 4” down). This seems a little small when looking at the ailerons, but about right when looking at the joystick. So, if a 4” drop is normal for aileron deflection, what is normal for flap deflection?
Thanks in advance,
Stuart
Posted: Fri Jan 31, 2014 6:18 pm Post subject: Firefly flap question |
Should be about 40 degrees full down and 20 degrees half down. Or, I should say, the flaps on my MKIII operate to those limits. I feel like it is a near perfect rigging.
4 inches up and down travel of the ailerons seems to be about right. I'd have to go over to the airstrip and measure mine to be sure.
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Stuart Harner
Sent: Friday, January 31, 2014 8:04 PM
Subject: Firefly flap question
Thanks in advance,
Stuart01234567890123
_________________ John Hauck
Titus, Alabama |
beauford173(at)tampabay.r Guest
Posted: Fri Jan 31, 2014 6:57 pm Post subject: Firefly flap question |
Brother Harner:
Mine droop about 2.5 inches at the trailing edge, but I have the original fifteen inch chord flaperons.
Your results may vary with the shorter ailerons in the current plans…
Worth what ye paid fer it…
Beauford
FF-076
Brandon, FL
Sent: Friday, January 31, 2014 9:04 PM
Posted: Fri Jan 31, 2014 7:30 pm Post subject: Firefly flap question |
Sorry Kolbers. Disregard my response below. I thought we were talking about MKIII's.
Getting old ain't for sissies.
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of John Hauck
Sent: Friday, January 31, 2014 8:19 PM
Subject: RE: Firefly flap question
From: owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com) [mailto:owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com)] On Behalf Of Stuart Harner
Thanks in advance,
Stuart01234567890123456789 | Quote: | | - The Kolb-List Email Forum - | 0 | Quote: | | - The Kolb-List Email Forum - | 1 | Quote: | | - The Kolb-List Email Forum - | 2 | Quote: | | - The Kolb-List Email Forum - | 3 | Quote: | | - The Kolb-List Email Forum - | 4 | Quote: | | - The Kolb-List Email Forum - | 5 | Quote: | | - The Kolb-List Email Forum - | 6 | Quote: | | - The Kolb-List Email Forum - | 7 | Quote: | | - The Kolb-List Email Forum - | 8
Titus, Alabama |
Ducati SS
Posted: Sun Feb 02, 2014 5:53 am Post subject: Re: Firefly flap question |
I placed a tie wrap on the control tube and cycled the flaps full up to full down - 1 5/8 " total travel.
Posted: Sun Feb 02, 2014 4:48 pm Post subject: Firefly flap question |
That sounds about right. I will compare to my Firefly next work day in the
shop. I know that the area of the torque tube that was not powder coated
was about twice that length, but maybe the slider is not supposed to move
that far.
Thanks for the help.
Stuart
