Plane Power Alternator
teamgrumman(at)yahoo.com
PostPosted: Thu Feb 06, 2014 12:54 pm    Post subject: Plane Power Alternator Reply with quote
To those who've installed a Plane Power Alternator, you may have noticed the terminal is just opposite the hole in the baffle where the wire is supposed to go. VERY bad setup. The terminals should be rotated 90 degrees one way to the other.
I made my own pass through with all new wires. Much nicer.
 Filesize:  2.12 MB
 Viewed:  2912 Time(s)
 Filesize:  1.8 MB
pwilson125(at)AOL.COM
PostPosted: Fri Feb 07, 2014 5:30 am    Post subject: Plane Power Alternator Reply with quote
Hello Gary, What type of Grumman is this on, Tiger?
Did you make up new longer wiring?
Thank you
Patrick Wilson
3143786574
PostPosted: Sat Feb 08, 2014 11:42 pm    Post subject: Plane Power Alternator Reply with quote
All new wires. I'll take another pic when the baffles are done.
Gary
Sent from my iPad
On Feb 7, 2014, at 5:29 AM, Patrick Wilson <pwilson125(at)AOL.COM (pwilson125(at)AOL.COM)> wrote:
[quote] Hello Gary, What type of Grumman is this on, Tiger?
Thank you
Patrick Wilson
3143786574
