donjohnston
tim2542(at)sbcglobal.net Guest
edpav8r(at)yahoo.com Guest
Posted: Tue Feb 04, 2014 9:59 am Post subject: Batteries and step down converters |
What device are you planning to power from such a DC/DC converter that needs a supply capable of 10-20 amps?
Lone Star's prices reflect the high cost of TSO compliance testing and, as you suggested, application of the word "aviation" to their products. That said, I'll bet they're high quality. The Pyle... who knows?
As long as in-flight failure of the connected device would have no safety implications, I wouldn't hesitate to use the Pyle converter, or indeed any you might find on eBay for even less $, smaller size and lower weight.
Perhaps this: http://bit.ly/1frGS3M -or this- http://bit.ly/1eQFmXj -or this- http://bit.ly/LM7x2A
Or, if 5A current capacity is enough, this: http://bit.ly/1n8N17Y
Search eBay for "DC buck" and you'll get endless hits.
I would figure out the peak current draw of your device, double it, and buy a converter with that capability to assure adequate supply without high operating temps. I wouldn't lose much sleep about reliability; if a converter functions out of the box, it's probably unlikely to fail later, assuming it's not driven to absurd temperatures or subjected to mechanical abuse.
Eric
On Feb 4, 2014, at 9:34 AM, "donjohnston" <don(at)velocity-xl.com> wrote:
Posted: Tue Feb 04, 2014 10:59 am Post subject: Batteries and step down converters |
At 10:34 AM 2/4/2014, you wrote:
Two totally unrelated questions...
1) To keep my primary EFIS up during engine start, I'm thinking of
using a small battery (I will need two since I've got a 24v system).
I've seen mention of people using 7ah batteries for this. What
manufacture/model battery people are using?
What is the input voltage requirement for your
electro-whizzies. Many contemporary products now
use switch-mode power supplies with a wide range
of acceptable inputs . . . typically 0-32 volts.
If your devices are of this generation, then you
don't need brownout protection in a 28v system . . .
starter inrush drain won't pull your bus below
10 volts and the glass will stay powered up.
The problem arises when a device with a 10v minimum
input voltage sees a drop to 7-8 volts during starter
inrush events.
2) I've got one device that is only available in a 12v version. I was
going to get this step down converter from Lone Star.
http://www.lonestaraviation.com/Step-Down-Conveter-24V-to-13.8-Volts.html
Then I ran across this one at 1/5th the cost.
http://www.pyleaudio.com/sku/PSWNV480/24V-DC-to-12V-DC-Power-Step-Down-480-Watt--Converter-W-PMW-Technology
I'm wondering if it's likely that there is a fundamental difference
between the two beyond one of them being for the aviation market.
What is the device you're fitting with the down-converter
and what are its input demands?
